BGP Basic Configuration On IOS XR - IBGP And EBGP
17682
Introduction:
In this document we will see basic BGP configuration on IOS XR. We will configure IPv4 IBGP and EBGP neighbors.
Configuration Example:
In below topology PE1 and PE2 is running Cisco IOS XR and CE1 is running Cisco IOS. We will be having IBGP neighborship between PE1 and PE2.PE2 and CE1 will have EBGP neighborship and we are advertising Loopback address of devices through BGP.IP address are preconfigured as shown in the diagram.
In IOS XR, BGP configure under “router bgp” process similar like in cisco IOS. There are some changes in the command structure of IOS XR than Cisco IOS but your entire fundamental remain same.
In IOS XR there is no concept of default address family. An address family must be explicitly configured under the BGP router configuration for the address family to be activated in BGP.
Similarly, an address family must be explicitly configured under a neighbor for the BGP session to be activated under that address family.
Let’s start with  IBGP neighborship configuration between PE1 and PE2.BGP must be able to obtain a router identifier (for example, a configured loopback address).
PE1:
RP/0/0/CPU0:PE1(config)#router bgp 1
RP/0/0/CPU0:PE1(config-bgp)#bgp router-id 10.1.1.1
RP/0/0/CPU0:PE1(config-bgp)#address-family ipv4 unicast
RP/0/0/CPU0:PE1(config-bgp-af)#exit
RP/0/0/CPU0:PE1(config-bgp)#nei 10.1.1.2
RP/0/0/CPU0:PE1(config-bgp-nbr)#remote-as 1
RP/0/0/CPU0:PE1(config-bgp-nbr)#address-family ipv4 unicast
RP/0/0/CPU0:PE1(config-bgp-nbr-af)#commit
Wed May 8 19:53:51.101 UTC
RP/0/0/CPU0:PE1(config-bgp-nbr-af)#end
RP/0/0/CPU0:PE1#
PE2:
RP/0/0/CPU0:PE2(config)#router bgp 1
RP/0/0/CPU0:PE2(config-bgp)#bgp router-id 10.1.1.2
RP/0/0/CPU0:PE2(config-bgp)#address-family ipv4 unicast
RP/0/0/CPU0:PE2(config-bgp-af)#exit
RP/0/0/CPU0:PE2(config-bgp)#neighbor 10.1.1.1
RP/0/0/CPU0:PE2(config-bgp-nbr)#remote-as 1
RP/0/0/CPU0:PE2(config-bgp-nbr)#address-family ipv4 unicast
RP/0/0/CPU0:PE2(config-bgp-nbr-af)#commit
Wed May 8 19:53:29.583 UTC
RP/0/0/CPU0:PE2(config-bgp-nbr-af)#end
Now to verify the BGP configuration on IOS XR you have to use "sh run router bgp" command.
RP/0/0/CPU0:PE1#sh run router bgp
Wed May 8 19:59:09.089 UTC
router bgp 1
neighbor 10.1.1.2
remote-as 1
RP/0/0/CPU0:PE1#
RP/0/0/CPU0:PE2#sh run router bgp
Wed May 8 20:00:06.285 UTC
router bgp 1
neighbor 10.1.1.1
remote-as 1
RP/0/0/CPU0:PE2#
Verifying BGP neighborship on PE1:
RP/0/0/CPU0:PE1#sh bgp ipv4 unicast summary | beg Nei
Wed May 8 20:30:28.280 UTC
Neighbor       Spk   AS MsgRcvd MsgSent   TblVer InQ OutQ Up/Down St/PfxRcd
10.1.1.2         0     1       4     40       3   0   0 00:01:23         0
Now let’s advertise loopback address of PEs in BGP. In IOS XR you have to configure "Network" command under address-family as shown below.
