Let's talk about different flavours of VWIC cards today .  When it comes about VWIC, he 1st things comes into my mind is,
1.What is V in VWIC?
2.Why there are different names VWIC, VWIC2 and VWIC3...? What is 1MFT,2MFT?  What is difference between VWIC-2MFT-T1  and
VWIC-2MFT-T1/E1???
V in VWIC signifies VOICE..Wan interface cards .it says "VWIC Cards enable customers to leverage voice over T1 and E1 service"
It's a combination voice and wireless interface card.
Why to go for a wireless interface card right? A  VIC does the same thing, but for a telephone.
VWIC  would be used on a  large corporate network instead of just for regular telephone  exchange.
Different VWIC card models mentioned in Table 1. Cisco VWIC2 and VWIC3 Interface Cards
Part Number
Description
VWIC3-1MFT-T1/E1
1-Port 3rd Gen Multiflex Trunk Voice/WAN Int. Card-T1/E1
VWIC3-2MFT-T1/E1
2-Port 3rd Gen Multiflex Trunk Voice/WAN Int. Card-T1/E1
VWIC3-1MFT-G703
1-Port 3rd Gen Multiflex Trunk Voice/WAN Int. Card-G.703
VWIC3-2MFT-G703
2-Port 3rd Gen Multiflex Trunk Voice/WAN Int. Card-G.703
VWIC3-4MFT-T1/E1
4-Port 3rd Gen Multiflex Trunk Voice/WAN Int. Card-T1/E1
VWIC2-1MFT-T1/E1
1-Port 2nd Gen Multiflex Trunk Voice/WAN Int. Card-T1/E1
VWIC2-2MFT-T1/E1
2-Port 2nd Gen Multiflex Trunk Voice/WAN Int. Card-T1/E1
VWIC2-1MFT-G703
1-Port 2nd Gen Multiflex Trunk Voice/WAN Int. Card-G.703
VWIC2-2MFT-G703
2-Port 2nd Gen Multiflex Trunk Voice/WAN Int. Card-G.703
Difference in terms of features and operations,
VWIC generation 1:
1. VWIC Geneartion1 card supports either T1 or E1 but one cannot  use it for dual controller purpose.
2.Cisco 2 port VWIC Geneartion1 card does not give an option to take clock source independently for each port. "clock source line independent"
is not supported.
controller t1 0/0/0
framing esf
linecode b8zs
channel-group 1 timeslots 1-24 speed 64
clock source line independent <<<<<<  Not allowed
controller t1 0/1/0
framing esf
linecode b8zs
Since independent clock sourcing is not supported, circuit will always be sustainable to clocking Slip sec errors when ever 2 ports are being used for data/Voice applications.Most of the customer came up with this issue and CISCO came up with  Generation2   card which address the major independent clocking issue,
VWIC generation 2:
The Cisco 2-port VWIC2 cards can enable each port  to be clocked from independent clock sources for data applications. This  independent clocking capability is not supported for voice applications  or with the Cisco ATM/Voice Advanced Integration Modules (part numbers  AIM-ATM, AIM-VOICE-30, and AIM-ATM-VOICE-30).
controller t1 0/0/0
framing esf
linecode b8zs
clock source line independent <<<<<<   allowed
controller t1 0/1/0
framing esf
linecode b8zs
However Customers started facing another issue when they use VWIC2
2 ports for both voice and data, they c
an't use Independent clock source.
controller t1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 speed 64
controller t1 0/1/0
framing esf
linecode b8zs
In this case , Cu comes with same issue,  getting Slip sec errors, clocking errors.  Earlier Cisco use to suggest,  As a design perspective better use 2 ports for data only and  use another card for voice , not to get slip errors. In order to support independent clocking for both "Data " and "voice"  on same card Generation 3 card has come into picture.
VWIC generation 3:
The  Cisco VWIC3 cards are supported only on the Cisco Integrated Services  Router (ISR) 1900, 2900, 3900 and 3900E series platforms.
The VWIC3 cards add enhancements to the previous generation VWIC2 cards,  including: Enhanced clocking capabilities:  The Cisco VWIC3 cards can enable each port to be clocked from an  independent clock source for data applications. Data ports can also be  clocked independent of voice ports. All voice ports on the card much use  the same clock source.Multiple data channel-groups supported per T1/E1 port
controller t1 0/0/0
framing esf
linecode b8zs
controller t1 0/1/0
framing esf
linecode b8zs
Thus VWIC3 eliminates the clocking issue compeletely.
Now it's time for you to choose which Generation card you would like to
go for your network?
VWIC
VWIC2
VWIC3?
Hope it helps.
Jyoti
2 Comments
danalvar
Jyoti,
The last section for the VWIC3 card is not accurate. Independent source clocking works for data T1s only, not for voice. So it should look something like this for the VWIC3 cards:
controller t1 0/0/0
controller t1 0/0/0
clock source line independent <<<<<< Allowed
Cisco Third-Generation 1-, 2-, and 4-Port T1/E1 Multiflex Trunk Voice/WAN Interface Cards
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/data_sheet_c36-609138.html
For Voice configuration with the VWIC cards, there's a known limitation to use a single clocking source per clocking domain.
Just to be completely certain that these new cards do not avoid/resolve this limitation for VWIC cards when using Voice, I went ahead an ran a quick lab test.
Once you enter the "clock source line/internal independent" command under the controller, you can't configure a PRI group.
VWIC3-TEST-ROUTER#
VWIC3-TEST-ROUTER#show diag | sec VWIC3
       VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
       Product (FRU) Number     : VWIC3-2MFT-T1/E1
VWIC3-TEST-ROUTER#show ver | sec flash:
System image file is "flash:c3900-universalk9-mz.SPA.151-3.T1.bin"
VWIC3-TEST-ROUTER#show run | sec controller
controller T1 0/0/0
cablelength long 0db
controller T1 0/0/1
VWIC3-TEST-ROUTER#show run | sec network
network-clock-participate wic 0
VWIC3-TEST-ROUTER#
VWIC3-TEST-ROUTER#
VWIC3-TEST-ROUTER#conf t
Enter configuration commands, one per line. End with CNTL/Z.
VWIC3-TEST-ROUTER(config)#controller t1 0/0/0
VWIC3-TEST-ROUTER(config-controller)#clock source line independent
VWIC3-TEST-ROUTER(config-controller)#pri-group timeslots 1-24
% Invalid input detected at '^' marker.
VWIC3-TEST-ROUTER(config-controller)#no clock source line independent
VWIC3-TEST-ROUTER(config-controller)#do show run | sec controller
controller T1 0/0/0
controller T1 0/0/1
Best regards,
Danny.
rickycheung2009
professional
