Shawn Ford
Community Member
Description
The Cisco Catalyst 3560 Series is a line of fixed-configuration, enterprise-class switches that include IEEE 802.3af and Cisco pre-standard Power over Ethernet (PoE) functionality in Fast Ethernet and Gigabit Ethernet configurations. These are ideal access layer switches for small enterprise LAN access or branch-office environments. Combining both 10/100/1000 and PoE configurations for maximum productivity and investment protection, they help you deploy new applications such as IP telephony, wireless access, video surveillance, building management systems, and remote video kiosks.
You can maintain the simplicity of traditional LAN switching and still deploy networkwide intelligent services such as:
  • Advanced quality of service (QoS)
  • Rate limiting
  • Access control lists (ACLs)
  • Multicast management
  • High-performance IP routing
Configurations:
  • Cisco Catalyst 3560-8PC: 8 Ethernet 10/100 ports with PoE and 1 dual purpose 10/100/1000 and small form-factor pluggable (SFP) port; compact form-factor with no fan
  • Cisco Catalyst 3560-24TS: 24 Ethernet 10/100 ports and 2 SFP ports
  • Cisco Catalyst 3560-48TS: 48 Ethernet 10/100 ports and 4 SFP ports
  • Cisco Catalyst 3560-24PS: 24 Ethernet 10/100 ports with PoE and 2 SFP ports
  • Cisco Catalyst 3560-48PS: 48 Ethernet 10/100 ports with PoE and 4 SFP ports
  • Cisco Catalyst 3560G-24TS: 24 Ethernet 10/100/1000 ports and 4 SFP ports
  • Cisco Catalyst 3560G-48TS: 48 Ethernet 10/100/1000 ports and 4 SFP ports
  • Cisco Catalyst 3560G-24PS: 24 Ethernet 10/100/1000 ports with PoE and 4 SFP ports
  • Cisco Catalyst 3560G-48PS: 48 Ethernet 10/100/1000 ports with PoE and 4 SFP ports
The Cisco Catalyst 3560 is available with either the IP Base or IP Services software images and can be upgraded to the Advanced IP Services software image. The IP Base software (formerly called the Standard Multilayer Image or SMI) includes advanced QoS, rate-limiting, ACLs, and basic routing and IPv6 functionality. The IP Services software (formerly called the Enhanced Multilayer Image or EMI) provides a richer set of enterprise-class features, including advanced hardware-based IP unicast and IP Multicast routing as well as policy-based routing (PBR). The Advanced IP Services software includes IPv6 routing and IPv6 ACL support.
Rick Thomas
Another excellent resource for the Cisco 3560 switch http://www.ciscobuy.com/cisco-switches/cisco-3560
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
