thulsdau
This how-to is a step-by-step guide to setup a so-called TransitVNET in Microsoft Azure with CSR 1000v and Azure Internal Load Balancer (ILB).
Solution Description
The goal of this solution is to have a scalable and highly available way of interconnecting VNETs in Azure to each other and back to an on-premise network (i.e. via IPSec). This is achieved by placing an Internal Load Balancer between the application / spoke VNETs and the CSR 1000v virtual routers in the TransitVNET.
Please consider the following diagram for the specific setup used in this how-to:
  • Two spoke VNETs (SpokeVNET1 & SpokeVNET2), both house one VM each.
  • One TransitVNET housing two CSR 1000v routers (CSR1 & CSR2) and one Internal Load Balancer (ILB).
  • One on-premise Datacenter housing a random (Cisco) router (e.g. ASR 1000 or ISR 4000).
    • Note: Configuration and Setup of the on-premise router and IPSec connection are not covered in this how-to and left as an exercise to the reader.
  • VNET peering is configured between each spoke VNET and the TransitVNET. This means, that there is direct IP connectivity between each spoke VNET and the TransitVNET and that no tunneling is needed between them. Subnets must not overlap.
  • A UDR (user-defined route table) is setup in each spoke VNET. The next-hop of the route to the on-premise network (10.0.0.0/8 in this case) points to the VIP (virtual IP) of the ILB.
  • The ILB is setup in a way that it will forward all protocols and ports coming in on the VIP to the CSRs using load balancing. This makes the solution scalable from one CSR to multiple CSRs.
  • The ILB will do a health check of each CSR by periodically connecting to port 80/TCP. If one of the CSRs is not reachable, it will be taken out of service. This makes the solution highly available.
Traffic flow from spoke VNET to the on-premise DC is via the ILB:
Traffic flow from the on-premise DC to the spoke VNETs is direct, leveraging the VNET peering and bypassing the ILB:
Prerequisites
Step-by-step instructions to setup TransitVNET, ILB & CSRs
Note: To help in setting this solution up as quickly as possible for testing or reference, a convenient shell script is attached to this post. Please see section "Automating the setup" for details below.
1. Create resource group, TransitVNET and two subnets
echo Creating resource group...
az group create --name TVNET --location EastUS
echo Creating VNET...
az network vnet create --name TransitVNET --resource-group TVNET --address-prefix 10.0.0.0/23
echo Creating inside subnet...
az network vnet subnet create --address-prefix 10.0.0.0/24 --name OutsideSubnet --resource-group TVNET --vnet-name TransitVNET
echo Creating outside subnet...
az network vnet subnet create --address-prefix 10.0.1.0/24 --name InsideSubnet --resource-group TVNET --vnet-name TransitVNET
2. Create the internal load balancer with HA port
echo Creating Azure Internal Load Balancer...
az network lb create --name TVNET_ILB --resource-group TVNET --sku Standard --private-ip-address 10.0.1.254 --vnet-name TransitVNET --subnet InsideSubnet --backend-pool-name ILBBackendpool
echo Creating ILB health probe to connect to port 80 with minimal possible interval... az network lb probe create --resource-group TVNET --lb-name TVNET_ILB --name ILBHealthProbe --protocol tcp --port 80 --interval 5 --threshold 2
echo Creating ILB rule to forward all packets to the CSRs... az network lb rule create --resource-group TVNET --lb-name TVNET_ILB --name ILBPortsRule --protocol All --frontend-port 0 --backend-port 0 --backend-pool-name ILBBackendpool --probe-name ILBHealthProbe
3. Create NSG (Network Security Groups)
echo Creating network security group for outside subnet...
az network nsg create --resource-group TVNET --name OutsideSubnetNSG --location EastUS
echo Creating nsg rule Allow_IPSEC1 ...
az network nsg rule create --resource-group TVNET --nsg-name OutsideSubnetNSG --name Allow_IPSEC1 --access Allow --protocol udp --direction Inbound --priority 100 --source-address-prefix * --source-port-range * --destination-address-prefix * --destination-port-range 500
echo Creating nsg rule Allow_IPSEC2...
