861W is used as an example. This will work on any IOS router
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set SP-3DES-SHA
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set reverse-route
crypto map VPN 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map VPN interface outside
ip local pool VPNPOOL 192.168.250.1-192.168.250.254 mask 255.255.255.0
access-list split_tunnel_list_1000 extended permit ip 10.0.0.0 255.255.0.0 any < HQ NETWORK
access-list 100 extended permit ip 10.0.0.0 255.255.0.0 10.0.20.0 255.255.255.0 < Don't NAT traffic to the remote site 10.0.20.0/24
nat (inside) 0 access-list 100
group-policy EZVPN internal
group-policy EZVPN attributes
vpn-idle-timeout none
vpn-tunnel-protocol IPSec
password-storage enable < Allow automatic login for EZVPN
ipsec-udp enable < Allow automatic login for EZVPN
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel_list_1000 < This list controls the automatic routes installed on the remote EZVPN router
default-domain value DOMAIN.com
nem enable < Allow EZVPN network extension mode
tunnel-group EZVPN type remote-access
tunnel-group EZVPN general-attributes
address-pool VPNPOOL
default-group-policy EZVPN
tunnel-group EZVPN ipsec-attributes
pre-shared-key <GROUP KEY>
username <REMOTESITENAME> password <PASSWORD> encrypted privilege 0
version 15.1
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
no service config
hostname ROUTER_NAME
logging buffered 100000
no logging console
enable secret ENABLE_PASSWORD
aaa new-model
aaa authentication login default local
aaa authentication ppp default local < for PPTP
aaa authorization console
aaa authorization exec default local
clock timezone CST -6 0 < Set your timezone
clock summer-time CDT recurring < Set your timezone
crypto pki trustpoint TP-self-signed-709273033 < Self-signed certificate will be automatically created by WEBVPN configuration
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-709273033
revocation-check none
crypto pki certificate chain TP-self-signed-709273033
certificate self-signed 01
quit
ip dhcp excluded-address 10.0.20.1 10.0.20.99
ip dhcp excluded-address 10.0.20.150 10.0.20.254
ip dhcp pool LAN
network 10.0.20.0 255.255.255.0
default-router 10.0.20.254
domain-name DOMAIN.com
dns-server 10.0.20.254 < Router will do split DNS
ip cef
ip domain name DOMAIN.com
ip name-server 4.2.2.2 < Public DNS server
vpdn enable < PPTP Server
vpdn-group PPTP-VPDN < PPTP Server (might need to disable encryption in Windows PPTP client settings)
accept-dialin
protocol pptp
virtual-template 3 < Virtual Template 3 for PPTP
license udi pid CISCO861W-GN-A-K9 sn <SN>
username ROUTERADMIN privilege 15 password PASSWORD
username VPNUSER1 privilege 0 password PASSWORD
username VPNUSER1 autocommand exit < Prevent user from logging into the router (SSH/telnet) [there is a better way to do this with AAA login methods but it requires more configuration]
username VPNUSER2 privilege 0 password PASSWORD
username VPNUSER2 autocommand exit
ip tcp synwait-time 5
ip ssh version 2
class-map type inspect match-any safe-hostile-cmap < Inspect and allow all outbound traffic
match protocol tcp
match protocol udp
match protocol icmp
class-map type inspect match-all hostile-safe-cmap-1
match protocol tcp
match access-group name hostile-safe-acl-1 < For TCP port forwarding to an internal server, see below
policy-map type inspect safe-hostile-pmap
class type inspect safe-hostile-cmap
inspect
class class-default
drop
policy-map type inspect hostile-safe-pmap
class type inspect hostile-safe-cmap-1
inspect
class class-default
drop
zone security hostile
zone security safe
zone-pair security safe-hostile source safe destination hostile
service-policy type inspect safe-hostile-pmap
zone-pair security hostile-safe source hostile destination safe
service-policy type inspect hostile-safe-pmap
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp keepalive 10
crypto ipsec transform-set TS esp-3des esp-sha-hmac
crypto ipsec client ezvpn EZVPNCONFIG
connect auto
group EZVPN key <ASA GROUP KEY> < ASA tunnel group name and key
