Configuring and Troubleshooting VWIC2-xCTE1-PRI Modules for Inbound ISDN Multilink PPP Data Calls
11042
We have seen more and more customers are now moving away from traditional NM-xCTE1-PRI and HWIC-xCTE1-PRI modules which supports data and modem calls (not voice calls) to VWIC2-xMFT-T1/E1 modules which supports Data and Voice calls together on same PRI lines. We have seen increased deployment of VWIC2-xMFT-T1/E1 modules on Integrated Service Routers that supports voice and data calls on same PRI line.
This document describes how to configure ISDN PRI interfaces on VWIC2-xMFT-T1/E1 modules with PVDM2-xx to support data calls on multiservice access routers. This feature enables Multilink PPP data (dial-in, dial-on-demand routing [DDR], and DDR backup) and voice call traffic to occur simultaneously from the supported ISDN PRI interfaces.
Supported Modules
This feature supports the following modules:
–NM-HD
–NM-HDV2
–Onboard DSPs
•This feature is supported on the following voice cards:
–VWIC-XMFT-X interface modules
–VWIC2-XMFT-X interface modules
Note http://www.cisco.com/en/US/i/templates/blank.gifData calls are supported only on the NM-HDV2-2T1/E1 and NM-HD-2V-E network modules, and the VWIC-2MFT-E1, VWIC-2MFT-T1 and VWIC2-T1/E1 voice cards.
Use the isdn switch-type ? command in interface configuration mode or global configuration mode to view the list of supported ISDN switch types. See the following example:
Router(config)# isdn switch-type ?
  primary-4ess    Lucent 4ESS switch type for the U.S.
  primary-5ess    Lucent 5ESS switch type for the U.S.
  primary-dms100  Northern Telecom DMS-100 switch type for the U.S.
  primary-dpnss   DPNSS switch type for Europe
  primary-net5    NET5 switch type for UK, Europe, Asia and Australia
  primary-ni      National ISDN Switch type for the U.S.
  primary-ntt     NTT switch type for Japan
  primary-qsig    QSIG switch type
  primary-ts014   TS014 switch type for Australia (obsolete)
Restrictions for Integrating Data and Voice Services for ISDN PRI Interfaces
•This feature is supported only on C5510 DSP-based platforms.
ISDN backhaul is not supported.
This feature does not support modem calls.
For platforms that support HDLC resources on the motherboard, the available on board HDLC resources are limited to 31 if all resources are not enabled.
The Cisco 2801 platform does not support full channelized data or full integrated data and voice over T1/E1 PRI interfaces. However, data back up through one PRI channel, or one group of PRI channels for data backup, is supported on this platform.
Only PPP with multilink is supported for multiple channels. HDLC is not supported for multiple channels.
This feature is not supported from a BRI interface.
• following dialer commands are not supported with the integrated data and voice feature:
dialer aaa
dialer callback-secure
dialer callback-server
dialer dns
dialer order
dialer persistent
dialer redial
dialer vpdn
dialer watch-disable
dialer watch-group
dialer watch-list
dialer watch-list delay
Components Used
The information in this document is based on these software and hardware versions in the lab environment
·       Cisco 3845 with VWIC2-2MFT-T1/E1 and PVDM2-64 running IOS® Software Release 12.4(24)T1
·       Cisco 2811 with WIC-1B-U-V2 running IOS® Software Release 12.4(7h)
Note: The information in this document was created from the devices in a specific lab environment. All of the devices used in this document started with a cleared (default) configuration. If your network is live, make sure that you understand the potential impact of any command.
Network Diagram
This document uses this network setup:
In above network diagram, 2811 as a Branch router with BRI lines dialing in to 3845 ISR router with PRI lines using Multilink PPP calls. Detailed configuration of 2811 Branch router is not the intended purpose of this document.
Configurations
Cisco 2811 Branch router
2811-1#sh run
Building configuration...
