887VA - cant get ACLs to work.
276
Question
I have configured a 887VA router but I cant get the ACL to work. What I want is to let anything out to the Internet and nothing in from Internet. The ACL I have permits ping out to internet but nothing else and when I add ex. https to the ACL I noticed that it also opened up for https traffic from Internet to the routers public IP.... Any help would be appreciated.
Here is the config:
version 15.7
no service pad
service password-encryption
hostname adslrouter
ip domain name localdomain
ip cef
no ipv6 cef
username xxxxx
controller VDSL 0
bridge irb
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
interface ATM0.35 point-to-point
description PrimaryWAN
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 1
pvc 8/35
tx-ring-limit 2
encapsulation aal5snap
interface FastEthernet0
description InsideInterface
switchport access vlan 301
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
no ip address
interface Vlan100
description LAN inside interface
ip address dhcp
ip nat inside
ip virtual-reassembly in
interface Vlan301
description IoT Interface
ip address 192.168.1.2 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
hold-queue 100 out
interface BVI1
ip address dhcp
ip access-group IPFW-ACL in
ip nat outside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list NAT-ACL interface BVI1 overload
ip route 0.0.0.0 0.0.0.0 dhcp
ip access-list standard VTY-ACL
permit 192.168.1.0 0.0.0.255
ip access-list extended IPFW-ACL
permit icmp any any administratively-prohibited
permit icmp any any echo-reply
permit icmp any any packet-too-big
permit icmp any any time-exceeded
permit icmp any any traceroute
permit udp 90.xxx.xxx.0 0.0.0.255 any log
deny ip any any log
ip access-list extended NAT-ACL
permit ip 192.168.1.0 0.0.0.255 any
ipv6 ioam timestamp
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
access-class VTY-ACL in
login local
transport input ssh
ntp server 192.168.1.50 source Vlan301
end
Hi @Jiess,
Looking at the configuration, your Router is doing NAT (more specifically PAT) which is inherently already doing what you are asking. This is, traffic generated from a host in your LAN side ingresses the Router's LAN interface (interface Vlan100 or interface Vlan301) and egresses the WAN interface (interface BVI1) towards the Internet. These traffic flows are recorded in the NAT stateful table (show ip nat translations). For the return traffic, this NAT stateful table allows the traffic to be translated back to your original private IP in the LAN side.
On the other hand, traffic generated from the Internet can only reach your WAN IP since you mentioned it is a Public IP. This traffic cannot directly hit a host in the LAN side unless you explicitly configure a Static NAT translation to do so.
Going back to your original question, ACLs are stateless rules. This means you need to allow the traffic in both directions (in and out)
With your current configuration, you are blocking ALL traffic coming to your Router's WAN interface with the exception of UDP traffic sourced from 90.xxx.xxx.0.
Likely, hosts in the LAN side of your Router generating traffic cannot receive responses due to this.
HTHs
Beginner
Hello and thank you for your answer!
""For the return traffic, this NAT stateful table allows the traffic to be translated back to your original private IP in the LAN side.""
* Yes, this works using ICMP but no other protocol. I added a line for https to the ACL but that also opened up for https to the Routers WAN IP for traffic initiated from Internet, so I must be doing something wrong.
What do I need to do to allow any LAN-side generated traffic also to receive responses without opening up for traffic to the Router WAN IP initiated from Internet?
Thanks.
Regards, Jiess
Beginner
Hi!
I found this excellent short article that explained what i needed to do to get it to work: https://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/firewall.html
Case closed.
Thanks @Hector Gustavo Serrano Gutierrez  for your input.
Jiess
Thanks for the feedback @Jiess,
You may also consider Cisco Zone-Based Firewall (ZBF)
Zone-Based Policy Firewall Design and Application Guide
For instance:
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
class-map type inspect match-all all-private match access-group 101 ! policy-map type inspect priv-pub-pmap class type inspect all-private inspect class class-default ! zone security private zone security public zone-pair security priv-pub source private destination public service-policy type inspect priv-pub-pmap ! interface BVI1 ip address 172.16.108.44 255.255.255.0 zone-member security public ! interface Vlan301 zone-member security private !
There are different approaches to accomplish stateful packet inspection in Cisco IOS.
Ordered from oldest (least recommended) to newest (recommended):
1) Add the established keyword at the end of the ACL permit TCP statement. This option is not available for UDP nor ICMP traffic types. The parameter indicates the Router to allow TCP packets based on whether the ACK or RST bits are set. Set ACK or RST bits indicate that the packet is not the first in the session, and therefore, that the packet belongs to an established session.
2) Reflexive Access Lists
A reflexive access list is triggered when a new IP upper-layer session (such as TCP or UDP) is initiated from inside your network, with a packet traveling to the external network. When triggered, the reflexive access list generates a new, temporary entry. This entry will permit traffic to enter your network if the traffic is part of the session, but will not permit traffic to enter your network if the traffic is not part of the session.
3) Cisco IOS Firewall
This is the option that worked fine for you.
4) Cisco Zone-Based Firewall (ZBF)
Reassembles more to a usual Firewall since you can separate different interfaces into Zones.
Regards.
Beginner
Thank you @Hector Gustavo Serrano Gutierrez for your input, much appreciated!
