X25 configuration , verification and debugging
1660
Contributor
X25 is definitely old and legacy, but still there are people out there who use it and there are ISP out there who support it, when I started looking for more docs on X25 I could not find much, so I decided to create one myself.
TOPOLOGY
router-2800-2 --Serial1/0----------------------------------Serial2/0--X25-switch-2900-4--s0/1/0:1-----------------------------------------s0/3/0:1---router-2800-3
CONFIGURATION
2800-2#sh run int s1/0
interface Serial1/0
ip address 10.1.1.1 255.255.255.0
encapsulation x25
x25 address 1234
x25 map ip 10.1.1.2 5678 broadcast
dsu bandwidth 44210
end
2800-3#sh run int s0/3/0:1
interface Serial0/3/0:1
ip address 10.1.1.2 255.255.255.0
encapsulation x25
x25 address 5678
x25 map ip 10.1.1.1 1234 broadcast
end
2900-4#conf t
2900-4#x25 routing
2900-4#x25 route 1234 interface Serial2/0
2900-4#x25 route 5678 interface Serial0/1/0:1
2900-4#sh run int s2/0
interface Serial2/0
no ip address
encapsulation x25 dce
dsu bandwidth 44210
end
2900-4#sh run int s0/1/0:1
no ip address
VERIFICATION
2900-4#sh x25 route
# Match                         Substitute         Route to     match/use
1 dest 1234                                         Serial2/0               0/0
2 dest 5678                                         Serial01/0:1         1/1
2800-2#sh x25 vc
SVC 1024, State: D1, Interface: Serial1/0
Started 00:10:07, last input 00:10:02, output 00:10:02
Connects 5678 <-> ip 10.1.1.2
Call PID cisco, Data PID none
Window size input: 2, output: 2
Packet size input: 128, output: 128
PS: 6 PR: 6 ACK: 5 Remote PR: 6 RCNT: 1 RNR: no
P/D state timeouts: 0 timer (secs): 0
data bytes 3000/3000 packets 30/30 Resets 0/0 RNRs 0/0 REJs 0/0 INTs 0/0
2800-2#ping 10.1.1.2
Sending 5, 100-byte ICMP Echos to 10.1.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/4/8 ms
2800-2#sh int s1/0
Serial1/0 is up, line protocol is up
Hardware is DSXPNM Serial
Internet address is 10.1.1.1/24
MTU 4470 bytes, BW 44210 Kbit/sec, DLY 200 usec,
Encapsulation X25, crc 16, loopback not set
Keepalive set (10 sec)
X.25 DTE, version 1984, address 1234, state R1, modulo 8, timer 0
     Defaults: idle VC timeout 0
       cisco encapsulation
     RESTARTs 0/0 CALLs 1+3/0+0/0+0 DIAGs 0/0
LAPB DTE, state CONNECT, modulo 8, k 7, N1 35816, N2 20
2800-2#sh x25 map
Serial1/0: X.121 5678 <-> ip 10.1.1.2
permanent, broadcast, 1 VC: 1024
“debug x25 packet” on 2900-2 while ping 10.1.1.2 from 2800-2 , packets being sent out (O) and received in (I)
2900-4#debug x25I
X.25 packet debugging is on
2900-4#
*May 27 02:17:02.946: Serial2/0: X.25 I D1 Data (103) 8 lci 1024 PS 3 PR 3
*May 27 02:17:02.946: Serial0/1/0:1: X.25 O D1 Data (103) 8 lci 1 PS 3 PR 3
*May 27 02:17:02.950: Serial0/1/0:1: X.25 I D1 Data (103) 8 lci 1 PS 3 PR 4
*May 27 02:17:02.950: Serial2/0: X.25 O D1 Data (103) 8 lci 1024 PS 3 PR 4
*May 27 02:17:02.950: Serial2/0: X.25 I D1 Data (103) 8 lci 1024 PS 4 PR 4
*May 27 02:17:02.950: Serial0/1/0:1: X.25 O D1 Data (103) 8 lci 1 PS 4 PR 4
*May 27 02:17:02.954: Serial0/1/0:1: X.25 I D1 Data (103) 8 lci 1 PS 4 PR 5
*May 27 02:17:02.954: Serial2/0: X.25 O D1 Data (103) 8 lci 1024 PS 4 PR 5
*May 27 02:17:02.954: Serial2/0: X.25 I D1 Data (103) 8 lci 1024 PS 5 PR 5
*May 27 02:17:02.954: Serial0/1/0:1: X.25 O D1 Data (103) 8 lci 1 PS 5 PR 5
*May 27 02:17:02.958: Serial0/1/0:1: X.25 I D1 Data (103) 8 lci 1 PS 5 PR 6
*May 27 02:17:02.958: Serial2/0: X.25 O D1 Data (103) 8 lci 1024 PS 5 PR 6
*May 27 02:17:02.958: Serial2/0: X.25 I D1 Data (103) 8 lci 1024 PS 6 PR 6
*May 27 02:17:02.958: Serial0/1/0:1: X.25 O D1 Data (103) 8 lci 1 PS 6 PR 6
*May 27 02:17:02.962: Serial0/1/0:1: X.25 I D1 Data (103) 8 lci 1 PS 6 PR 7
*May 27 02:17:02.962: Serial2/0: X.25 O D1 Data (103) 8 lci 1024 PS 6 PR 7
*May 27 02:17:02.962: Serial2/0: X.25 I D1 Data (103) 8 lci 1024 PS 7 PR 7
*May 27 02:17:02.962: Serial0/1/0:1: X.25 O D1 Data (103) 8 lci 1 PS 7 PR 7
*May 27 02:17:02.966: Serial0/1/0:1: X.25 I D1 Data (103) 8 lci 1 PS 7 PR 0
*May 27 02:17:02.966: Serial2/0: X.25 O D1 Data (103) 8 lci 1024 PS 7 PR 0
“debug x25 events” on 2900-2 while shut and no shut on int s1/0 on 2800-2 , look for cause code.
2900-4#
*May 27 02:19:42.314: Serial2/0: X.25 O R/Inactive Restart (5) 8 lci 0
*May 27 02:19:42.314:  Cause 7, Diag 0 (Network operational/No additional information)
*May 27 02:19:42.314: Serial2/0: X.25 I R3 Restart (5) 8 lci 0
*May 27 02:19:42.314:   Cause 0, Diag 0 (DTE originated/No additional information)
X25 over tcp coming soon ....... keep checking.....
Content for Community-Ad