Current configuration : 1165 bytes
version 12.4
hostname 2811-1
boot-start-marker
boot system flash:c2800nm-advsecurityk9-mz.124-7h
boot-end-marker
!enable password cisco
no aaa new-model
resource policy
ip cef
isdn switch-type basic-5ess
username cisco password 0 cisco
archive
log config
  hidekeys
interface GigabitEthernet0/1
ip address 11.0.0.1 255.255.255.0
load-interval 30
duplex auto
speed auto
interface BRI0/0/0
ip address negotiated
encapsulation ppp
dialer idle-timeout 120 either
dialer string 914084283115
dialer load-threshold 2 either
dialer-group 1
isdn point-to-point-setup
ppp authentication chap callin
ppp chap hostname Param
ppp chap password 0 cisco
ppp multilink
ip route 0.0.0.0 255.255.255.255 BRI0/0/0
no ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
login
scheduler allocate 20000 1000
end
2811-1#
2811-1# sh diag
Slot 0:
            C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
            Port adapter is analyzed
            Port adapter insertion time unknown
            Onboard VPN                        : v2.2.0
            EEPROM contents at hardware discovery:
            PCB Serial Number        : FOC08212CQB
            Hardware Revision        : 0.9
            Top Assy. Part Number    : 800-23519-01
            Board Revision           : 13
            Deviation Number         : 0
            Fab Version              : 08
            RMA Test History         : 00
            RMA Number               : 0-0-0-0
            RMA History              : 00
            Processor type           : 87
            Hardware date code       : 20040524
            Chassis Serial Number    : FHK0829F048
            Chassis MAC Address      : 000f.352c.8bf1
            MAC Address block size   : 36
            CLEI Code                : CNMJ600BRA
            Product (FRU) Number     : CISCO2821
            Part Number              : 73-8854-09
            Version Identifier       :   NA
            EEPROM format version 4
            EEPROM contents (hex):
              0x00: 04 FF C1 8B 46 4F 43 30 38 32 31 32 43 51 42 40
              0x10: 03 E8 41 00 09 C0 46 03 20 00 5B DF 01 42 31 33
              0x20: 88 00 00 00 00 02 08 03 00 81 00 00 00 00 04 00
              0x30: 09 87 83 01 31 CB 4C C2 8B 46 48 4B 30 38 32 39
              0x40: 46 30 34 38 C3 06 00 0F 35 2C 8B F1 43 00 24 C6
              0x50: 8A 43 4E 4D 4A 36 30 30 42 52 41 CB 8F 43 49 53
              0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 96
              0x70: 09 89 20 20 4E 41 D9 02 40 C1 FF FF FF FF FF FF
            WIC Slot 0:
            BRI U - 2091, 3086 WAN daughter card
            Hardware revision 1.0                     Board revision H0
            Serial number     33000351              Part number    800-19400-01
            FRU Part Number     WIC-1B-U-V2=
            Test history      0x0                     RMA number     00-00-00
            Connector type    Wan Module
            EEPROM format version 1
              0x20: 01 45 01 00 01 F7 8B 9F 50 4B C8 01 00 00 00 00
              0x30: 88 00 00 00 05 01 13 01 FF FF FF FF FF FF FF FF
Note:
In order for 3845 with VWIC2-2MFT-T1/E1 card to accept the data calls, need to make sure that dial-peer for data calls are configured with incoming called-number matching the DNIS received.
If data dial-peer or “incoming called-number “ command is not configured, you will see ISR rejecting the call with following debugs
*Sep 10 21:02:54.389: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x14C9
            Bearer Capability i = 0x8890
                        Standard = CCITT
                        Transfer Capability = Unrestricted Digital
                        Transfer Mode = Circuit
                        Transfer Rate = 64 kbit/s
            Channel ID i = 0xA98381
                        Exclusive, Channel 1
            Calling Party Number i = 0x2180, '4087775100'
                        Plan:ISDN, Type:National
            Called Party Number i = 0x80, '83115'
                        Plan:Unknown, Type:Unknown
*Sep 10 21:02:54.393: ISDN Se0/0/1:23 Q931: Received SETUP  callref = 0x94C9 callID = 0x0008 switch = primary-5ess interface = User
*Sep 10 21:02:54.393: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4087775100, Called Number=83115, Voice-Interface=0x6A0DB574,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_DATA,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=NO_MATCH(-1) after DP_MATCH_INCOMING_DNIS
   Calling Number=4087775100, Called Number=83115, Voice-Interface=0x0,
*Sep 10 21:02:54.393: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x94C9
            Cause i = 0x809C - Invalid number format (incomplete number)
Cisco 3845 router :
3845-1#sh run
Current configuration : 3877 bytes
version 12.4
service internal
hostname 3845-1
boot-start-marker
boot-end-marker
card type t1 0 0
!---Need to define a card type about the use of VWIC2-2MFT-T1/E1 card to be a
!--- T1 card or a E1 card. Here we are using it as a T1 card.
logging message-counter syslog
logging buffered 65535
enable secret 5 $1$clc3$GfelyWY1QQs6bCR4lxwl..
no aaa new-model
network-clock-participate wic 0
!--- Allow other WICs modules to drive the clock from the selected T1 line
network-clock-select 1 T1 0/0/1
!---Need to select proper T1 line to source the clock from.