mode network-extension < Enable NEM, or otherwise traffic to HQ site will be NATted
peer X.X.X.X < ASA external IP
virtual-interface 1 < Using virtual template interface to simplify Zone Based Firewall configuration
username <REMOTESITENAME> password <PASSWORD> < match username on the ASA
xauth userid mode local
interface Loopback0
ip address 172.16.1.1 255.255.255.255 < any unused IP
interface FastEthernet0
spanning-tree portfast < 861W has four switch ports
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4 < 861W has one external WAN Ethernet port
ip address x.x.x.x x.x.x.x < Public IP at the remote site. This can also be DHCP, but then SSL VPN will not work as it is tied to a static IP address. This can also be behind NAT (EZVPN will work through NAT), but then you need to make sure that external NAT device port forwards ports 443 for SSL VPN to work (additional ports for PPTP and other port forwarding will also be needed)
ip nat outside
ip virtual-reassembly in
zone-member security hostile
load-interval 30
duplex auto
speed auto
interface Virtual-Template1 type tunnel < Virtual Template 1 for EZVPN
no ip address
zone-member security safe < You can also set up separate VPN zone, but usually all traffic is allowed through VPN, so it's safe to put it into internal ZONE
tunnel mode ipsec ipv4
interface Virtual-Template3 < Virtual Template 3 for inbound PPTP connections
ip unnumbered Loopback0
peer default ip address pool vpnpool
ppp authentication ms-chap ms-chap-v2
interface Virtual-Template10 < Virtual Template 10 for SSL VPN
interface wlan-ap0 < Management connection to built-in AP, connect to AP's console with "service-module wlan-ap 0 session"
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0 < Data switchport to the AP, this could also be setup as 802.1q trunk for multiple SSID+VLANs
description Internal switch interface connecting to the embedded AP
interface Vlan1
ip address 10.0.20.254 255.255.255.0
ip dns view-group SPLITDNS < Enable split DNS
ip nat inside
crypto ipsec client ezvpn EZVPNCONFIG inside
ip local pool vpnpool 10.0.21.1 10.0.21.20 < VPN Pool for SSL VPN and PPTP. It must be a different subnet from the VLAN1 subnet
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns view SPLITDNS-VIEW < DNS View for Internal DNS
domain name-server 10.0.0.100 < DNS server at the HQ site
dns forwarding source-interface Vlan1 < Source DNS requests for internal DNS from the internal IP
ip dns view-list SPLITDNS < DNS View Group grouping Internal DNS view 10 for DOMAIN.com requests and External DNS view 20 for public DNS requests
view SPLITDNS-VIEW 10
restrict name-group 1
view default 20
ip dns name-list 1 permit .*.DOMAIN.COM < SPLITDNS-VIEW will be used for DNS requests for <anything>.DOMAIN.COM (syntax: "." is for any character, "*" is for any number of any character, and the following "." represents the actual "." in the domain name)
ip dns server < Enable DNS server
ip nat inside source list 100 interface FastEthernet4 overload < Enable dynamic PAT to the Internet. If you use named ACL you might experience a bug where you can't connect the router from the outside (SSH, SSL VPN, PPTP)
ip nat inside source static tcp 10.0.20.55 22 interface FastEthernet4 2022 < Port forwarding from outside to SSH on an internal server
ip route 0.0.0.0 0.0.0.0 X.X.X.X < Default route to outside. Not necessary if using DHCP.
ip access-list extended hostile-safe-acl-1 < Allow inbound port forwarding from outside through Zone Based firewall. Use local IP and Port instead of global IP and Port
permit tcp any host 10.0.20.55 eq 22
ip sla 100 < Keep VPN connection up
icmp-echo 10.0.0.100 source-ip 10.0.20.254
frequency 5
ip sla schedule 100 life forever start-time now
access-list 100 permit ip any any < No need to not NAT traffic to HQ site because it's not flowing through the Fas4 outside interface but instead through a virtual-template (actually, virtual-access) interface
banner motd ^
Authorized access only!
line con 0
logging synchronous
line aux 0
line 2 < Reverse CONSOLE to the built-in AP. Automatically configured.
