Cisco Nexus 7000 / 7700 Line Cards
12292
Overview
The Cisco Nexus core switch platform includes the 7000 series switches and the newer 7700 series switches. The 7000 series switches are comprised of the 7004 (4 slot), 7006 (6 slot), 7009 (9 slot), 7010 (10 slot) and 7018 (18 slot). The 7700 series switches are comprised of the 7706 (6 slot), 7710 (10 slot) and 7718 (18 slot) switches. The Nexus switches are high performance distribution and core switches that have features unique to the Nexus platform such as FabricPath, OTV and multiple fabric modules for increasing capacity. In addition the Supervisor Engine 1, 2 and 2E are specific to Nexus switches. Most of the line cards support layer 2 and layer 3 forwarding. The F1 32-port GE and 10 GE line card module is a layer 2 module and used for access switch connectivity. All Nexus line cards are wire rate non-blocking (no oversubscription) except those noted. In addition the line cards specify chassis type and platform support. The Nexus switches use a distributed architecture for all layer 2 and layer 3 forwarding. That means each line card does all the layer 2 and layer 3 forwarding of packets without using the supervisor engine. It is similar to the Cisco 6500 switch dCEF architecture. Some of the Nexus platforms have additional slots for fabric modules that increase the line card data throughput.
FabricPath is a Nexus layer 2 feature available with all F-Series line cards that is designed to replace spanning tree protocol and optimize local and remote data center interconnect. The bandwidth is optimized with multiple ECMP path load balancing while availability is improved with faster convergence using IS-IS SFP routing protocol. Those enhancements available with NX-OS software allows for significant scalability at the data center and cloud service providers. Each FabricPath enabled switch is assigned a MAC address for forwarding Ethernet packets across the FabricPath for all connected switches. The Nexus switch attaches a unique FabricPath MAC address header used for forwarding packets to the neighbor switch. The destination switch then strips off the FabricPath header and forwards the Ethernet packet after doing CAM and ARP table lookups. An advantage of FabricPath is that VLANs can be extended across the data center. That provides layer 2 adjacency without having to move servers.
Overlay Transport Virtualization (OTV), available with all F3-Series line cards, extends the data center layer 2 topology and connectivity to multiple data centers. It creates a single logical layer 2 network with VLANs extended across multiple data centers. The layer 3 OTV edge devices at each data center maintain a table with local and remote mac addresses. Remote host MAC reachability is done with a control plane protocol to advertise local MAC addresses to remote OTV edge devices. The remote MAC addresses have a next hop IP address of the remote OTV edge device. The OTV edge device uses MAC routing transport to encapsulate or add an IP header to the Ethernet layer 2 frame. The IP header contains the next hop IP address of the remote OTV edge device. The IP header is stripped off by the remote OTV edge device and forwarded to the core switch. At that point Ethernet frames are forwarded across the campus switching infrastructure with traditional data plane CAM and ARP table lookups.
VDCs allow for virtualizing or creating logical switches from a single physical nexus switch. The advantages include separate administrative domains, fault isolation, traffic segmentation and security. It is often most deployed to larger data centers and cloud providers for scalability purposes.
Nexus 7700 F3-Series 12-Port 100 Gigabit Ethernet Module
  • Layer 2 / Layer 3
  • 12 x 100 Gbps (CPAK)
  • 192 x wire-rate 100 Gigabit Ethernet ports are supported in a Nexus 7718 chassis
  • 1.8 billion packets per second layer 2 and layer 3 IPv4 and IPv6 forwarding
  • 1.2 Tbps of data throughput (2.4 Tbps full-duplex)
  • 7710 and 7718 chassis
  • Supervisor Engine 2E
  • Fabric-2 Module (7010 and 7018 chassis)
  • 4 ingress and 8 egress queues per port
  • Jumbo Frame Support
  • 64K MAC addresses
  • 4096 VLANs per VDC
  • 64K IPv4 routes
  • 32K IPv6 routes
  • Switch on Chip (SoC) ASIC
Nexus 7700 F3-Series 24-Port 40 Gigabit Ethernet Module
  • Layer 2 / Layer 3
  • 24 x 40 Gbps (QSFP+)
  • 384 x wire-rate 40 Gigabit Ethernet ports in a Nexus 7718 chassis
  • 1.44 billion packets per second layer 2 and layer 3 IPv4 and IPv6 forwarding
  • 960 Gbps data throughput (1.92 Tbps full-duplex)
  • 64K MAC addresses
  • 64K IPv4 routes
  • 32K IPv6 routes
Nexus 7700 F3-Series 48-Port Fiber 1 and 10 Gigabit Ethernet Module
