4500X-32 IOS upgrade procedure
7740
  • Assumptions/requirement
ROMMON version should be SG4 or above. In this case it was  ROM: 15.0(1r)SG10
1.Copy IOS image to bootflash:
2.Check the IOS copy
SWITCH4500X-32#dir
Directory of bootflash:/
79202  -rw-   126060564  Jul 24 2014 14:11:25 -05:00  cat4500e-universalk9.SPA.03.04.04.SG.151-2.SG4.bin
79203  -rw-   178257396   Dec 9 2015 04:35:32 -06:00  cat4500e-universalk9.SPA.03.06.03.E.152-2.E3.bin
1659666432 bytes total (1354903552 bytes free)
3.Check the current boot statement
SWITCH4500X-32#sh run | in boot
boot-start-marker
boot system flash bootflash:cat4500e-universalk9.SPA.03.04.04.SG.151-2.SG4.bin
boot-end-marker
4.Check boot variables as well
SWITCH4500X-32#show bootvar
BOOT variable = bootflash:cat4500e-universalk9.SPA.03.04.04.SG.151-2.SG4.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Configuration register is 0x2101
5. Change the Boot statement to new IOS
SWITCH4500X-32#config t
Enter configuration commands, one per line.  End with CNTL/Z.
SWITCH4500X-32(config)#boot system flash bootflash:cat4500e-universalk9.SPA.03.06.03.E.152-2.E3.bin
6. Save the change
SWITCH4500X-32(config)#do wr
Building configuration...
Compressed configuration from 15475 bytes to 6699 bytes[OK]
7.Check the boot statement
SWITCH4500X-32(config)#do sh run | in boot
boot-start-marker
boot-end-marker
8. Remove the old bootstatement
SWITCH4500X-32(config)#no boot system flash bootflash:cat4500e-universalk9.SPA.03.04.04.SG.151-2.SG4.bin
9.Check the boot statement
boot-start-marker
boot-end-marker
10. Save the changes and check the bootvar
Compressed configuration from 15396 bytes to 6660 bytes[OK]
SWITCH4500X-32(config)#do show bootvar
BOOT variable = bootflash:cat4500e-universalk9.SPA.03.06.03.E.152-2.E3.bin,1;
11. Change the config-register to 0X2102 & Save the changes
SWITCH4500X-32(config)#config-register 0X2102
Compressed configuration from 15396 bytes to 6652 bytes[OK]
12. Check the bootvar
Configuration register is 0x2101 (will be 0x2102 at next reload)
13. Reload the switch
SWITCH4500X-32#reload
Proceed with reload? [confirm]
Contributor
Hi Butturwa,
Nice writting !!
Question, if i want to upgrade ROMMON and IOS in C4500X VSS, what is the proper step?
Start from upgrading passive unit ROMMON, then manually promote this unit become active after restart.
Same action apply to the next unit.
Can i upload both ROMMON and IOS into box, set the path and reboot? (shortcut one step)
Noel