RP/0/0/CPU0:PE1(config-if)#router bgp 1
RP/0/0/CPU0:PE1(config-bgp-af)#net 192.168.1.1/32
RP/0/0/CPU0:PE1(config-bgp-af)#commit
Wed May 8 20:11:18.169 UTC
RP/0/0/CPU0:PE1(config-bgp-af)#end
RP/0/0/CPU0:PE1#
RP/0/0/CPU0:PE2(config-bgp-af)#network 192.168.1.2/32
RP/0/0/CPU0:PE2(config-bgp-af)#commit
Wed May 8 20:32:54.981 UTC
RP/0/0/CPU0:PE2(config-bgp-af)#end
RP/0/0/CPU0:PE2#
Verify Advertise prefixes on PE1 and PE2:
RP/0/0/CPU0:PE1#sh bgp | beg Net
Wed May 8 20:33:30.668 UTC
   Network           Next Hop           Metric LocPrf Weight Path
*> 192.168.1.1/32     0.0.0.0                 0         32768 i
*>i192.168.1.2/32     10.1.1.2                0   100     0   i
Processed 2 prefixes, 2 paths
RP/0/0/CPU0:PE1#
RP/0/0/CPU0:PE2#sh bgp | beg Net
Wed May 8 20:35:59.838 UTC
             i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
*>i192.168.1.1/32     10.1.1.1               0   100     0   i
*> 192.168.1.2/32     0.0.0.0                0         32768 i
RP/0/0/CPU0:PE2#
Verify routing table of PE1 and loopback reachability:
RP/0/0/CPU0:PE1#sh route bgp
Wed May 8 20:36:42.565 UTC
B   192.168.1.2/32 [200/0] via 10.1.1.2, 00:03:35
RP/0/0/CPU0:PE1#
RP/0/0/CPU0:PE1#ping 192.168.1.2 so 192.168.1.1
Wed May 8 20:37:13.562 UTC
Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 9/13/19 ms
RP/0/0/CPU0:PE1#
Now we will configure EBGP neighborship between PE2 and CE1, commands are same as configure before.
PE2:
RP/0/0/CPU0:PE2(config-bgp)#nei 10.2.2.2
RP/0/0/CPU0:PE2(config-bgp-nbr)#remote-as 2
Wed May 8 20:56:06.685 UTC
RP/0/0/CPU0:PE2#
CE1 configuration:
conf t
router bgp 2
nei 10.2.2.1 remote-as 1
net 172.16.1.1 mask 255.255.255.255
end
Now let's verify EBGP neighborship:
RP/0/0/CPU0:PE2#sh bgp sum | beg Nei
Wed May 8 21:04:50.129 UTC
10.1.1.1         0     1     38     38      4   0   0 00:34:57         1
10.2.2.2         0     2     43     43      4   0   0 00:02:22         0 !
You can see PE2 have formed EBGP neighborship with CE1 but not receiving any prefixes advertise by CE1 also not sending any to CE1.The reason behind this is, In IOS XR External BGP (eBGP) neighbors must have an inbound and outbound policy configured. If no policy is configured, no routes are accepted from the neighbor, nor are any routes advertised to it. This added security measure ensures that routes cannot accidentally be accepted or advertised in the case of a configuration omission error.
These neighbors will default to sending and/or receiving no routes and are marked with '!' in the output above. Use the "show bgp neighbor 10.2.2.2 | beg policy" command for details.
RP/0/0/CPU0:PE2#sh bgp neighbor 10.2.2.2 | in policy
Wed May 8 21:30:41.733 UTC
eBGP neighbor with no inbound or outbound policy; defaults to 'drop'
RP/0/0/CPU0:PE2#
Instead of a route-map like IOS, IOS XR uses a Route Policy Language (RPL) – that is more powerful and easier than IOS. Let’s configure a very simple one RPL to pass everything and apply that to the EBGP neighbor:
RP/0/0/CPU0:PE2#conf t
Wed May 8 21:31:45.759 UTC
RP/0/0/CPU0:PE2(config)#route-policy pass_all
RP/0/0/CPU0:PE2(config-rpl)#pass
RP/0/0/CPU0:PE2(config-rpl)#exit
RP/0/0/CPU0:PE2(config-bgp-nbr-af)#route-policy pass_all in
RP/0/0/CPU0:PE2(config-bgp-nbr-af)#route-policy pass_all out
Wed May 8 21:34:05.039 UTC
RP/0/0/CPU0:PE2#
From below output you can see PE2 learned prefixes from CE1:
Wed May 8 21:39:13.638 UTC
* i172.16.1.1/32     10.2.2.2                 0   100    0  2 i
Processed 3 prefixes, 3 paths
RP/0/0/CPU0:PE1#
PE2 learn prefix 172.16.1.1/32 by CE1 will advertise to PE1 with next-hop IP address of CE1 i.e.10.2.2.2. As we are not using any underline IGP, PE1 will not have 10.2.2.0/30 reachability, hence PE2 will not put this prefix in its routing table so we need to configure “next-hop-self” command on PE2 for all advertise prefixes to PE1.