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
!---Configure multilink bundle name based on the authenticated username
isdn switch-type primary-5ess
!--- Switch-type for the PRI circuit. Obtain this information from Telco.
voice-card 0
username 1811-1 password 0 cisco
username 1800-1 password 0 cisco
username 2811-1 password 0 cisco
username preet password 0 cisco
username Param password 0 cisco
!--- Usernames for local authentication of the call.
!--- The client presents the username/password and the ISR
!--- authenticates the peer.
archive
log config
  hidekeys
controller T1 0/0/0
cablelength long 0db
pri-group timeslots 1-24
controller T1 0/0/1
!--- For T1 PRI scenarios, all 24 T1 timeslots are assigned as
!--- ISDN PRI channels. The router now automatically creates the
!--- corresponding D-channel: interface Serial 0/0/1:23.
!--- Framing for this T1 is Extended Super Frame (ESF) and linecode is !--- B8ZS is default. Obtain these information from the Telco.
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Loopback1
ip address 100.1.1.1 255.255.255.0
interface GigabitEthernet0/0
ip address 200.1.1.1 255.255.255.0
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/0/0:23
ip unnumbered Loopback1
encapsulation ppp
dialer idle-timeout 600 either
dialer-group 1
isdn integrate calltype all
peer default ip address pool My-IP
ppp chap hostname 3845-1
ppp multilink
interface Serial0/0/1:23
!--- D-channel configuration for T1 0/2/0.
!--- A Loopback interface is always up/up. So, unnumber the Loopback
!--- interface for stability.
encapsulation ppp
!--- Idle Timeout is defined as 600 secs which is 10 mins.
dialer-group 1
!--- Interesting traffic is defined in dialer-list 1.
!--- Note: The specified dialer-group number must be the same as the   !--- dialer-list number. In this example, the number is defined as "1".
!--- Enables the serial interface for integrated mode, which allows
!--- data and voice call traffic to occur simultaneously.
!--- Clients are assigned addresses from the IP address pool named My-IP which needs to be configured later in the config.
!--- Use CHAP authentication.
ppp multilink
!--- Configure the interface to use multilink.
!--- Without this command multilink is NOT negotiated.
!--- This command is needed to bind more than one calls from the same
!--- user together.
ip local pool My-IP 100.1.1.2 100.1.1.100
!--- IP address pools for dialin clients.
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 200.1.1.2
ip http server
control-plane
voice-port 0/0/1:23
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
dial-peer data 1 pots
incoming called-number 83115
!--- For data dial-peer matching, only the called number of an incoming call is
!--- used to match the incoming called number of POTS dial peers. Wild cards
!--- are accepted. The string must match the number received in ISDN SETUP
!--- message for data call.
dial-peer search type data voice
!--- Configures the preference of voice or data dial-peer lookup during the
!--- calltype checking for incoming ISDN calls.
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
password cisco
login
line vty 0 4
exec-timeout 60 0
privilege level 15
password cisco
logging synchronous
login
line vty 5 10
exec-timeout 60 0
privilege level 15
password cisco
logging synchronous
login
end
3845-1#show diag
Slot 0:
            C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 13 ports
            <snip>
            PVDM Slot 0:
            64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
            Hardware Revision        : 4.0
            Part Number              : 73-8541-05
            Board Revision           : A0
            Fab Version              : 04
            PCB Serial Number        : FOC10202UFD
            RMA History              : 00
            Processor type           : 00
            Product (FRU) Number     : PVDM2-64
            Version Identifier       : V01
            <snip>
            WIC Slot 0:
            VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
            Hardware Revision        : 0.0
            Top Assy. Part Number    : 800-22629-05
            Board Revision           : B0
            Fab Version              : 04
            PCB Serial Number        : FOC11240T31
            RMA History              : 00
            Product (FRU) Number     : VWIC2-2MFT-T1/E1
3845-1#sh network-clocks
  Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
     1          T1 0/0/1        GOOD            T1
    11          Backplane       GOOD            PLL
  Current Primary Clock Source
     1          T1 0/0/1        GOOD            T1
Use the following commands to troubleshoot integrated data for ISDN interfaces:
debug dialer events—Used to display debugging information about the packets received on a dialer interface.
debug isdn q931—Used to check outgoing dial-peer matching for an ISDN incoming call. Enable this command on both sides of the call. The output indicates whether the messages are generated by the calling party router (indicated by TX ->) or by the called party router (indicated by RX <-).
