Cisco dCloud Lab - Integrated Routing and Bridging (IRB) on the 5921 ESR - c5921_ubuntu32_1 - View
823
This configuration is used with “Introduction to the Cisco 5921 Embedded Services Router v1” in dCloud.
Lines in BOLD ORANGE are changes made to the existing configuration to do the lab exercise.
c5921_ubuntu32_1#sh running-config brief
Building configuration...
Current configuration : 2644 bytes
! Last configuration change at 12:04:19 PST Wed Sep 9 2015
version 15.5
service call-home
hostname c5921_ubuntu32_1
boot-start-marker
boot-end-marker
enable secret 5 $1$x.6O$4UZX1B5lYLF1DeOul7GiV1
enable password cisco
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
clock timezone PST -8 0
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
call-home
! if contact email address in call-home is configured as sch-smart-licensing@cisco.com
! The email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
  active
  destination transport-method http
  no destination transport-method email
ip name-server 8.8.8.8
ip cef
no ipv6 cef
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
license udi pid CISCO5921-K9 sn 91J81443B9I
redundancy
bridge irb
interface Loopback0
ip address 10.0.0.120 255.255.255.255
interface Ethernet0/0
ip address 172.23.1.120 255.255.255.0
shutdown
duplex full
speed 1000
no mop enabled
interface Ethernet0/1
no ip address
duplex full
speed 1000
bridge-group 1
interface Ethernet0/2
no ip address
duplex full
speed 1000
bridge-group 1
interface Ethernet0/3
no ip address
duplex full
speed 1000
bridge-group 1
interface Ethernet1/0
description TAP interface
ip address 198.18.134.131 255.255.192.0
interface Ethernet1/1
no ip address
shutdown
interface Ethernet1/2
no ip address
shutdown
interface Ethernet1/3
no ip address
shutdown
interface BVI1
ip address 172.23.2.1 255.255.255.0
router ospf 100
network 10.0.0.120 0.0.0.0 area 0
network 172.23.1.0 0.0.0.255 area 0
network 172.23.2.0 0.0.0.255 area 0
network 172.23.3.0 0.0.0.255 area 0
network 172.23.4.0 0.0.0.255 area 0
network 198.18.128.0 0.0.63.255 area 0
default-information originate
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 198.18.134.120
snmp-server community public RO
control-plane
bridge 1 priority 8196
bridge 1 protocol ieee
bridge 1 route ip
line con 0
logging synchronous
line aux 0
line vty 0 4
password cisco
login
transport input all
ntp server 198.18.134.132
end
c5921_ubuntu32_1#sh ip rou
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is 198.18.134.120 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 198.18.134.120
      10.0.0.0/32 is subnetted, 2 subnets
C        10.0.0.120 is directly connected, Loopback0
O        10.0.0.121 [110/2] via 172.23.2.2, 00:40:16, BVI1
      172.23.0.0/16 is variably subnetted, 5 subnets, 2 masks
O        172.23.1.0/24 [110/2] via 172.23.2.2, 00:40:16, BVI1
C        172.23.2.0/24 is directly connected, BVI1
L        172.23.2.1/32 is directly connected, BVI1
O        172.23.3.0/24 [110/2] via 172.23.2.2, 00:38:19, BVI1
O        172.23.4.0/24 [110/2] via 172.23.2.2, 00:34:12, BVI1
C     198.18.128.0/18 is directly connected, Ethernet1/0
      198.18.134.0/32 is subnetted, 1 subnets
L        198.18.134.131 is directly connected, Ethernet1/0
c5921_ubuntu32_1#
fcolumbu
Please restore these pages ASAP.
Content for Community-Ad