RP/0/0/CPU0:PE2(config-bgp)#nei 10.1.1.1
RP/0/0/CPU0:PE2(config-bgp-nbr-af)#next-hop-self
Wed May 8 21:40:23.983 UTC
RP/0/0/CPU0:PE2#
Now let’s verify end to end reachability between PE1 and CE1:
Wed May 8 21:40:25.033 UTC
*>i172.16.1.1/32     10.1.1.2                 0   100    0   2 i
RP/0/0/CPU0:PE1#ping 172.16.1.1 so 192.168.1.1
Wed May 8 21:40:29.292 UTC
Sending 5, 100-byte ICMP Echos to 172.16.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 19/21/29 ms
RP/0/0/CPU0:PE1#
Classic IOS and IOS XR command comparison:
Classic  IOSIOS XR
Conf t
router bgp 65000
no bgp default ipv4-unicast
nei 192.168.1.1 remote-as 65000...(IBGP peer)
nei 192.168.1.1 update-source lo0
nei 10.1.1.1 remote-as 65001...(EBGP peer)
nei 10.1.1.1 ebgp-multihop
nei 192.168.1.1 activate
nei 10.1.1.1 activate
conf t
router bgp  65000
address-family ipv4 unicast..(Activate addres-family)
nei 192.168.1.1
remote-as 65000
update-so lo0
exit
nei 10.1.1.1
remote-as 65001
ebgp-multihop
commit
Related Information:
Implementing BGP on Cisco ASR 9000 Series Router
Beginner
Hy, is there some IOS XR equivalent of following :
vrf data
rd 10000:100
route-target both 10000:100
bgp next-hop loopback100
where loopback 100 is used for MPLS TE traffic routing (per VRF MPLS TE).
In IOS XR there is no possibility to migrate configuration in similar way, so I would like to know is there some by-the-book proposed solution for that ?
thank you
thanks!
Beginner
Hello Ashirkar,
Thanks for your post, I wonder if you could help me, I'm trying to configure BGP in GNS3 with the demo IOS-XR, this is my config:
R1
interface Loopback0
 ipv4 address 10.7.1.1 255.255.255.0
 ipv6 address 2001:db8:10:7:1::1/128
interface GigabitEthernet0/0/0/0
 ipv4 address 192.168.178.70 255.255.255.0
 ipv6 address 2001:db8:192:168:178::70/64
route-policy PASS
pass
exit
router bgp 65001
network 10.7.1.0/24
 neighbor 10.8.1.1
  remote-as 65001
  update-source Loopback0
   route-policy PASS in
   route-policy PASS out
  address-family ipv6 unicast
 neighbor 2001:db8:10:8:1::1
  remote-as 65001
R2
interface Loopback0
 ipv4 address 10.8.1.1 255.255.255.0
 ipv6 address 2001:db8:10:8:1::1/128
 ipv4 address 192.168.178.80 255.255.255.0
 ipv6 address 2001:db8:192:168:178::80/64
route-policy PASS
pass
exit
router bgp 65001
  network 10.8.1.0/24
 neighbor 10.7.1.1
  remote-as 65001
 neighbor 2001:db8:10:7:1::1
  remote-as 65001
It is showing idle on "sh bgp sum", I also ran "debug bgp all" and nothing shows up, also "debug icmp ipv4" and nothing shows up either when pinging.
Ping works, however when I shutdown an interface the other one remains down, but ping drops.
At this stage I believe it's something with my GNS3, however I'd like to know if the above config would work.
Edit: My bad, my routers were not able to reach the loopbacks, I enabled OSPF between the two and BGP worked.
However, BGP did not seem to work when creating static routes. Any ideas why?
Content for Community-Ad
July's Community Spotlight Awards