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
logging synchronous
transport input ssh < Allow only SSH from outside. Some might decide to use SELF zone for Zone Based Firewall to control management traffic, but I find it unnecessary. You might also experience problems with SSL VPN and PPTP if you do that.
ntp server 173.203.122.111
crypto key generate rsa modulus 2048 < Non-configuration command. Don't forget to do this to enable SSH server on the router.
webvpn gateway ssl < SSL VPN configuration, as soon as you enter this mode IOS will create a self-signed certificate on the router
ip address X.X.X.X port 443 < Router's external IP. Not possible if router is using external DHCP.
http-redirect port 80 < Redirect port 80 to 443 for convenience
ssl trustpoint TP-self-signed-709273033
inservice < Enable SSL VPN
webvpn install svc flash:/webvpn/anyconnect-win-3.0.1047-k9.pkg sequence 1 < Install anyconnect packages for Windows, Mac OSX, Linux 32-bit and Linux 64-bit. You need to download these packets from Cisco.com
webvpn install svc flash:/webvpn/anyconnect-macosx-i386-3.0.1047-k9.pkg sequence 2
webvpn install svc flash:/webvpn/anyconnect-linux-3.0.1047-k9.pkg sequence 3
webvpn install svc flash:/webvpn/anyconnect-linux-64-3.0.1047-k9.pkg sequence 4
webvpn context sslvpn
ssl authenticate verify all
login-message "Welcome to XYZ SSL VPN Service"
policy group sslvpn
functions svc-required < Disable clientless web vpn
timeout idle 3600
timeout session 86400
svc address-pool "vpnpool"
svc default-domain "DOMAIN.com"
svc keep-client-installed
svc mtu 1200
svc split include 10.0.20.0 255.255.255.0 < Allow anyconnect to split tunnel
svc dns-server primary 4.2.2.2
virtual-template 10 < Using virtual template for SSL VPN to simplify zone based firewall configuration
default-group-policy sslvpn
aaa authentication list default
gateway ssl
inservice
end
ROUTER_NAME#service-module wlan-ap 0 session
Trying 10.0.20.254, 2002 ... Open
Connecting to AP console, enter Ctrl-^ followed by x,
then "disconnect" to return to router prompt
User Access Verification
Username: ROUTERADMIN < This is ROUTERADMIN from the router's configuration
Password:
Welcome to wireless access point! Please login again! < MOTD Banner on the AP
Username: ROUTERADMIN < This is ROUTERADMIN from the AP's configuration
Password:
AP#sh run
Building configuration...
version 12.4
hostname AP
logging buffered 20000 debugging
enable secret <ENABLE PASSWORD>
aaa new-model
aaa session-id common
dot11 syslog
dot11 ssid WIRELESS_SSID
authentication open
authentication key-management wpa version 2 < Enforce WPA2
guest-mode < Broadcast SSID
wpa-psk ascii WPA_PASSWORD < WPA2 Password
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid WIRELESS_SSID
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. < Disable 802.11b clients
station-role root ap-only
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting AP with the host router
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 10.0.20.253 255.255.255.0 < AP's management IP
no ip route-cache
ip default-gateway 10.0.20.254
no ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner motd ^Welcome to wireless access point! Please login again!^
line con 0
logging synchronous
line vty 0 4
logging synchronous
line vty 5 15
logging synchronous
Having trouble getting version 15.1 to work with (aaa authorization network default group radius local) it works in 12.4. Anyone willing to share there reply-attributes?
