INSTALL LICENSE ON CSR 1000v ( for security license, other license also same method)
Step 1: copy the license file to CSR1000v
Step 2: Install the license
Router#license install bootflash:9XXXXXX_XXXXXXXX.lic
Router#sh lice detail
Index: 1 Feature: sec_5G Version: 1.0
License Type: Permanent
Start Date: N/A, End Date: Jun 15 2020
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Store Index: 0
Store Name: Primary License Storage
Step 3:
Router#config t
Router(config)#license boot level security
Router(config)#license accept end user agreement
Router# write memory
Router#reload
Router#
Router#
Router# show verison
Router# sh platform hardware throughput level
The current throughput level is 5000000 kb/s
Router#
Router#
///summary
conf t
end
wr me
reload
if the throughput level is not changed from 100kbps(default) then use the manual method( below command).
conf t
platform hardware through level MB 5000
end
wr me
show platform hardware throughput level
>> it will show the
If still not shows the correct throughput level reload the Router
**for more details about licensing refer the below
http://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/b_CSR1000v_Configuration_Guide/b_CSR1000v_Configuration_Guide_chapter_01000.html#d21979e4851a1635
For Licensing/Ordering Part# -- follow the datasheet
Cisco Cloud Services Router 1000v Data Sheet - Cisco