debug voip ccapi inout—Used to show how a call flows through the system. From the output, you can see the call setup and teardown operations performed on both the telephony and network call legs.
show isdn active and show isdn status—Used to show the active data and voice calls.
debug ppp negotiation—displays information on the PPP traffic and exchanges, and negotiates Link Control Protocol (LCP), Authentication, and Network Control Protocol (NCP). A successful PPP negotiation first opens the LCP state, then authenticates, and finally negotiates NCP. Multilink Parameters such as Maximum Receive Reconstructed Unit (MRRU) are established during LCP negotiation.
debug ppp error—displays protocol errors and error statistics associated with PPP connection negotiation and operation.
debug ppp authentication—displays PPP authentication protocol messages, including CHAP packet exchanges and Password Authentication Protocol (PAP) exchanges.
debug voip dialpeer all—displays dialpeer selection based on the incoming digits
3845-1#debug isdn q931
debug isdn q931 is                        ON.
3845-1#debug ppp negotiation
PPP protocol negotiation debugging is on
3845-1#debug ppp authentication
PPP authentication debugging is on
3845-1#debug dialer
Dial on demand events debugging is on
3845-1#debug voip dialpeer
voip dialpeer default debugging is on
3845-1#debug voip ccapi inout
voip ccapi inout debugging is on
3845-1#sh debug
PPP:
  PPP protocol errors debugging is on
The following ISDN debugs are enabled on all DSLs:
debug isdn error is                        ON.
debug isdn q931 is                        ON.   (filter is OFF)
DIALPEER:
  debug voip dialpeer error call is ON (filter is OFF)
  debug voip dialpeer error call informational is ON (filter is OFF)
  debug voip dialpeer error software is ON
  debug voip dialpeer error software informational is ON
  debug voip dialpeer function is ON (filter is OFF)
  debug voip dialpeer inout is ON (filter is OFF)
  debug voip dialpeer detail is ON (filter is OFF)
CCAPI:
  debug voip ccapi inout is ON (filter is OFF)
3845-1#
3845-1#
*Sep  9 17:14:40.368: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x1479
                        Standard = CCITT
*Sep  9 17:14:40.368: ISDN Se0/0/1:23 Q931: Received SETUP  callref = 0x9479 callID = 0x0016 switch = primary-5ess interface = User
*Sep  9 17:14:40.368: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=4087775100, Called Number=83115, Voice-Interface=0x6A16A13C,
   Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=83115
*Sep  9 17:14:40.368: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
*Sep  9 17:14:40.372: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=83115, Expanded String=83115, Calling Number=
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
*Sep  9 17:14:40.372: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1 Is Matched
*Sep  9 17:14:40.372: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5615
*Sep  9 17:14:40.372: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
*Sep  9 17:14:40.372: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6169
*Sep  9 17:14:40.372: %LINK-3-UPDOWN: Interface Serial0/0/1:0, changed state to up
*Sep  9 17:14:40.372: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected to 4087775100 N/A
*Sep  9 17:14:40.372: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x9479
*Sep  9 17:14:40.372: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8  callref = 0x9479
*Sep  9 17:14:40.372: Se0/0/1:0 PPP: Using dialer call direction