  • Layer 2 / Layer 3
  • 48 x 1/10 Gbps (SFP and SFP+)
  • 768 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7718 chassis
  • 720 million packets per second layer 2 and layer 3 IPv4 and IPv6 forwarding
  • 480 Gbps data throughput (960 Gbps full-duplex)
  • 7706, 7710 and 7718 chassis
  • 64K MAC addresses
  • 64K IPv4 routes
  • 32K IPv6 routes
Nexus 7700 F2-Series Enhanced 48-Port Fiber 1 and 10 Gigabit Ethernet Module
  • Layer 2 / Layer 3
  • 4 ingress and 4 egress queues per port
  • 16K MAC addresses
  • 32K IPv4 routes
  • 16K IPv6 routes
  • NX-OS 6.2.2+
Nexus 7000 F3-Series 6-Port 100 Gigabit Ethernet Module
  • Layer 2 / Layer 3
  • 6 x 100 Gbps (CPAK)
  • 96 x wire-rate 100 Gigabit Ethernet ports in a single Nexus 7018 chassis
  • 900 million packets per second layer 2 and layer 3 IPv4 and IPv6 forwarding
  • 600 Gbps data throughput (1.2 Tbps full-duplex)
  • 7004, 7009, 7010 and 7018 chassis
  • Supervisor Engine 1, 2 and 2E
  • Fabric-1 Module (7010 and 7018 chassis), Fabric-2 Module (7009, 7010, 7018 chassis)
  • 64K MAC addresses
  • 64K IPv4 routes
  • 32K IPv6 routes
Nexus 7000 F3-Series 12-Port 40 Gigabit Ethernet Module
  • Layer 2 / Layer 3
  • 12 x 40 Gbps (QSFP+)
  • 192 x wire-rate 40 Gigabit Ethernet ports in a single Nexus 7018 chassis
  • 64K MAC addresses
  • 64K IPv4 routes
  • 32K IPv6 routes
Nexus 7000 F2-Series Enhanced 48-Port Fiber 1 and 10 Gigabit Ethernet Module
  • Layer 2 / Layer 3
  • 768 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
  • 16K MAC addresses
  • 32K IPv4 routes
  • 16K IPv6 routes
  • NX-OS 6.1.2+
Nexus 7000 F2-Series Enhanced 48-Port 1 and 10GBASE-T Ethernet Copper Module
  • Layer 2 / Layer 3
  • 48 x 1/10 Gbps (RJ-45)
  • 768 x wire-rate 10GBase-T Ethernet ports in a single Nexus 7018 chassis
  • 16K MAC addresses
  • 32K IPv4 routes
  • 16K IPv6 routes
  • NX-OS 6.1.2+
Nexus 7000 F2-Series 48-Port 1 and 10 Gigabit Ethernet Module
  • Layer 2 / Layer 3
  • 16K MAC addresses
  • 32K IPv4 routes
  • 16K IPv6 routes
  • NX-OS 6.0+
Nexus 7000 F1-Series 32-Port 1 and 10 Gigabit Ethernet Module
  • Layer 2
  • 32 x 1/10 Gbps (SFP and SFP+)
  • 512 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
  • 480 million packets per second layer 2 forwarding
  • 320 Gbps data throughput (640 Gbps full-duplex)
  • 7009, 7010 and 7018 chassis
  • 256K MAC addresses
  • 16K VLANs per module
  • NX-OS 5.1.1+
Nexus 7000 M2-Series 24-Port 10 Gigabit Ethernet Module with XL Option
  • Layer 2 / Layer 3
  • 24 x 10 Gbps (SFP+)
  • 384 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
  • 120 million packets per second layer 2 and layer 3 IPv4 forwarding and 60 mpps IPv6
  • 550 Gbps data throughput (1.1 Tbps full-duplex)
  • 8 ingress and 8 egress queues per port
  • 128K MAC addresses
  • 1M IPv4 routes
  • 350K IPv6 routes
  • NX-OS 6.1+
Nexus 7000 M2-Series 6-Port 40 Gigabit Ethernet Module with XL Option
  • Layer 2 / Layer 3
  • 6 x 40 Gbps (QSFP+)
  • 96 x wire-rate 40 Gigabit Ethernet and 10 Gbps ports in a Nexus 7018 chassis
  • 1M IPv4 routes
  • 350K IPv6 routes
  • NX-OS 6.1+
Nexus 7000 M2-Series 2-Port 100 Gigabit Ethernet Module with XL Option
  • Layer 2 / Layer 3
  • 2 x 100 Gbps (CFP)
  • 32 x wire-rate 100 Gigabit Ethernet ports in a single Nexus 7018 chassis
  • 550 Gbps of data throughput (1.1 Tbps full-duplex)
  • 1M IPv4 routes
  • 350K IPv6 routes
  • NX-OS 6.1+
Nexus 7000 M1-Series 8-Port 10 Gigabit Ethernet Module with XL Option
  • Layer 2 / Layer 3
  • 8 x 10 Gbps (X2)
  • 128 x wire-rate 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
  • 80 Gbps of data throughput (160 Gbps full-duplex)
  • 1M IPv4 routes
  • 350K IPv6 routes
  • NX-OS 5.0+
Nexus 7000 M1-Series 32-Port 10 Gigabit Ethernet Module with XL Option
  • Layer 2 / Layer 3
  • 32 x 10 Gbps (SFP+)
  • 512 x 10 Gigabit Ethernet ports in a single Nexus 7018 chassis
  • 60 million packets per second layer 2 and layer 3 IPv4 forwarding and 30 mpps IPv6
  • 1M IPv4 routes
  • 350K IPv6 routes
  • 4:1 oversubscription
  • NX-OS 5.1+
Nexus 7000 M1-Series 48-Port Gigabit Ethernet Modules with XL Option
  • Layer 2 / Layer 3
  • 48 x 1 Gbps (SFP/RJ45)
  • 768 x Gigabit Ethernet (SFP) or 10/100/1000 (RJ45) ports in Nexus 7018 chassis
  • 46 Gbps of data throughput (92 Gbps full-duplex)
  • 2 ingress and 4 egress queues per port
  • 1M IPv4 routes
  • 350K IPv6 routes
  • Some oversubscription
  • NX-OS 5.0 (SFP) / 5.1+ (RJ45)
  • Layer 2 / Layer 3
  • 128K FIB routes
  • NX-OS 4.0+
  • Layer 2 / Layer 3
  • 768 x 10/100/1000 RJ45 or Gigabit Ethernet (SFP) ports in Nexus 7018 chassis
  • 128K FIB routes
  • NX-OS 4.1+ (SFP) / 4.0+ (RJ45)
Copyright © 2015 Shaun L. Hummel All Rights Reserved
