How to configure a GRE tunnel
409059
Introduction:
Tunneling provides a mechanism to transport packets of one protocol within another protocol. The protocol that is carried is called as the passenger protocol, and the protocol that is used for carrying the passenger protocol is called as the transport protocol. Generic Routing Encapsulation (GRE) is one of the available tunneling mechanisms which uses IP as the transport protocol and can be used for carrying many different passenger protocols. The tunnels behave as virtual point-to-point links that have two endpoints identified by the tunnel source and tunnel destination addresses at each endpoint.
The below diagram shows encapsulation process of GRE packet as it traversers the router and enters the tunnel interface:
Configuring GRE Tunnel:
Configuring a GRE tunnel involves creating a tunnel interface, which is a logical interface. Then you must configure the tunnel endpoints for the tunnel interface.
To configure the tunnel source and destination, issue the tunnel source {ip-address | interface-type} and tunnel destination {host-name | ip-address} commands under the interface configuration mode for the tunnel.
The below example explain about how to create simple GRE tunnels between endpoints and the necessary steps to create and verify the GRE tunnel between the two networks.R1's and R2's Internal subnets(192.168.1.0/24 and 192.168.2.0/24) are  communicating with each other using GRE tunnel over internet.Both Tunnel interfaces are part of the 172.16.1.0/24 network.
First step is to create our tunnel interface on R1 and R2 :
R1R2
R1(config)# interface Tunnel1
R1(config-if)# ip address 172.16.1.1 255.255.255.0
R1(config-if)# ip mtu 1400
R1(config-if)# ip tcp adjust-mss 1360
R1(config-if)# tunnel source 1.1.1.1
R1(config-if)# tunnel destination 2.2.2.2
R2(config)# interface Tunnel1
R2(config-if)# ip address 172.16.1.2 255.255.255.0
R2(config-if)# ip mtu 1400
R2(config-if)# ip tcp adjust-mss 1360
R2(config-if)# tunnel source 2.2.2.2
R2(config-if)# tunnel destination 1.1.1.1
Since GRE is an encapsulating protocol, we adjust the maximum transfer unit (mtu) to 1400 bytes and maximum segment size (mss) to 1360 bytes. Because most transport MTUs are 1500 bytes and we have an added overhead because of GRE, we must reduce the MTU to account for the extra overhead. A setting of 1400 is a common practice and will ensure unnecessary packet fragmentation is kept to a minimum.
After configuring tunnel,two tunnel endpoints can see each other can verify using an icmp echo from one end.
R1# ping 172.16.1.2
Sending 5, 100-byte ICMP Echos to 172.16.1.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Workstations on either network will still not be able to reach the other side unless a routing is configure on each router.Here We will configure static route on both router.
R1(config)# ip route 192.168.2.0 255.255.255.0 172.16.1.2
R2(config)# ip route 192.168.1.0 255.255.255.0 172.16.1.1
Now both networks (192.168.1.0/24 and 192.168.2.0/24) are able to freely communicate with each other over the GRE Tunnel .
Reference:
mmehdar77
Beginner
Thanks , very helpful.
keithsauer507
Contributor
Can you do this on an ehwic card?
I'm trying to simulate it in Cisco Packet Tracer Student 6.1 before rolling it into production.  Have a simulation of two 2811's with the same config as production on.
Issue when I go to specify the tunnel source it says Invalid input detected at '^' marker.  So running tunnel source ? shows it's looking for an interface name, not an ip address.
Well I have an HWIC card in the simulation and on Fa0/2/2 I have a cable going to another router where I am trying to gre tunnel over.  Issue is, if I specify Fa0/2/2 it says %ERROR: Source interface does not exist.  But clearly I can go into that interface and clearly I can ping the router connected to that interface!!!!
nagak
Really helpful info.
Thanks for posting.
You should use Loopback for source and destination interface for a better stability
Bony Varghese
Community Member
Thanks helpful :)
rooseveltmc
Community Member
Please note this example GRE tunnel is not encrypted.
You don't want to set this up over a Public Internet without additional encryption such as IPSEC.
https://www.youtube.com/watch?v=2PtK8HgkRvM
h_boulfrakh
Community Member
Hi , Tks for posting :)
But ,
I really want to know what I need as a prerequisite or special  configuration in the case of a GRE tunnel between two public IP address (two different wan)
Configuration :
R1 :
wan : @IP1 ..........@tunnel : 192.168.200.1/30.................@tunnel dest : @IP2
R2 :
wan : @IP2...............@tunnel 192.168.200.2/30....................@tunneldest: @IP1
it does not ping between points of tunnel  !!!!!!
Is what I need something from the provider?
Thanks.
Lost & Found
Beginner
Hi.
Ive tried to configure Gre tunnel on out site 1 and 2 but both site has no connection.
All tunnel interface status is UP/UP
from isp router 2 ip can ping the int tunnel IP but ISP router 1 can't ping it's own tunnel address.
Is it fine to run with s0/0 interface?
Router 2 - 2800 and router 1 - 2600
Do i need to setup OSPF to ping r1-r2? or just static configuration?
Please see the attached photo for the configuration.
Yaron Golan
Beginner
Check your IP adresses of the Tunnels , They are the same. ( 10.10.1.2 ) gre.png (644×434)
victor melo
Beginner
cyberbench31
Beginner
check the settings of your routing protocol, you should broadcast tunnel interface and not the public interface on you routing protocol..
sam.craven.01
Beginner
I would look at your static/default route on both. That might be a reach but I have those statements on the configs that I am using.
I would also look at your ACL's, if any.
clay.haynes
Community Member
This is blogspam and links to copyrighted material. This post should be removed.
aman7uela
Beginner
GRE can encapsulate other protocols. But how can you prove it? Can you please use routers as small as 3 to show me that?
shubhamkumarhcl
Beginner
http://www.ccnaccnplinux.com
http://www.ccnaccnplinux.com/2015/04/gre-tunnel.html
if You visit i am sure you will get useful information
