Cisco 1721 - Running IPTV, Multicast, PPPoA Internet (one box!)
2153
Hi, I have a Cisco router that I want to run IPTV and Multicast on. My Service provider passes PPPoA over PVC 0,38.
TV is as such:
Unicast DHCP/VOD = PVC 0,65
Multicast = PVC 0,67
Set Top Box will be on a 10.x.x.x subnet. I aim to setup my PC (data) for 192.168.1.0/24...
Ok, so I know I need to run bridging here and maybe IRB so my config is as such:
bridge irb
interface FastEthernet0
no ip address
ip pim sparse-mode
ip igmp helper-address udl ATM0.2
ip igmp proxy-service
duplex half
bridge-group 1
interface Serial2/0
no ip address
shutdown
serial restart-delay 0
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
atm route-bridged ip
bridge-group 1
pvc 0/65
interface ATM0.2 point-to-point
ip pim sparse-mode
ip igmp unidirectional-link
bridge-group 1
pvc 0/67
ip forward-protocol nd
ip forward-protocol udp bootpc
no ip http server
no ip http secure-server
logging alarm informational
control-plane
bridge 1 protocol ieee
bridge 1 route ip
Can I bridge from one Ethernet port to two differnet ATM PVC's? Will this work ok? Also, how can I setup the Internet? Shall I set the BVI1 to an address in the normal "DHCP" subnet like 192.168.1.0/24 and setup and dialer etc for atm0.3 like:
bridge irb
interface FastEthernet0/0
no ip address
ip pim sparse-mode
ip igmp helper-address udl ATM3/0.2
duplex half
bridge-group 1
interface Serial2/0
no ip address
shutdown
interface Serial2/1
no ip address
shutdown
interface Serial2/2
no ip address
shutdown
interface Serial2/3
no ip address
shutdown
interface ATM3/0
no ip address
interface ATM3/0.1 point-to-point
bridge-group 1
pvc 0/65
interface ATM3/0.2 point-to-point
ip pim sparse-mode
bridge-group 1
pvc 0/67
interface ATM3/0.3 point-to-point
pvc 0/38
  dialer pool-member 1
  protocol ppp dialer
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname <ADSL-Username>_<VPN>
ppp chap password 0 <Password>
ppp timeout idle 2147483
interface BVI1
ip address 192.168.1.254 255.255.255.0
no ip http server
control-plane
bridge 1 route ip
SO therefore allowing DHCP for the stb and bridging it as well as bridging the Multicast to two different VC's and allowing for PPPoA out the same Ethernet...
Can this be done??
Content for Community-Ad
