A Catalyst 6500 switch that runs Cisco IOS system software crashes, and the %C6KERRDETECT-SP-2-LPBKFAIL: error message appears
744
Core issue
The error message looks similar to this:
%C6KERRDETECT-2-LPBKFAIL: The in-band loopback test between switch processor and route processor failed, count:[dec]
This indicates that the system detected an unrecoverable in-band loopback test error. [dec] is the number of times that the system detected the failure.
The system continuously monitors the communication between the route processor (RP) and the switch processor (SP) on a given supervisor. If ten consecutive pings are missed between the RP and the SP, it is noted that there is some problem in the communication between them, and the switchover is initiated, if a redundant supervisor is available.
The communication between the RP and the SP can be broken for many reasons, sometimes it is a transient issue.
Resolution
Open a case with Cisco Technical Support with the TAC Service Request Tool for more assistance and support.
Content for Community-Ad
