Resolution
To configure Spanning Tree Protocol (STP) diameter on Cisco Catalyst switches that run Cisco IOS Software, issue the spanning-tree vlan vlan-id root primary diameter net-diameter command.
To configure STP diameter on Cisco Catalyst switches that run Catalyst OS (CatOS), issue the set spantree root vlan diameter network_diameter command.
