TCC_2
Level 10
Level 10
Core issue
This document discusses how to use the GOLD diagnostics online testing  feature to identify possible hardware issues and capture the test output for Technical Support  engineer review.
Online diagnostics are categorized as bootup, on-demand,  schedule, or health monitoring diagnostics. Bootup diagnostics run during bootup,  module Online Insertion and Removal (OIR), or switchover to a backup supervisor engine. On-demand diagnostics  run from the Command Line Interface (CLI). Schedule diagnostics run at user-designated intervals or  specified times when the switch is connected to a live network. Health-monitoring runs in the background.
This scenario displays examples using on-demand diagnostics to  troubleshoot possible hardware failures and captures the test results for Technical Support  review if a service request is required.
Resolution
When a switch component exhibits symptoms of possible hardware failure,  additional diagnostics tests should be performed to confirm the issue is hardware  related and rule out other causes of the symptoms.
Some tests disrupt network activity, so it is important to verify that the  test you run does not affect your current network traffic.
Runtime diagnostic checks can be run on demand or scheduled to run at a  specific time. They can run continually in the background. When a module or  supervisor exhibits failure symptoms or an error message is received, the test can  usually be performed on demand.
Issuing a diagnostic start command triggers on-demand diagnostics tests  statically. Specify how many times a test runs and whether to continue running  the test upon failure detection. On-demand diagnostics is useful primarily as a  troubleshooting tool to verify hardware functions when an administrator suspects  a hardware fault.
On-demand diagnostics does not cause the faulty hardware to reset or power down the Cisco Catalyst 6500 series. Syslog messages warn about the faulty hardware, and the administrator needs to check the  diagnostics results to see if the tests pass or fail, and then take appropriate action. As an example, this command triggers two on-demand module memory tests (test number 12) on a module in slot 2. If the first memory test fails, no further testing is performed, as shown:
Router#diagnostic ondemand iterations 2
Router#diagnostic ondemand action-on-failure stop
Router#diagnostic start module 2 test ?
Router#diagnostic start module 2 test 12
To display the test suite and the monitoring interval and test attributes for  the module, issue the show diagnostic content command. This example shows how to display the test suite and the monitoring interval and test attributes:
Router# show diagnostic content module       1
Diagnostic Tests List for Module 1:
Module 1:
Diagnostics test suite attributes:
M/C/* - Minimal level test / Complete       level test / Not applicable
B/* - Bypass bootup test / Not       applicable
P/* - Per port test / Not applicable
D/N - Disruptive test / Non-disruptive       test
S/* - Only applicable to standby unit /       Not applicable
X/* - Not a health monitoring test /       Not applicable
F/* - Fixed monitoring interval test /       Not applicable
E/* - Always enabled monitoring test /       Not applicable
A/I - Monitoring is active / Monitoring       is inactive
Testing Interval
ID Test Name Attributes (day       hh:mm:ss.ms)
1) TestDummy1 ---------------------->       M**D****A 000 00:01:00.000
2) TestDummy2 ---------------------->       M**D**FEA 000 00:02:30.000
3) TestGBICIntegrity --------------->       *BPD****I not configured
4) TestActiveToStandbyLoopback ----->       M*PDS***I not configured
5) TestLoopback -------------------->       M*PD****I not configured
6) TestNewLearn -------------------->       M**N****I not configured
7) TestIndexLearn ------------------>       M**N****I not configured
8) TestConditionalLearn ------------>       M**N****I not configured
9) TestBadBpdu --------------------->       M**D****I not configured
10) TestCapture --------------------->       M**D****I not configured
11) TestProtocolMatch --------------->       M**D****I not configured
12) TestChannel --------------------->       M**D****I not configured
13) TestDontShortcut ---------------->       M**N****I not configured
14) TestL3Capture2 ------------------>       M**N****I not configured
15) TestL3VlanMet ------------------->       M**N****I not configured
16) TestIngressSpan ----------------->       M**N****I not configured
17) TestEgressSpan ------------------>       M**N****I not configured
18) TestAclPermit ------------------->       M**N****I not configured
19) TestAclDeny --------------------->       M**D****I not configured
20) TestNetflowInlineRewrite -------->       C*PD****I not configured
Router#
This example shows how to start a diagnostic test on a specific module:
Router# diagnostic start module 1 test       5
Module 1:Running test(s) 5 may disrupt       normal system operation
Do you want to run disruptive tests? [no]yes
00:48:14:Running OnDemand Diagnostics       [Iteration #1] ...
