aradford
Continuing the story
The first blog in this series gave an overview of network Plug and Play and how it could be used on APIC-EM.  The second blog gave examples of how network-device configuration template could be created programmatically and using the REST API, uploaded to the controller along with the PnP rules and projects.  This blog provides an "all-in-one" script to tie all the scripts together using a client library called Uniq.
I also cover the code needed to build a Cisco-Spark chat-ops bot to integrate into the PnP API.  The output is shown below.
GitHub
As usual, all the source code is in a Github repository.  Here are the steps you need to take to download them in a terminal session.
git clone https://github.com/CiscoDevNet/apic-em-samples-aradford.git
cd apic-em-samples-aradford/
cd uniq_samples/code_samples/PnP
Here is what the output should look like  when you run the commands above in a command window.  NOTE:  This is for linux/MAC, windows is outside the scope of this blog.
$ git clone https://github.com/CiscoDevNet/apic-em-samples-aradford.git
Cloning into 'apic-em-samples-aradford'...
remote: Counting objects: 409, done.
remote: Total 409 (delta 0), reused 0 (delta 0), pack-reused 409
Receiving objects: 100% (409/409), 580.75 KiB | 523.00 KiB/s, done.
Resolving deltas: 100% (198/198), done.
Checking connectivity... done.
$ cd apic-em-samples-aradford/
$ cd uniq_samples/code_samples/PnP
$ ls
00_get_project.py     __init__.py           pnp_config.py
01_create_project.py  __pycache__           suffix.py
02_delete_project.py  bot                   work_files
Installing Uniq
Cisco has recently published a client library for APIC-EM.  It does require python3.   As per recommended best practice I am going to use a virtual environment for installing custom packages.  Here are the commands you need to use in a terminal window:
virtualenv -p python3 env
source env/bin/activate
pip3 install uniq
Here is the output from running those commands:
$ virtualenv -p python3 env
Running virtualenv with interpreter /usr/local/bin/python3
Using base prefix '/Library/Frameworks/Python.framework/Versions/3.4'
New python executable in /private/tmp/adam/env/bin/python3
Also creating executable in /private/tmp/adam/env/bin/python
Installing setuptools, pip, wheel...done.
$ source env/bin/activate
(env)$ pip3 install uniq
Collecting uniq
  Downloading uniq-1.2.0.20-py3-none-any.whl (521kB)
    100% |████████████████████████████████| 522kB 1.1MB/s
Collecting requests>=2.6.0 (from uniq)
  Using cached requests-2.10.0-py2.py3-none-any.whl
Installing collected packages: requests, uniq
Successfully installed requests-2.10.0 uniq-1.2.0.20
(env)$
Automatic Creation of Configuration Files
As discussed in blog2, a jinja2 template is used to aid the generation of configuration files.  The config_template.jnj file you can see there are two variables: "hostname" and "ipAddress".  These correspond to columns in the inventory.csv file. You could have as many variables as you like.
hostname {{hostName|lower}}
enable password cisco123
username cisco password 0 cisco123
no aaa new-model
int vlan 1
ip address {{ipAddress}}
end
It is critical to have "end" as the last statement in the file.
Here is an example of running this script.  The output files are stored in the "work_files/configs" directory.  Notice that a suffix has been added to the filenames to make them unique. As the example scripts are using a sandboxapic in the cloud, multiple people can be running the scripts at a time. This suffix should be unique, so you do not clash with other users.  In production you would not do this.
Script for Creating/Uploading
In this blog all of the steps are combined into one script.  A template file is created, it is uploaded to the controller, a project is created and a rule is added to the project.