az network nsg rule create --resource-group TVNET --nsg-name OutsideSubnetNSG --name Allow_IPSEC2 --access Allow --protocol udp --direction Inbound --priority 110 --source-address-prefix * --source-port-range * --destination-address-prefix * --destination-port-range 4500
echo Creating nsg rule Allow_SSH... az network nsg rule create --resource-group TVNET --nsg-name OutsideSubnetNSG --name Allow_SSH --access Allow --protocol tcp --direction Inbound --priority 120 --source-address-prefix Internet --source-port-range * --destination-address-prefix * --destination-port-range 22
echo Creating nsg rule Allow_All_Out... az network nsg rule create --resource-group TVNET --nsg-name OutsideSubnetNSG --name Allow_All_Out --access Allow --protocol * --direction Outbound --priority 140 --source-address-prefix * --source-port-range * --destination-address-prefix * --destination-port-range *
echo Creating network security group for inside subnet... az network nsg create --resource-group TVNET --name InsideSubnetNSG --location EastUS
echo Creating nsg rule Allow_All_Out (2)... az network nsg rule create --resource-group TVNET --nsg-name InsideSubnetNSG --name Allow_All_Out --access Allow --protocol * --direction Outbound --priority 140 --source-address-prefix * --source-port-range * --destination-address-prefix * --destination-port-range *
4. Create file with initial IOS-XE config
cat >csr_customdata_temp.txt <<endofcustemdata
Section: IOS configuration
! Azure sources the ILB probes from 168.63.129.16
ip route 168.63.129.16 255.255.255.255 10.0.1.1
! Static routing towards the spoke VNETs pointing out the internal interface
!! Do not forget to create new static routes if you create new spoke VNETs !! ip route 10.0.2.0 255.255.255.0 10.0.1.1
ip route 10.0.3.0 255.255.255.0 10.0.1.1 endofcustemdata
5. Create the two CSRs
(including public IPs, NICs and availability set)
echo Creating public IP for CSR1...
az network public-ip create --name CSR1PublicIP --resource-group TVNET --idle-timeout 30 --allocation-method Static --sku standard
echo Creating public IP for CSR2... az network public-ip create --name CSR2PublicIP --resource-group TVNET --idle-timeout 30 --allocation-method Static --sku standard
echo Creating outside interface for CSR1... az network nic create --name CSR1OutsideInterface -g TVNET --subnet OutsideSubnet --vnet TransitVNET --public-ip-address CSR1PublicIP --private-ip-address 10.0.0.4 --ip-forwarding true --network-security-group OutsideSubnetNSG --accelerated-networking true
echo Creating inside interface for CSR1... az network nic create --name CSR1InsideInterface -g TVNET --subnet InsideSubnet --vnet TransitVNET --ip-forwarding true --private-ip-address 10.0.1.4 --network-security-group InsideSubnetNSG --lb-name TVNET_ILB --lb-address-pools ILBBackendpool --accelerated-networking true
echo Creating outside interface for CSR2... az network nic create --name CSR2OutsideInterface -g TVNET --subnet OutsideSubnet --vnet TransitVNET --public-ip-address CSR2PublicIP --private-ip-address 10.0.0.5 --ip-forwarding true --network-security-group OutsideSubnetNSG --accelerated-networking true
echo Creating inside interface for CSR2... az network nic create --name CSR2InsideInterface -g TVNET --subnet InsideSubnet --vnet TransitVNET --ip-forwarding true --private-ip-address 10.0.1.5 --network-security-group InsideSubnetNSG --lb-name TVNET_ILB --lb-address-pools ILBBackendpool --accelerated-networking true
echo Creating availability set... az vm availability-set create --resource-group TVNET --name CSRAvailabiliySet --platform-fault-domain-count 2 --platform-update-domain-count 2
echo Creating CSR1... az vm create --resource-group TVNET --location EastUS --name CSR1 --size Standard_DS4_v2 --nics CSR1OutsideInterface CSR1InsideInterface --image cisco:cisco-csr-1000v:16_10-byol:16.10.120190108 --authentication-type ssh --generate-ssh-keys --availability-set CSRAvailabiliySet --custom-data csr_customdata_temp.txt
echo Creating CSR2... az vm create --resource-group TVNET --location EastUS --name CSR2 --size Standard_DS4_v2 --nics CSR2OutsideInterface CSR2InsideInterface --image cisco:cisco-csr-1000v:16_10-byol:16.10.120190108 --authentication-type ssh --generate-ssh-keys --availability-set CSRAvailabiliySet --custom-data csr_customdata_temp.txt
Step-by-step instructions to setup the spoke VNETs and attach to ILB
1. Create two new spoke VNETs
(including subnets and Ubuntu VMs)
echo Creating VNET for Spoke1...
