Shiv.AD
We are working on a spare switch (with 12 fibre modules), which needs to be used as the failover switch in our company data centre.
Cisco switch model : WS-C3750-12S(PowerPC405)
Can you confirm the below :
i. Does this switch support BGP protocol?
ii. Is this switch out of warranty? Can you share the cisco page weblink where I can check the End of Life details for this switch?
As per the below link that I could find, it appears that this switch has reached its End of Life :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-series-switches/eol_c51-696372.html
How can we work on a support agreement with Cisco to have general production support till we replace this one with a permanent switch which is new?
iii. What is the correct SFP module that can be used on the 12 fibre ports that this switch possesses? Can you share the exact SFP module that I need to purchase inorder to ensure the hardware compatibility is taken care?
Shiv
3 Comments
Leo Laohoo
3750G-12S does not support BGP Protocol.
This particular model is way past end-of-support.
Shiv.AD
Thanks @Leo Laohoo very much appreciate your response. Could you confirm your input after reviewing the below show version output which I got after consoling in???
Cisco3750Spare#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 23-Jul-12 13:22 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
Cisco3750Spare uptime is 9 minutes
System image file is "flash:c3750-ipservicesk9-mz.122-55.SE6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-12S (PowerPC405) processor (revision X0) with 131072K bytes of memory.
Processor board ID FDO1642X09P
Last reset from power-on
1 Virtual Ethernet interface
12 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 30:37:A6:78:EB:00
Motherboard assembly number     : 73-9678-12
Power supply part number        : 341-0048-03
Motherboard serial number       : FDO14050NS9
Power supply serial number      : LIT14010AXJ
Model revision number           : X0
Motherboard revision number     : A0
Model number                    : WS-C3750G-12S-S
System serial number            : FDO1642X09P
Top Assembly Part Number        : 800-26634-10
Top Assembly Revision Number    : A0
Version ID                      : V12
CLEI Code Number                : COMX410ARB
Hardware Board Revision Number  : 0x06
Switch Ports Model              SW Version            SW Image
*    2 12    WS-C3750G-12S      12.2(55)SE6           C3750-IPSERVICESK9-M
Configuration register is 0xF
Leo Laohoo
Same thing.
The 3750G-12S does not have enough flash space to support BGP routing table.