$ python3 10_create_and_upload.py
{'site': 'Sydney', 'serialNumber': '12345678901', 'hostName': 'sw01', 'ipAddress': '10.10.10.101', 'platformId': 'WS-C2960X-48FPD-L'}
created file: work_files/configs/sw01-config-6230
creating project:Sydney-6230
    "pkiEnabled": true,
    "serialNumber": "12345676230",
    "hostName": "sw01",
    "configId": "44e5e148-a64b-48b0-a321-76e5ff1008f4",
    "platformId": "WS-C2960X-48FPD-L"
{"message":"Success creating new site device(rule)","ruleId":"a740c94a-2a07-4f05-8c54-8eb54b547046"}
<SNIP>
A file is created in "work_files/configs/sw01-config-6230. A project is created called "Sydney-6230", and a rule created using the configId of the file "sw01-config-6230".
Uniq client library
The first thing needed is a client manager to interact with the controller API.  The file in the parent directory "../login.py" contains the code to do this:
def login():
    """ Login to APIC-EM northbound APIs in shell.
    Returns:
        Client (NbClientManager) which is already logged in.
    try:
        client = NbClientManager(
                server=APIC,
                username=APIC_USER,
                password=APIC_PASSWORD,
                connect=True)
In the code we open a client manager called "apic" that will be used to make all of the REST APIC calls.  Below is a simple example of uploading a configuration file.
Note the apic.file.uploadFile call.   This is using the file API, and the uploadFile method.
def upload_file(apic, filename):
    file_id = is_file_present(apic, "config", os.path.basename(filename))
    if file_id is not None:
        print ("File %s already uploaded: %s" %(filename, file_id))
        return file_id
    file_result = apic.file.uploadFile(nameSpace="config", fileUpload=filename)
    file_id = file_result.response.id
    return file_id
Looking at swagger, you can see how this call was generated.  You can see "file" is the collection of filesystem API.  "uploadFile" in red box is the call required to upload a file to the controller. Obviously it is a POST call.
Click on the /file/{namespace} POST API, to see the details of which parameters can be provided. Both "nameSpace" and "fileUpload" are used in the earlier call.
Asynchronous API Calls
The /file API are synchronous, meaning they block until the call is complete, then return the status and the id of the resource that was created.  For example, when uploading a file, you will not see a response until the file upload is complete.  For a large file, this might take a while.
All other POST/PUT/DELETE API calls are asynchronous, meaning they return a 202 response code and a taskId for the request made. For example, to create a new pnp-project, with a "siteName":"Sydney", you would make a POST to /pnp-project, you would expect a 201 HTTP response code, with the UUID of the resource. Instead the following happens:
  1. The POST will return you will get a taskId.
  2. GET the /task/taskId and the body have a key  "endTime" which indicates the task is complete and "isError" which shows the error status.  If the task completed without error,  "progress" will be the UUID for the pnp-project  (<pnp-project-id>).  Longer running tasks may require GET requests, until they complete.
  3. GET /pnp-project/<pnp-project-id> will return the newly created resource.
Uniq  simplifies task management with the wait_for_task_complete method.  The id of the project that was created is in the "progress" attribute (it is the "siteId" attribute).
def lookup_and_create(apic, project_name):
    project_name = name_wrap(project_name)
    project = apic.pnpproject.getPnpSiteByRange(siteName=project_name)
    if project.response != []:
        project_id = project.response[0].id
    else:
        # create it
        print ("creating project:{project}".format(project=project_name))
        pnp_task_response= apic.pnpproject.createPnpSite(project=[{'siteName' :project_name}])
        task_response = apic.task_util.wait_for_task_complete(pnp_task_response, timeout=5)
        # 'progress': '{"message":"Success creating new site","siteId":"6e059831-b399-4667-b96d-8b184b6bc8ae"}'
        progress = task_response.progress
        project_id = json.loads(progress)['siteId']
    return project_id
Cisco Spark Chat-Ops Bot Code
Cisco spark is a collaboration tool that has "room" based messaging.  Spark has a powerful API that is easy to integrate. This post is not going to cover every detail for Spark integration, just the highlights for the APIC-EM PnP integration.
There are two parts to the spark integration.  The first is the ability to post to a room.  This is done for each PnP project created, or when a PnP device rule is provisioned.