az network vnet create --name Spoke1VNET --resource-group TVNET --address-prefix 10.0.2.0/24 --output json
echo Creating subnet for Spoke1... az network vnet subnet create --address-prefix 10.0.2.0/24 --name Spoke1Subnet --resource-group TVNET --vnet-name Spoke1VNET --output json
echo Creating VNET for Spoke2... az network vnet create --name Spoke2VNET --resource-group TVNET --address-prefix 10.0.3.0/24
echo Creating subnet for Spoke2... az network vnet subnet create --address-prefix 10.0.3.0/24 --name Spoke2Subnet --resource-group TVNET --vnet-name Spoke2VNET
echo Creating instance Spoke1... az vm create -n Spoke1VM1 -g TVNET --image UbuntuLTS --vnet-name Spoke1VNET --size Standard_DS4_v2 --subnet Spoke1Subnet --accelerated-networking true
echo Creating instance Spoke2... az vm create -n Spoke2VM1 -g TVNET --image UbuntuLTS --vnet-name Spoke2VNET --size Standard_DS4_v2 --subnet Spoke2Subnet --accelerated-networking true
2. Setup peering between each spoke VNET and the TransitVNET
echo Setting up peering between TransitVNET and Spoke1...
az network vnet peering create -g TVNET -n TransitVNETtoSpoke1 --vnet-name TransitVNET --remote-vnet Spoke1VNET --allow-vnet-access
echo Setting up peering between Spoke1 and TransitVNET... az network vnet peering create -g TVNET -n TransitVNETtoSpoke1 --vnet-name Spoke1VNET --remote-vnet TransitVNET --allow-vnet-access --allow-forwarded-traffic
echo Setting up peering between TransitVNET and Spoke2... az network vnet peering create -g TVNET -n TransitVNETtoSpoke2 --vnet-name TransitVNET --remote-vnet Spoke2VNET --allow-vnet-access
echo Setting up peering between Spoke2 and TransitVNET... az network vnet peering create -g TVNET -n TransitVNETtoSpoke2 --vnet-name Spoke2VNET --remote-vnet TransitVNET --allow-vnet-access --allow-forwarded-traffic
3. Setup UDR in spoke VNETs
echo Creating route table for Spokes...
az network route-table create --name SpokeRT -g TVNET --location EastUS
echo Configuring route via the ILB... az network route-table route create -g TVNET --route-table-name SpokeRT -n ViaILB --next-hop-type VirtualAppliance --address-prefix 10.0.0.0/8 --next-hop-ip-address 10.0.1.254
echo Attaching route table to Spoke1Subnet... az network vnet subnet update --name Spoke1Subnet --resource-group TVNET --vnet-name Spoke1VNET --route-table SpokeRT
echo Attaching route table to Spoke2Subnet... az network vnet subnet update --name Spoke2Subnet --resource-group TVNET --vnet-name Spoke2VNET --route-table SpokeRT
Note: In this how-to we only route the 10.0.0.0/8 private network via the ILB to retain the ability to directly connect to the VMs from the Internet via ssh and to have direct internet access for the VMs.
4. Query all assigned IP addresses
(so we know where to connect to)
echo Getting IP addresses...
az vm list-ip-addresses -g TVNET --output table
VirtualMachine PrivateIPAddresses PublicIPAddresses
CSR1 10.0.1.4
CSR1 10.0.0.4 52.151.239.79
CSR2 10.0.1.5
CSR2 10.0.0.5 52.151.239.88
Spoke1VM1 10.0.2.4 40.114.8.96
Spoke2VM1 10.0.3.4 40.114.49.237
Verify
Perform the following steps to verify the setup
Verify the ILB resource health in the Azure portal:
Please see the following documentation for more options to check the health of your ILB: https://docs.microsoft.com/en-us/azure/load-balancer/load-balancer-standard-diagnostics
Verify that the ILB is sending probes to the CSRs by connecting to port 80:
thulsdau$ ssh 52.151.239.79 "show ip http server statistics" ; echo
HTTP server statistics:
Accepted connections total: 769
thulsdau$ ssh 52.151.239.88 "show ip http server statistics" ; echo
Accepted connections total: 736
Log into Spoke1VM1 and ping Spoke2VM1 as well as the CSRs:
thulsdau$ ssh 40.114.8.96
The authenticity of host '40.114.8.96 (40.114.8.96)' can't be established.
