Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
CISCO switch can communication with a Hirschmann switch via SFP module?
1928
I've got a 2960-8tc-l switch that I need to connect via multi-mode fiber to a Hirschmann switch.The hirschmann switch supports only 100M bits fibber and the vavelength is 1310nm. So I should choose  SFP module (GLC-FE-100FX) or SFP module (GLC-LH-SM) or both can't be connetet to a hirschmann switch? Is there any other solution if both can't be connected to a hirschmann switch except for replacing the cisco switch?
Looking for a solution that will quickly resolve this problem!
Thank you!