  The code below shows how this works.  You need to get an  "authentication token" from https://developer.ciscospark.com/.  This is used in the "authorization" header. You also need to know the roomId you are posting to.  Spark has an API you can call to get a list of rooms you are a member of, join a room etc.
def post_message(message, roomid):
    payload = {"roomId" : roomid,"text" : message}
    headers = {
    'authorization': AUTH,
    'content-type': "application/json"
    response = requests.request("POST", url, data=json.dumps(payload), headers=headers)
The second part is the ability to issue commands to the bot, and have it respond.  For example "apic show pnp-projects".  This requires a webhook to integrate to the Spark chatroom (see https://developer.ciscospark.com/ for more information) All  SparkRoom  messages will be received by My-BOT server.  The steps are illustrated below:
  1. A user types a message "apic show pnp-projects" in the Spark chatroom
  2. Their spark client client will post the message to the Spark server
  3. The webhook will POST the messageId and room ID to My-Bot.
The code to receive the webhook post on My-Bot is shown below (this is step #3)
def bot_webhook():
  messageid = request.json['data']['id']
  roomid = request.json['data']['roomId']
  message = get_message(messageid)
  process_message(message, roomid)
  return jsonify(""), 201
You then need to make an API call to spark to get the contents of the message (Step #4).
url = "https://api.ciscospark.com/v1/messages"
def get_message(messageid):
    messageurl = url + "/" + messageid
    headers = {
      'content-type': "application/json"}
    print ("getting: %s" % messageurl)
    response = requests.request("GET", messageurl, headers=headers)
    response.raise_for_status()
    return response.json()['text']
Next you need to process the messages, for example "apic show pnp-project".  This requires an API call to APIC-EM (step #5)
def apic_login():
    apic  = NbClientManager(server="sandboxapic.cisco.com",
  username="devnetuser",
  password="Cisco123!",
  connect=True)
    return apic
def apic_show_pnp_project(apic):
    response = ""
    projects = apic.pnpproject.getPnpSiteByRange()
    for project in projects.response:
        response += "Project {project}: count {count}\n".format(
                            project=project.siteName,
                            count=project.deviceCount)
    return response
The function post_to_spark(message) described earlier can be used to reply to the spark room.
NOTE: ANY messages that are sent to the room (including the ones you post) will be sent to the chat-bot.  Make sure you do not auto respond to your own messages!  You will end up in a loop.
Self destructing EEM script in configuration
A PnP configuration file is downloaded when the network-device first boots.  Some elements of configuration might be time sensitive (e.g. a virtual routing and forwarding (VRF) configuration).  In addition, there are some things such as VLAN defined outside the configuration file (e.g. vlan.dat – the vlan database).
To address this problem, an embedded event manager (EEM) script can be put into the configuration file. This contains commands to be run after the configuration is downloaded.  To ensure it is only run once, you can tell the EEM script to "self destruct" i.e. remove itself after it has run.   The highlighted EEM commands below will:
  • Create an EEM script called POST_PNP
  • wait 30 seconds
  • create vlan 15 on the network-device
  • remove itself after executing
line con 0
line vty 0 4
login local
transport input ssh telnet
line vty 5 15
login local
event manager applet POST_PNP
event timer countdown time 30
action 1.0 cli command "enable"
action 1.1 cli command "config t"
action 1.2 cli command "vlan 15"
action 2.0 cli command "exit"
action 2.1 cli command "no event manager applet POST_PNP"
action 2.2 cli command "end"
action 2.3 cli command "exit
end
What Next?
This blog covered more advanced topics such as embedded EEM scripts in the day zero configurations, using a client library (uniq) to make the code more efficient and integrating all of the components into a single tool.  It also showed how the API could be used to integrate into a spark chat room (Thanks to Jose Bogarín for that idea)
In the meantime, if you would like to learn more about this, you could visit Cisco Devnet.  DevNet has further explanations about this. In addition, we have a Github repository where you can get examples related to PnP.
Thanks for reading
@adamradford123
13 Comments
jboga
Level 5
Level 5
The EEM stuff is really cool. Would never have thought of it. Very useful.