*Sep  9 17:14:40.372: Se0/0/1:0 PPP: Treating connection as a callin
*Sep  9 17:14:40.372: Se0/0/1:0 PPP: Session handle[1200007E] Session id[29]
*Sep  9 17:14:40.372: Se0/0/1:0 PPP: Phase is ESTABLISHING, Passive Open
*Sep  9 17:14:40.372: Se0/0/1:0 LCP: State is Listen
*Sep  9 17:14:40.384: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x1479
*Sep  9 17:14:40.616: Se0/0/1:0 LCP: I CONFREQ [Listen] id 10 len 22
*Sep  9 17:14:40.616: Se0/0/1:0 LCP:    MagicNumber 0x36F9583B (0x050636F9583B)
*Sep  9 17:14:40.616: Se0/0/1:0 LCP:    MRRU 1524 (0x110405F4)
*Sep  9 17:14:40.616: Se0/0/1:0 LCP:    EndpointDisc 1 Param (0x130801506172616D)
*Sep  9 17:14:40.616: Se0/0/1:0 PPP: Authorization required
*Sep  9 17:14:40.616: Se0/0/1:0 LCP: O CONFREQ [Listen] id 3 len 28
*Sep  9 17:14:40.616: Se0/0/1:0 LCP:    AuthProto CHAP (0x0305C22305)
*Sep  9 17:14:40.616: Se0/0/1:0 LCP:    MagicNumber 0x4817A467 (0x05064817A467)
*Sep  9 17:14:40.616: Se0/0/1:0 LCP:    EndpointDisc 1 3845-1 (0x130901333834352D31)
*Sep  9 17:14:40.616: Se0/0/1:0 LCP: O CONFACK [Listen] id 10 len 22
*Sep  9 17:14:40.632: Se0/0/1:0 LCP: I CONFACK [ACKsent] id 3 len 28
*Sep  9 17:14:40.632: Se0/0/1:0 LCP:    AuthProto CHAP (0x0305C22305)
*Sep  9 17:14:40.632: Se0/0/1:0 LCP:    MagicNumber 0x4817A467 (0x05064817A467)
*Sep  9 17:14:40.632: Se0/0/1:0 LCP:    MRRU 1524 (0x110405F4)
*Sep  9 17:14:40.632: Se0/0/1:0 LCP:    EndpointDisc 1 3845-1 (0x130901333834352D31)
*Sep  9 17:14:40.632: Se0/0/1:0 LCP: State is Open
*Sep  9 17:14:40.632: Se0/0/1:0 PPP: Phase is AUTHENTICATING, by this end
*Sep  9 17:14:40.632: Se0/0/1:0 CHAP: O CHALLENGE id 3 len 27 from "3845-1"
*Sep  9 17:14:40.648: Se0/0/1:0 CHAP: I RESPONSE id 3 len 26 from "Param"
*Sep  9 17:14:40.648: Se0/0/1:0 PPP: Phase is FORWARDING, Attempting Forward
*Sep  9 17:14:40.652: Se0/0/1:0 PPP: Phase is AUTHENTICATING, Unauthenticated User
*Sep  9 17:14:40.652: Se0/0/1:0 PPP: Sent CHAP LOGIN Request
*Sep  9 17:14:40.652: Se0/0/1:0 PPP: Received LOGIN Response PASS
*Sep  9 17:14:40.652: Se0/0/1:0 PPP: Phase is FORWARDING, Attempting Forward
*Sep  9 17:14:40.652: Se0/0/1:0 PPP: Phase is AUTHENTICATING, Authenticated User
*Sep  9 17:14:40.652: Se0/0/1:0 PPP: Sent LCP AUTHOR Request
*Sep  9 17:14:40.652: Se0/0/1:0 PPP: Sent MLP AUTHOR Request
*Sep  9 17:14:40.652: Se0/0/1:0 PPP: Sent IPCP AUTHOR Request
*Sep  9 17:14:40.652: Se0/0/1:0 LCP: Received AAA AUTHOR Response PASS
*Sep  9 17:14:40.652: Se0/0/1:0 MLP: Received AAA AUTHOR Response PASS
*Sep  9 17:14:40.652: Se0/0/1:0 IPCP: Received AAA AUTHOR Response PASS
*Sep  9 17:14:40.652: Se0/0/1:0 CHAP: O SUCCESS id 3 len 4
*Sep  9 17:14:40.652: Se0/0/1:0 PPP: Phase is VIRTUALIZED
*Sep  9 17:14:40.656: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to up
*Sep  9 17:14:40.656: Vi1 MLP: Added first link Se0/0/1:0 to bundle Param
*Sep  9 17:14:40.656: Vi1 PPP: Phase is DOWN, Setup
*Sep  9 17:14:40.656: Vi1 PPP: Phase is UP
*Sep  9 17:14:40.656: Vi1 IPCP: O CONFREQ [Closed] id 1 len 10
*Sep  9 17:14:40.656: Vi1 IPCP:    Address 100.1.1.1 (0x030664010101)
*Sep  9 17:14:40.656: Vi1 PPP: Sent CDPCP AUTHOR Request
*Sep  9 17:14:40.656: Vi1 PPP: Process pending ncp packets
*Sep  9 17:14:40.656: Se0/0/1:0 PPP: Process pending ncp packets
*Sep  9 17:14:40.656: Vi1 CDPCP: Received AAA AUTHOR Response PASS
*Sep  9 17:14:40.656: Vi1 CDPCP: O CONFREQ [Closed] id 1 len 4
*Sep  9 17:14:40.672: Vi1 IPCP: I CONFREQ [REQsent] id 1 len 10
*Sep  9 17:14:40.672: Vi1 IPCP:    Address 0.0.0.0 (0x030600000000)
