GRE - Recursive loops
18950
Introduction
This document provides you an example configuration on how to overcome recursive routing issue while using GRE tunnels.
Prerequisites
It is assumed that reader already has knowledge of routing protocols and is aware of GRE configuration.
Components used
Cisco 3700 series Router loaded with IOS 12.4(2)T has been used for this document.
Configuration
For Initial configuration, these routers are learning all the routes using RIP protocol. If you are interested in seeing initial configuration, please have a look at the files attached.
Now let’s suppose R1 and R3 have networks connected behind them and both router R1 and R3 need to know about all those networks and because of scalability issues that we have with RIP protocol, we need to run some other protocol. Let that protocol be EIGRP. Also, let’s suppose that because of resources limitation we can’t run EIGRP on R2. So you decide to use GRE tunnel between routers R1 and R3.
Here is the configuration for the same:
R1R3
interface Tunnel13
ip address 100.1.13.1 255.255.255.0
tunnel source Loopback0
tunnel destination 3.3.3.3
end
interface Tunnel31
ip address 100.1.13.3 255.255.255.0
tunnel destination 1.1.1.1
end
Now as soon as we enable EIGRP and run it on tunnel interface and the loo 0 interface, we get following error:
This happens because the tunnel interface status depends on the reachability to tunnel destination. In our case R1 and R3 find reachability to tunnel destination using RIP. As soon as we enable EIGRP on loo 0 interfaces, the routers find reachability to tunnel destination through tunnel and that’s what causes the recursive loop.
To overcome this situation, an access-list in configured which identifies the IP add of tunnel destination. Then, AD of this route is configured lower than EIGRP. Once this is done router find better path to tunnel destination throught RIP and tunnel comes up (you may have to clear routing table at this point).
R1R3
R1#show access-lists
Standard IP access list 1
10 permit 3.0.0.0 (100 matches)
R1#show run | sec rip
router rip
version 2
network 1.0.0.0
network 10.0.0.0
distance 89 0.0.0.0 255.255.255.255 1
no auto-summary
R3#show access-list
10 permit 1.0.0.0 (98 matches)
R3#sho run | sec rip
router rip
version 2
network 3.0.0.0
network 10.0.0.0
no auto-summary
Network Diagram
Verify
Here, you can see the routing table of R1 and R3
I hope you found this worth your time, thank you!
Related Information
        How to configure a GRE tunnel
Very nice and lucid explanation Pulkit.
Thanks Imran!
Beginner
On some devices you won't see the recursive routing log, instead will only see this one:
 ADJ-5-PARENT  Midchain parent maintenance for IP
midchain out of TunnelXXX - looped chain attempting to stack
Just wanted to add it here in case someone is googling for the above message
Participant
Good one thanks Pulkit
Content for Community-Ad
July's Community Spotlight Awards
