Ask the Expert- SD-WAN
Error Message:%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface <interface> Power Controller reports power Imax error detected
34160
Introduction
This document explains the solution for the error message %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error,
Interface <interface> Power Controller reports power Imax error detected.
Core Issue
Power Imax / Tstart errors may be reported with some third party PDs.
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error,Interface <interface>
For Example:
Log:
Sep 21 22:25:13.675 GMT:%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error,
Interface Fa0/15:  Power Controller reports power Imax error detected
Explanation
You are hitting the bug CSCsw18530 : Power Imax / Tstart errors may be reported with some third party PDs
This error indicates that PD is drawing over-current more than allowed/supported per IEEE 802.3af standard.
Seen with some of the 3750,3750G,3750-E,3560-E, 3750-X, 3560-X, 3560-C, 2960S, 2960,2960C switches.
Resolution
This issue is fixed in 12,2(55)SE3 , 12.2(58)SE1 and later releases. The following interface configuration commands have to be applied
to resolve the issue,
Switch(config)# int x/y
Switch(config-if)# power inline port 2x-mode
Switch(config-if)# shut
Switch(config-if)# no shut
The fix is present in the following platforms only : 3750-E,3560-E, 3750-X, 3560-X, 3560-C, 2960S, 2960,2960C.The other platforms
do not support 2X power mode and the workaround would be to use a longer cable.Possible workaround is using Longer cable (>50ft)
seems to fix the issue in most cases.
Source: https://supportforums.cisco.com/thread/157276
Related Information
Troubleshooting Power over Ethernet
Please tell me what is this 2x mode which we defined after power inline command ???
What does it specify., I am aware about static and never but not about 2x mode.
Getting the same error on
15.0(2)SE2 3750 v2 48PS
Beginner
Same problems on C3560-48PS, running 12.2(55)SE6.
No possibillity to configure mentioned configuration on the interface.
We've than exchanged the switch, but problem still occured on the same port.
So might be the end-device be the problem? (Alcatel ipTouch)
Beginner
I am running 12.2 (55)SE3 code on a 2960s stack with the power inline 2x-mode configured on the interface and still getting a consistent "Tstart error condition"
the PD is an Ingenico iSC Touch 480
Beginner
We are having trouble with Ingenico iSC Touch 480 as well.
Switch :
WS-C3850-12X48U    03.07.02E
Log message :
*Jan 12 09:45:17.734: %ILPOWER-7-DETECT: Interface Gi1/0/4: Power Device detected: IEEE PD
*Jan 12 09:45:18.596: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/4: PD removed
test cable diagnostic output :
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/4 auto Pair A 0 +/- 1 meters N/A Normal
Pair B 0 +/- 1 meters N/A Normal
Pair C 1 +/- 1 meters N/A Short
Pair D 2 +/- 1 meters N/A Short
Same issue here too.  Ingenico iSC Touch 480.
Switch:
WS-C2960X-24PS-L
15.0(2a)EX5
Log Messages:
%ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi1/0/1: Power Controller reports power Tstart error detected
Show power inline:
Gi1/0/1   auto   faulty     0.0     n/a                 n/a   30.0
test cable tdr output:
Gi1/0/1   auto  Pair A     N/A                N/A         Normal
                Pair B     N/A                N/A         Normal
                Pair C     1    +/- 10 meters N/A         Short
                Pair D     1    +/- 10 meters N/A         Short
Anyone have any resolution to this yet?
Beginner
It ended up being an issue with the Ingenico device. They were able to identify which devices had the issue by the serial number.
I am seeing this on a a  WS-C3560G-24PS-S with a Meraki MR42, also saw it on a 3750 and swaped switch out to the 3560G, hoping to fix it.
IOS version
Switch Ports Model SW Version SW Image
* 1 28 WS-C3560G-24PS 15.0(2)SE8 C3560-IPSERVICESK9-M
*Mar 1 03:58:31.149: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi0/3: Power Controller reports power Imax error detected
*Mar 1 03:58:41.106: %ILPOWER-7-DETECT: Interface Gi0/3: Power Device detected: IEEE PD
Content for Community-Ad
July's Community Spotlight Awards
