One of the latest and big scenario of the OSPF Demystified with RFC book called "OSPFv3 path selection with RFC 3101 1587 2328 5340", when you look at the explanations, you will change drastically your thought about path selection.
Note: Only one command is used in the entire scenario "the compatible rfc command".
