How to Allow pinging of PC-A to Router 1?
650
Question
There are two PC's on different subnet masks and the Multilayer switch is how I am doing the routing for them to ping. However whenever I try and ping the router, it always comes back with 'host destination unreachable'. For this particular test i am trying to implement an ACL and know that it is possible on the MLS but then the routing seems to be disabled. Any advice for either reaching the router or implementing the ACL on the MLS?
Answer
Engager
Hi @JT4 ,
To achieve ping between the PCs, you only have to assign the correct IP gateway on the PCs (currently both have the IP 10.0.0.2).
On the vlan 10 PC you must assign the IP gateway 10.0.0.114
On the vlan 20 PC you must assign the IP gateway 10.0.0.98
The IP gateway address must match the IP configured in the MLS vlan interfaces
JT4 Beginner
Beginner
Hi @luis_cordova,
Thank you for helping me with that issue but Im still stuck on the issue of not being able to get past the MLS to the router, any advice on that front?
Engager
Hi @JT4 ,
To achieve communication with the router you must configure a routing protocol, such as RIPv2:
Router1
router rip
version 2
network 192.168.1.0
no auto-summary
MLS
interface GigabitEthernet0/1
no switchport  <--This command disables the layer 2 functions of the interface and enables it as a router interface
ip address 192.168.1.11 255.255.255.0
Multi-layer(config)#router rip
Multi-layer(config-router)#no auto-summary
Multi-layer(config-router)#version 2
Multi-layer(config-router)#net 10.0.0.0
Multi-layer(config-router)#net 10.0.0.64
Multi-layer(config-router)#net 10.0.0.96
Multi-layer(config-router)#net 10.0.0.112
Multi-layer(config-router)#net 10.0.0.120
Multi-layer(config-router)#net 192.168.1.0
Multi-layer(config-router)#ex
Content for Community-Ad
