DTECH M3-PM-RTR3C Datasheet
317
The M3-PM-RTR3C (also referenced as M3-PM-RTR3CG) provides network routing support in the M3C4G system. It is based on Cisco® 5915 Embedded Services Router (5915 ESR) and Cisco ESS 2020 (ESS 2020) switch technology, offering enterprise-strength security. Four, of the Fast Ethernet ports (labeled SW PORTS PoE 4-7) are PoE injected, with a combined power, (on all four) of less than 50 W maximum, which follows the IEEE 802.3at PoE standard. This provides reliable operations under shock and vibration conditions typical for mobile applications. The M3-PM-RTR3C provides:
  • Low-power consumption
  • Streaming multicast video support
  • Modular
  • Remote voice services with Cisco Unified CME
  • Security to protect the network and transmitted data
The M3-PM-RTR3CG supports IPSec, SSL/TLS, SRTP, 3DES, AES, and IKE security protocols.
Content for Community-Ad
August's Community Spotlight Awards
