velo84
I'm currently redistributing OSPF to BGP and setting a local pref on the routes. Currently this works fine and having no issues.
 ip prefix-list ospf-routes seq 10 permit 172.16.100.0/24
 route-map ospf-bgp permit 10
  match ip address prefix-list ospf-routes
  set local-preference 100
What I would like to do is have some routes with a local pref of 100 and some with a local pref of 200. I tried to create a new ACL and then a new permit statement in the existing route map but it gives an error saying you can only have one match ip statement in a routemap.
E.g. I wanted to do this (it doesn't allow this config though)
 ip prefix-list ospf-routes-cust-1 seq 10 permit 172.16.100.0/24
 ip prefix-list ospf-routes-cust-2 seq 10 permit 172.16.200.0/24
  match ip address prefix-list ospf-routes-cust-1
 route-map ospf-bgp permit 20
  match ip address prefix-list ospf-routes-cust-2
  set local-preference 250
What would be the best way to achieve this?
4 Comments
no route-map ospf-bgp
do this first and repeat the config.
I think you can't modify seq 10 of this route-map,
so do this first and then repeat the config.
velo84
Oh that's odd, I removed it and added it back then it let me. Is that a bug or something? Thanks a lot
That Good,
i think it is not bug but this is only way to modify route-map.
can you please mention that this issue solved.
velo84
Thanks, unfortunately there is no option for that. Just 'mark as helpful'
