Ask the Expert- SD-WAN
How To Get the Environment Temperature on a Nexus Using SNMP
5393
Information to capture the output "show environment temperature" using SNMP in Nexus devices.
Output of the show environment temperature Command Through the CLI
Note: You must be in enable mode in order to issue the show environment temperature command.
sh environment temperature
Temperature:
Module Sensor MajorThresh MinorThres  CurTemp Status
(Celsius) (Celsius) (Celsius)
    1      FRONT        60              42              37           Ok
    1      BACK           80              70              46           Ok
    1      CPU             90              80              49           Ok
    1      TD2            105             90               61           Ok
    1      DONNER   105             90               51           Ok
SNMP Output :
entPhysicalDescr (1.3.6.1.2.1.47.1.1.1.1.2)
SNMPv2-SMI::mib-2.47.1.1.1.1.2.21590 = STRING: "module-1 FRONT"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.21591 = STRING: "module-1 BACK"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.21592 = STRING: "module-1 CPU"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.21593 = STRING: "module-1 TD2"
SNMPv2-SMI::mib-2.47.1.1.1.1.2.21594 = STRING: "module-1 DONNER"
entSensorThresholdValue (1.3.6.1.4.1.9.9.91.1.2.1.1.4)
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21590.1 = INTEGER: 42
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21590.2 = INTEGER: 60
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21591.1 = INTEGER: 70
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21591.2 = INTEGER: 80
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21592.1 = INTEGER: 80
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21592.2 = INTEGER: 90
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21593.1 = INTEGER: 90
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21593.2 = INTEGER: 105
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21594.1 = INTEGER: 90
SNMPv2-SMI::enterprises.9.9.91.1.2.1.1.4.21594.2 = INTEGER: 105
entSensorValue (1.3.6.1.4.1.9.9.91.1.1.1.1.4)
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.21590 = INTEGER: 37
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.21591 = INTEGER: 46
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.21592 = INTEGER: 52
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.21593 = INTEGER: 62
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.21594 = INTEGER: 51
entSensorStatus (1.3.6.1.4.1.9.9.91.1.1.1.1.5)
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.5.21590 = INTEGER: 1 (ok)
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.5.21591 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.5.21592 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.5.21593 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.5.21594 = INTEGER: 1
Note: This document uses these MIBs:
CISCO-ENTITY-SENSOR-MIB
ENTITY-MIB
Claudio Gonzalez S
Beginner
Thanks.
How do we artificially configure a lower threshold to force the generation of an 'entSensorThresholdNotification' SNMP trap?
Content for Community-Ad
July's Community Spotlight Awards