*Sep  9 17:14:40.672: Vi1 AAA/AUTHOR/IPCP: Start.  Her address 0.0.0.0, we want 0.0.0.0
*Sep  9 17:14:40.672: Vi1 AAA/AUTHOR/IPCP: Done.  Her address 0.0.0.0, we want 0.0.0.0
*Sep  9 17:14:40.672: Vi1 IPCP: Pool returned 100.1.1.7
*Sep  9 17:14:40.672: Vi1 IPCP: O CONFNAK [REQsent] id 1 len 10
*Sep  9 17:14:40.672: Vi1 IPCP:    Address 100.1.1.7 (0x030664010107)
*Sep  9 17:14:40.672: Vi1 CDPCP: I CONFREQ [REQsent] id 1 len 4
*Sep  9 17:14:40.672: Vi1 CDPCP: O CONFACK [REQsent] id 1 len 4
3845-1#
*Sep  9 17:14:40.672: Vi1 IPCP: I CONFACK [REQsent] id 1 len 10
*Sep  9 17:14:40.672: Vi1 IPCP:    Address 100.1.1.1 (0x030664010101)
*Sep  9 17:14:40.684: Vi1 IPCP: I CONFREQ [ACKrcvd] id 2 len 10
*Sep  9 17:14:40.684: Vi1 IPCP:    Address 100.1.1.7 (0x030664010107)
*Sep  9 17:14:40.684: Vi1 IPCP: O CONFACK [ACKrcvd] id 2 len 10
*Sep  9 17:14:40.684: Vi1 IPCP: State is Open
*Sep  9 17:14:40.684: Se0/0/1:23 IPCP: Install route to 100.1.1.7
*Sep  9 17:14:40.684: Vi1 IPCP: Add link info for cef entry 100.1.1.7
3845-1#
*Sep  9 17:14:41.652: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/1:0, changed state to up
*Sep  9 17:14:41.656: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
3845-1#sh users
    Line       User       Host(s)              Idle       Location
   0 con 0                1.1.1.1                  1w1d
  tty 0/514               idle                     1w1d 1.1.1.1
*706 vty 0                idle                 00:00:00 171.69.89.61
  Interface    User               Mode         Idle     Peer Address
  Vi1          Param              MLP Bundle   00:00:20 100.1.1.7
  Se0/0/1:0    Param              Sync PPP     -        Bundle: Vi1
3845-1#sh caller timeouts
  Line           User               Limit     Remaining Timer Type
  con 0          -                  -         -         -
  tty 0/514      -                  -         -         -
  vty 706        -                  01:00:00  00:59:59  Idle Exec
  Se0/0/1:0      Param              -         -         -
  Vi1            Param              00:10:00  00:09:34  Dialer idle
3845-1#
3845-1#sh dialer map
Dynamic dialer map ip 100.1.1.7   name Param     () on Se0/0/1:23
3845-1#sh ppp multilink
Virtual-Access1
  Bundle name: Param
  Remote Username: Param
  Remote Endpoint Discriminator: [1] Param
  Local Username: 3845-1
  Local Endpoint Discriminator: [1] 3845-1
  Bundle up for 00:00:55, total bandwidth 64, load 1/255
  Receive buffer limit 12192 bytes, frag timeout 1524 ms
  Dialer interface is Serial0/0/1:23
    0/0 fragments/bytes in reassembly list
    0 lost fragments, 0 reordered
    0/0 discarded fragments/bytes, 0 lost received
    0x0 received sequence, 0x0 sent sequence
  Member links: 1 (max not set, min not set)
    Se0/0/1:0, since 00:00:55
No inactive multilink interfaces
3845-1#
2nd call from the branch router come in
*Sep  9 17:15:47.128: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x147A
                        Standard = CCITT
            Channel ID i = 0xA98382
                        Exclusive, Channel 2
*Sep  9 17:15:47.132: ISDN Se0/0/1:23 Q931: Received SETUP  callref = 0x947A callID = 0x0017 switch = primary-5ess interface = User
*Sep  9 17:15:47.132: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Sep  9 17:15:47.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
*Sep  9 17:15:47.132: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Sep  9 17:15:47.132: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Sep  9 17:15:47.132: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@5615