Integrating Spark with APIC-EM is great. I'm still thinking about use cases for POST calls but for GET is quite nice. We are working in a project with a big rollout and we are working in this chat bot to allow the project manager to get the information that he needs without having to go to an engineer.
I don't know if it's a feature in the roadmap but I think that having some kind of webhook in APIC-EM would be great for a use case like this. For example I can register to a PnP event and trigger an action in the chat bot, or any other system for that matter, when a new device is configured.
Again, great blog.
aradford
Thanks Jose,
I appreciate the comments.
Yes, we are looking to add notifications in APIC-EM.  Please "make a wish" to add support for this.  At present, the only way to do this is poll/store state... which is how i am doing it right now.
jboga
Level 5
Level 5
Thanks. As soon as I'm in front of the computer. I'll get to my APIC-EM and make that feature request.
zztopping
Level 4
Level 4
Oh my god, just spent about 8 hours trying to isolate why my PnP configs were failing...VLANS!!! When I remove the vlans from my configuration, the configuration deploys with no errors as I would expect it would.
Is the EEM script to deploy VLANs the only workaround for this behavior? I can't believe the documentation doesnt mention this at all.
aradford
Hi Jonathan,
It depends on the mode that you have chosen for VTP.  If you are using VTP transparent mode, then the vlans will appear in the configuration file and you should be fine.
If you are using VTP, then there are different considerations.  VTPv1 is default, but many people use transparent mode.
Adam
zztopping
Level 4
Level 4
Maybe I'm hitting a caveat then. On 9300 running 16.6 code, I cannot push VLANs using the nomenclature:
vtp mode transparent (or off)
vlan XXX
name YYYY
With the VLAN statements present, i get a error 1410 in the PnP logs. Without them present, this process works flawlessly. Using your EEM script VLANs are added just fine, and VTP is also set fine with no EEM. It seems to me that MAYBE VTP isnt being properly set "in time" or "quickly enough" for the VLANs to be pushed properly.
I'll try an older platform (3650 on 16.3) to see if this still occurs. Your blog series has been awesome by the way.
aradford
Hi Jonathan,
Just to save you some time, I tested with 3650 - IOS-XE 3.6.6 and it works fine.  I am also able to replicate the issue on 16.6.1 with 3650.  It looks like the behvaior has changed in 16.x, so nothing to do with hardware.
I will chase down the root cause and update.
Thanks for the note about the blogs.  Just trying to help people out.
Adam
aradford
Hi Jonathon,
There is a long back story, but the short story is if you are running the latest PnP v1.5.1.35 - released 14th Aug
you will be fine.
You can just download the PnP application (it is only 16M) and drag and drop it into admin -> app management
We have separated out the PnP app from the base platform now.
Adam
zztopping
Level 4
Level 4
I was on 1.5.0.211 before. Just updated to the 1.5.1 as you suggested and it shows success but doesn't actually push the vlans down.
Super simple config I'm using to test
hostname vlantest
vlan 10
name test1
vlan 100
name mgmt
vlan 689
name test2
end
aradford
You need to have vtp mode transparent or off as well
Sent from my iPhone
aradford
Here is my config file.  Note: I need to have vtp in either transparent of off mode.
vtp mode off
vlan 14
name management
vlan 20
name fred
vlan 999
end
zztopping
Level 4
Level 4
I'm a knuckle-head. My last mini-test after the PnP upgrade I forgot the VTP step, everything is working great.
In summary:
  • PnP 1.5.0 could NOT push vlans to IOS-XE 16.6 switch unless a special EEM script was written, regardless of VTP state.
  • PnP 1.5.1 works great using "normal vlan configurations" (don't forget VTP!)
aradford
We made some changes in 16.x around strict syntax checking for configuration files.  PnP1.5.1 will take that into account.  It is actually a false negative, but PnP will do the right thing.
BTW, if you are really keen, you should notice that it is actually the "name" statement that causes the issue in 1.5.0.  You should be able to push vlan if the do not have a name.
Adam
