ashirkar
Level 7
Level 7
Introduction:
This document created from discussion, in this discussion user is looking for EEM script that will generate syslog Message and send mail alert when IP SLA Tracking condition goes down.
In this document, I will show you how to configure a simple EEM script sending mail when IP SLA track goes down.This script can be used in various scenarios like if you want a track specific routes which is flapping frequently in your network and want to have email alerts as soon as it goes unreachable.
Topology Diagram:
R1 and R2 are directly connected and running OSPF as IGP between them. All interfaces configured as per diagram.
On R1, we will be tracking R2's Loopback IP address 192.168.1.2 using IP SLA and create EEM Applet script so that if track on R1 goes down it will send email alerts.
Basic Configuration:-
R1R2
hostname R1
ip cef
interface Loopback0
ip address 192.168.1.1 255.255.255.255
ip ospf 100 area 0
interface FastEthernet1/0
ip address 10.1.1.1 255.255.255.252
ip ospf 100 area 0
speed auto
duplex auto
interface FastEthernet1/1
ip address 1.1.1.1 255.255.255.252
ip ospf 100 area 0
speed auto
duplex auto
router ospf 100
hostname R2
ip cef
interface Loopback0
ip address 192.168.1.2 255.255.255.255
ip ospf 100 area 0
interface FastEthernet0/0
ip address 10.1.1.2 255.255.255.252
ip ospf 100 area 0
duplex auto
speed auto
router ospf 100
IP SLA config and EEM script:
R1(config)#ip sla 1
R1(config-ip-sla)# icmp-echo 192.168.1.2
R1(config-ip-sla-echo)# frequency 5
R1(config-ip-sla-echo)#exit
R1(config)#ip sla schedule 1 life forever start-time now
R1(config)#
R1(config)#track 1 ip sla 1 reachability
R1(config-track)#delay down 2 up 2
R1(config-track)#exit
event manager applet track_SLA_1
event track 1 state down
action 1.0 syslog msg "IPSLA collector 1 timed out"
action 2.0 mail from "user@example.com" to "user@example.com" subject "IPSLA Collector 1is down" body "IPSLA Collector 1 has timed out" server "1.1.1.2"
Verification:
1) Let’s verify track: track is up now
R1#sh track 1
Track 1
  IP SLA 1 reachability
  Reachability is Up
    5 changes, last change 00:00:25
  Delay up 2 secs, down 2 secs
  Latest operation return code: OK
  Latest RTT (millisecs) 76
  Tracked by:
    EEM applet track_SLA_1
To trigger EEM script our track should go down. Removing OSPF advertisement from R2 and also turning dubug to verify on R1.
R2#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R2(config)#int lo 0
R2(config-if)#no ip ospf 100 area 0
R2(config-if)#end
R2#
R1#debug event manager action cli
Debug EEM action cli debugging is on
R1#
*Sep 30 03:26:24.686: %TRACKING-5-STATE: 1 ip sla 1 reachability Up->Down
R1#
*Sep 30 03:26:24.762: %HA_EM-6-LOG: track_SLA_1: IPSLA collector 1 timed out
R1#
*Sep 30 03:26:45.794: %HA_EM-3-FMPD_SMTP: Error occurred when sending mail to SMTP server: 1.1.1.2 : timeout error
R1#
As you can see while sending, I’m getting error because, I don’t have SMTP server but if you have it will work for you.
roger perkin
Level 2
Level 2
Ashish,
This is great, however I tried to implement it on a 3750 switch and did not have the option in the EEM applet for
event track?
Is there another way on the 3750 to do this?
Many Thanks
Roger
http://www.rogerperkin.co.uk/ccie
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
