I've been tasked with looking at a network of twelve 48 port switches, the first thing i've found is someone has been implimenting bandwidth settings on a lot of the ports. I'd really rather avoid factory resetting the switches to sweep away the bandwith limits.
Is there an efficient way of enumerating the network ports across all the switches and removing all the bandwidth limits that have been put in place? its a lot of work to visit each switch and every port to remove limits otherwise.
Answer