*Sep  9 17:15:47.132: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerSPI:exit@6169
*Sep  9 17:15:47.132: %LINK-3-UPDOWN: Interface Serial0/0/1:1, changed state to up
*Sep  9 17:15:47.132: %ISDN-6-CONNECT: Interface Serial0/0/1:1 is now connected to 4087775100 N/A
*Sep  9 17:15:47.136: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x947A
*Sep  9 17:15:47.136: ISDN Se0/0/1:23 Q931: TX -> CONNECT pd = 8  callref = 0x947A
*Sep  9 17:15:47.136: Se0/0/1:1 PPP: Using dialer call direction
*Sep  9 17:15:47.136: Se0/0/1:1 PPP: Treating connection as a callin
*Sep  9 17:15:47.136: Se0/0/1:1 PPP: Session handle[4B00007D] Session id[31]
*Sep  9 17:15:47.136: Se0/0/1:1 PPP: Phase is ESTABLISHING, Passive Open
*Sep  9 17:15:47.136: Se0/0/1:1 LCP: State is Listen
3845-1#
*Sep  9 17:15:47.144: ISDN Se0/0/1:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x147A
*Sep  9 17:15:47.320: Se0/0/1:1 LCP: I CONFREQ [Listen] id 8 len 22
*Sep  9 17:15:47.320: Se0/0/1:1 LCP:    MagicNumber 0x36FA5CCC (0x050636FA5CCC)
*Sep  9 17:15:47.320: Se0/0/1:1 LCP:    MRRU 1524 (0x110405F4)
*Sep  9 17:15:47.320: Se0/0/1:1 LCP:    EndpointDisc 1 Param (0x130801506172616D)
*Sep  9 17:15:47.320: Se0/0/1:1 PPP: Authorization required
*Sep  9 17:15:47.320: Se0/0/1:1 LCP: O CONFREQ [Listen] id 2 len 28
*Sep  9 17:15:47.320: Se0/0/1:1 LCP:    AuthProto CHAP (0x0305C22305)
*Sep  9 17:15:47.320: Se0/0/1:1 LCP:    MagicNumber 0x4818A8F9 (0x05064818A8F9)
*Sep  9 17:15:47.320: Se0/0/1:1 LCP:    EndpointDisc 1 3845-1 (0x130901333834352D31)
*Sep  9 17:15:47.320: Se0/0/1:1 LCP: O CONFACK [Listen] id 8 len 22
*Sep  9 17:15:47.336: Se0/0/1:1 LCP: I CONFACK [ACKsent] id 2 len 28
*Sep  9 17:15:47.336: Se0/0/1:1 LCP:    AuthProto CHAP (0x0305C22305)
*Sep  9 17:15:47.336: Se0/0/1:1 LCP:    MagicNumber 0x4818A8F9 (0x05064818A8F9)
*Sep  9 17:15:47.336: Se0/0/1:1 LCP:    MRRU 1524 (0x110405F4)
*Sep  9 17:15:47.336: Se0/0/1:1 LCP:    EndpointDisc 1 3845-1 (0x130901333834352D31)
*Sep  9 17:15:47.336: Se0/0/1:1 LCP: State is Open
*Sep  9 17:15:47.336: Se0/0/1:1 PPP: Phase is AUTHENTICATING, by this end
*Sep  9 17:15:47.336: Se0/0/1:1 CHAP: O CHALLENGE id 2 len 27 from "3845-1"
*Sep  9 17:15:47.356: Se0/0/1:1 CHAP: I RESPONSE id 2 len 26 from "Param"
*Sep  9 17:15:47.356: Se0/0/1:1 PPP: Phase is FORWARDING, Attempting Forward
*Sep  9 17:15:47.356: Se0/0/1:1 PPP: Phase is AUTHENTICATING, Unauthenticated User
*Sep  9 17:15:47.356: Se0/0/1:1 PPP: Sent CHAP LOGIN Request
3845-1#
*Sep  9 17:15:47.356: Se0/0/1:1 PPP: Received LOGIN Response PASS
*Sep  9 17:15:47.356: Se0/0/1:1 PPP: Phase is AUTHENTICATING, Authenticated User
*Sep  9 17:15:47.356: Se0/0/1:1 PPP: Sent LCP AUTHOR Request
*Sep  9 17:15:47.356: Se0/0/1:1 LCP: Received AAA AUTHOR Response PASS
*Sep  9 17:15:47.356: Se0/0/1:1 CHAP: O SUCCESS id 2 len 4
*Sep  9 17:15:47.356: Se0/0/1:1 PPP: Phase is VIRTUALIZED
*Sep  9 17:15:47.356: Vi1 MLP: Added link Se0/0/1:1 to bundle Param
*Sep  9 17:15:47.356: Se0/0/1:1 PPP: Process pending ncp packets
*Sep  9 17:15:48.356: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/1:1, changed state to up
3845-1#
3845-1#sh users
  Vi1          Param              MLP Bundle   00:00:16 100.1.1.7
  Se0/0/1:1    Param              Sync PPP     -        Bundle: Vi1
  con 0          -                  -         -         -
  tty 0/514      -                  -         -         -
  Se0/0/1:1      Param              -         -         -
  Vi1            Param              00:10:00  00:09:40  Dialer idle
Virtual-Access1
