I am planning a CAT3560G connected with CAT2960S, where can I find example configurations to config VLANs, OSPF or RIP, trunks ,qos, etc. between the two switchs.
-I had a c9200 device discovered by dna center and it showed a cli authentication error. -tried to delete it from inventory and I checked clean up configuration box. -and then I did a reset the device configuration. -but the device didn't r...
view more
We have a ISR4331 that we use as a voice gateway. Currently it is on version isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin and it works without any problems. After the upgrade it doesn't even initialize the call I ran a kron debug and found ...
view more
i have a 6807 core switch setup as a VSL-Pair. have about 1000 VoIP phones throughout maybe 10-12 access switches. in the last few weeks i have been noticing that people on voice-VL1 having issues with dropped calls and the other f...
view more
Hi It is possible to configure the same network for Service Side NAT pool but in different VPN/VRF? Ex:VPN 1Inside Local : 10.0.100.0/24Inside Global : 192.168.100.0/24 VPN 2Inside Local : 10.0.101.0/24Inside Global : 192.168.100.0/24 ...
view more
Hi Cisco people, I've just inherited a Cisco L2 device running IOS XR 6.6.12. This switch has a bundle connection to another identical switch. I see this subinterface on the switch-to-switch bundle connection in the running c...
view more
