Resolution
Issue these commands to enable the 10-Gigabit Ethernet and/or the Gigabit Ethernet Small Form-Factor Pluggable (SFP) uplink ports:
Switch#configure terminal
Switch(config)#hw-module uplink select {tengigabitethernet|gigabitethernet|all}
Note: On a Catalyst 4510R Series Switch, if you enable both the 10-Gigabit Ethernet and Gigabit Ethernet SFP uplink ports, you must re-boot the switch. On the Catalyst 4503, 4506, and 4507R Series Switches, this capability is automatically enabled.
Port type
1000 TX
