rsanchezre
     I've been trying to set up a trunk between a SF-300 and 3560 without success, in spite of i've been sticking to the manual "Cisco Small Business 300 Series Managed Switch Administration Guide Release 1.2.7". So, i wonder if any of you could help me with this issue.
Into the Cisco Catalyst 3560 I configured the following commands,
interface FastEthernet0/29
description Puesto de PruebaVLANs
power inline never
switchport mode trunk
speed 100
duplex full
and as result of this i have
SBSTRCPCO01#sh int trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa0/29      on           802.1q         trunking      1
Po1         on           802.1q         trunking      1
Port        Vlans allowed on trunk
Fa0/29      1-4094
Po1         1-4094
Port        Vlans allowed and active in management domain
Fa0/29      1,167,201,418,500
Po1         1,167,201,418,500
Port        Vlans in spanning tree forwarding state and not pruned
into the Cisco SF-300 I configured these commands,
vlan database
vlan 2,418
interface vlan 418
ip address 10.0.18.10 255.255.254.0
no ip address dhcp
interface vlan 1
name Default
no ip address dhcp
interface fastethernet1
switchport mode access
interface fastethernet2
switchport access vlan 418
interface gigabitethernet3
speed 100
no negotiation
switchport trunk allowed vlan add 418vlan database
vlan 2,418
interface vlan 418
no ip address dhcp
interface vlan 1
name Default
no ip address dhcp
speed 100
no negotiation
So as result of all this configuration,
- I can ping  the PC which is connected to fastethernet1 (Native VLAN ID 1 )
- I can ping  the managment interface (On interface vlan 418).
- but,  I can´t ping the PC which is connected to fastethernet2 (VLAN ID 418)
It's like the VLAN ID 418 wasn't propagated into the switch from the trunk interface gigabiteethernet3, which is a tagged, to the interfase fastethernet2, which is untagged.
So appreciate any clue which it help me to fix this problem.
regards so appreciate any clue which it help me to fix this problem.
regards
Rodrigo
