Any idea why this TDR wont run on fa ports?
#test cable-diagnostics tdr interface ?
GigabitEthernet GigabitEthernet IEEE 802.3z
No option for fa ports.
POP29-DIAMSANDS_BLD_10#sh ver | inc image
System image file is "flash:/c3750-ipservicesk9-mz.122-55.SE9.bin"
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750-48TS 12.2(55)SE9 C3750-IPSERVICESK9-M
POP29-DIAMSANDS_BLD_10#sh inventory
NAME: "1", DESCR: "WS-C3750-48TS"
PID: WS-C3750-48TS-S , VID: V05 , SN: CAT1039ZH3L
NAME: "GigabitEthernet1/0/1", DESCR: "1000BaseBX10-U SFP"
PID: Unspecified , VID: , SN: 1311163107
NAME: "GigabitEthernet1/0/2", DESCR: "1000BaseBX10-D SFP"
PID: Unspecified , VID: , SN: 1311165517
NAME: "GigabitEthernet1/0/3", DESCR: "1000BaseBX10-D SFP"
PID: Unspecified , VID: , SN: 1311165516
NAME: "GigabitEthernet1/0/4", DESCR: "1000BaseBX10-U SFP"
PID: Unspecified , VID: , SN: 1311163106
sh int cap : FastEthernet1/0/17
Model: WS-C3750-48TS
Type: 10/100BaseTX
Speed: 10,100,auto
Duplex: half,full,auto
Trunk encap. type: 802.1Q,ISL
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(4q3t) (3t: Two configurable values and one fixed.)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
# sh int fa1/0/17
FastEthernet1/0/17 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0019.56dc.1f13 (bia 0019.56dc.1f13)
Description: unit-1107
MTU 1546 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 11w5d, output 00:00:01, output hang never
Last clearing of "show interface" counters 01:04:03
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1123
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4000 bits/sec, 5 packets/sec
5 minute output rate 13000 bits/sec, 4 packets/sec
43291 packets input, 8819123 bytes, 0 no buffer
Received 12 broadcasts (5 multicasts)
0 watchdog, 5 multicast, 0 pause input
41513 packets output, 29184901 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Thank you.
