Cisco Works using TFTP to PUSH instead of SNMP
37
Is there a way to change Cisco Works to use SNMP to push Configuration Changes to routers & switches?  I recently did a push to the over 4500 devices in my network and found that Cisco Works was using TFTP instead of SNMP.  Is there a setting in Cisco Works I can change for getting SNMP used instead of TFTP?
Also, when I look at the devices, they do NOT show the profile name that Cisco Works uses to log into the devices.  Thus the Audit function doesn't pick up the name.  Is there something I need to add to get this to happen?  Would like to keep the Security people off my back.
Content for Community-Ad
August's Community Spotlight Awards