00:48:14:%DIAG-SP-6-TEST_RUNNING:Module       1:Running TestNewLearn{ID=5} ...
00:48:14:%DIAG-SP-6-TEST_OK:Module       1:TestNewLearn{ID=5} has completed successfully
00:48:14:Running OnDemand Diagnostics       [Iteration #2] ...
Router#
This example shows how to display the online diagnostic results for a module:
Router# show diagnostic result module 5
Current bootup diagnostic level:minimal
Module 5:
Overall Diagnostic Result for Module 5       ASS
Diagnostic level at card bootup:minimal
Test results:(. = Pass, F = Fail, U =       Untested)
1) TestScratchRegister -------------> .
2) TestSPRPInbandPing --------------> .
3) TestGBICIntegrity:
Port 1 2
U U
4) TestActiveToStandbyLoopback:
Port 1 2
U U
5) TestLoopback:
Port 1 2
6) TestNewLearn --------------------> .
7) TestIndexLearn ------------------> .
8) TestDontLearn -------------------> .
9) TestConditionalLearn ------------> .
10) TestBadBpdu --------------------->       .
11) TestTrap ------------------------>       .
12) TestMatch ----------------------->       .
13) TestCapture --------------------->       .
14) TestProtocolMatch --------------->       .
15) TestChannel --------------------->       .
16) TestIPv4FibShortcut ------------->       .
17) TestL3Capture2 ------------------>       .
18) TestL3VlanMet ------------------->       .
19) TestIngressSpan ----------------->       .
20) TestEgressSpan ------------------>       .
21) TestIPv6FibShortcut ------------->       .
22) TestMPLSFibShortcut ------------->       .
23) TestNATFibShortcut -------------->       .
24) TestAclPermit ------------------->       .
25) TestAclDeny --------------------->       .
26) TestQoSTcam --------------------->       .
27) TestNetflowInlineRewrite:
Port 1 2
U U
28) TestFabricSnakeForward ---------->       .
29) TestFabricSnakeBackward --------->       .
30) TestFibTcam - RESET ------------->       U
Router#
This example shows how to display the       detailed online diagnostic results for a module:
Router# show diagnostic result module 5       detail
Module 5:
___________________________________________________________________________
Error code ------------------> 0 (DIAG_SUCCESS)
Total run count -------------> 330
Last test execution time ----> May 12       2003 14:49:36
First test failure time -----> n/a
Last test failure time ------> n/a
Last test pass time ---------> May 12       2003 14:49:36
Total failure count ---------> 0
Consecutive failure count ---> 0
Total run count -------------> 660
Last test execution time ----> May 12       2003 14:49:38
Last test pass time ---------> May 12       2003 14:49:38
Port 1 2
U U
Total run count -------------> 0
Last test execution time ----> n/a
Last test pass time ---------> n/a
Router#
Scheduled diagnostics tests run at either one specific time or periodically. This is useful when scheduling disruptive tests during maintenance windows. When failures are detected, appropriate syslog  messages are displayed. Diagnostics results can be accessed by issuing the show  diagnostic result command on the switch. Scheduled diagnostics does not cause  the faulty hardware to reset or power down the Cisco Catalyst 6500 series. This CLI schedules a loopback test (test number 1) on a module situated in module 2 every Monday at 3 a.m., as shown:
Router(config)#diagnostic schedule       module 2 test 1 weekly MON 03:00
Once testing is complete, capture the test results. If opening a Technical Support case,  include the test results as a case attachment.
For more information on online diagnostics, refer to Generic Online Diagnostics on the Cisco Catalyst 6500 Series Switch.
For detailed configuration options, refer to Configuring Online Diagnostics.