  Bundle name: Param
  Bundle up for 00:01:32, total bandwidth 128, load 1/255
  Receive buffer limit 24384 bytes, frag timeout 1524 ms
    0 lost fragments, 1 reordered
    0x2 received sequence, 0x0 sent sequence
  Member links: 2 (max not set, min not set)
    Se0/0/1:0, since 00:01:32
    Se0/0/1:1, since 00:00:26
3845-1#sh int virtual-access 1
Virtual-Access1 is up, line protocol is up
  Hardware is Virtual Access interface
  MTU 1500 bytes, BW 128 Kbit/sec, DLY 20000 usec,
  Encapsulation PPP, LCP Open, multilink Open
  Open: IPCP, CDPCP
  MLP Bundle vaccess, cloned from Serial0/0/1:23
  Vaccess status 0x40, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 5 seconds on reset
  Time to interface disconnect: idle 00:09:26
  Last input 00:00:31, output never, output hang never
  Last clearing of "show interface" counters 5d18h
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 96 kilobits/sec
     117 packets input, 12384 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     116 packets output, 11752 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
3845-1#sh caller user Param detail
  User: Param, line Se0/0/1:0, service PPP
        Connected for 00:02:06, Idle for 00:00:58
  Timeouts:    Limit     Remaining Timer Type
  PPP: LCP Open, multilink Open, CHAP (<-)
  LCP: -> peer, AuthProto, MagicNumber, MRRU, EndpointDisc
       <- peer, MagicNumber, MRRU, EndpointDisc
  NCP: Closed IPCP, CDPCP
  Dialer: Connected to 4087775100, inbound
          Type is ISDN, group Se0/0/1:23
  IP: Local 100.1.1.1
  Bundle: Member of Param
  Counts: 209 packets input, 18576 bytes, 0 no buffer
          1 input errors, 1 CRC, 0 frame, 0 overrun
          210 packets output, 17789 bytes, 0 underruns
  User: Param, line Se0/0/1:1, service PPP
        Connected for 00:00:59, Idle for 00:00:58
  IP: Local 100.1.1.1
  Counts: 28 packets input, 1932 bytes, 0 no buffer
          30 packets output, 1687 bytes, 0 underruns
  User: Param, line Vi1, service MLP Bundle
        Connected for 00:02:06, Idle for 00:01:00
               00:10:00  00:08:59  Dialer idle
  PPP: LCP Open, multilink Open, IPCP, CDPCP
  LCP: -> peer
       <- peer
  NCP: Open IPCP, CDPCP
  IPCP: <- peer, Address
        -> peer, Address
          Type is IN-BAND SYNC, group Se0/0/1:23
  IP: Local 100.1.1.1, remote 100.1.1.7
  Bundle: Bundle Param, 2 links
  Counts: 117 packets input, 12384 bytes, 0 no buffer
          117 packets output, 12116 bytes, 0 underruns
3845-1#show isdn status
<snip>
ISDN Serial0/1/0:23 interface
        dsl 1, interface ISDN Switchtype = primary-5ess
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 1 CCBs = 0
    The Free Channel Mask:  0x00000000
    Number of L2 Discards = 0, L2 Session ID = 0
ISDN Serial0/0/1:23 interface
        dsl 2, interface ISDN Switchtype = primary-5ess
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        2 Active Layer 3 Call(s)
        CCB:callid=16, sapi=0, ces=0, B-chan=1, calltype=DATA, hdlctype=HDLC-TRUNK
        CCB:callid=17, sapi=0, ces=0, B-chan=2, calltype=DATA, hdlctype=HDLC-TRUNK
    Active dsl 2 CCBs = 2
    The Free Channel Mask:  0x807FFFFC
    Number of L2 Discards = 0, L2 Session ID = 3
    Total Allocated ISDN CCBs = 2
Beginner
This document is called:
Components Used
·Cisco 3845 with VWIC2-2MFT-T1/E1 and PVDM2-64 running IOS® Software Release 12.4(24)T1
·Cisco 2811 with WIC-1B-U-V2 running IOS® Software Release 12.4(7h)
My question now is:  Is a PVDM2 module actually needed to support ISDN data-only calls???