ECDSA key fingerprint is SHA256:smahT708NMluJYneNVZ9UhajLYrt+LjnhHLrq/duodg.
Are you sure you want to continue connecting (yes/no)? yes
Warning: Permanently added '40.114.8.96' (ECDSA) to the list of known hosts.
Welcome to Ubuntu 18.04.2 LTS (GNU/Linux 4.18.0-1024-azure x86_64)
thulsdau@Spoke1VM1:~$ for IP in 10.0.1.4 10.0.1.5 10.0.2.4 10.0.3.4 ; do ping -c 2 $IP ; done
PING 10.0.1.4 (10.0.1.4) 56(84) bytes of data.
64 bytes from 10.0.1.4: icmp_seq=1 ttl=255 time=2.38 ms
64 bytes from 10.0.1.4: icmp_seq=2 ttl=255 time=1.76 ms
--- 10.0.1.4 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 1.763/2.075/2.388/0.315 ms
PING 10.0.1.5 (10.0.1.5) 56(84) bytes of data.
64 bytes from 10.0.1.5: icmp_seq=1 ttl=255 time=2.74 ms
64 bytes from 10.0.1.5: icmp_seq=2 ttl=255 time=1.85 ms
--- 10.0.1.5 ping statistics ---
rtt min/avg/max/mdev = 1.852/2.298/2.744/0.446 ms
PING 10.0.2.4 (10.0.2.4) 56(84) bytes of data.
64 bytes from 10.0.2.4: icmp_seq=1 ttl=64 time=0.023 ms
64 bytes from 10.0.2.4: icmp_seq=2 ttl=64 time=0.027 ms
--- 10.0.2.4 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1031ms
rtt min/avg/max/mdev = 0.023/0.025/0.027/0.002 ms
PING 10.0.3.4 (10.0.3.4) 56(84) bytes of data.
64 bytes from 10.0.3.4: icmp_seq=1 ttl=63 time=3.82 ms
64 bytes from 10.0.3.4: icmp_seq=2 ttl=63 time=3.02 ms
--- 10.0.3.4 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1002ms
rtt min/avg/max/mdev = 3.026/3.426/3.826/0.400 ms
Verify with tracepath that traffic between the Ubuntu VMs traverses the CSRs (note that both CSRs are listed, indicating that load balancing is working as expected):
thulsdau@Spoke1VM1:~$ tracepath 10.0.3.4
 1?: [LOCALHOST]                      pmtu 1500
 1:  10.0.1.4                                              2.189ms
 1:  10.0.1.5                                              2.164ms
 2:  10.0.3.4                                              2.946ms reached
     Resume: pmtu 1500 hops 2 back 2
To help in setting up the whole solution as described in this article as quickly as possible and as a starting point for custom automation, as shell script (in az_create_ilb_transitvnet.zip) is attached to this document.
All parameters are defined as variables to make adaption simple.
Please make sure that Azure CLI is working on your computer before running the script (see section "Prerequisites").
Running the script is straight forward:
thulsdau$ ./az_create_ilb_transitvnet.sh
*** Setting up TransitVNET with Cisco CSR and Azure Internal Load Balancer ***
Creating VNET...
Creating ILB probe...
Creating ILB rule...
Creating CSR1...
Creating CSR2...
CSR1              10.0.1.4
CSR2              10.0.1.5
Script started: Tue Jul 23 12:15:12 PDT 2019
Script finished: Tue Jul 23 12:34:31 PDT 2019
*** TransitVNET created ***
Deleting the setup
To delete the whole setup, we can simply delete the resource group and Azure will take care of deleting all associated resources:
$ time az group delete -g TVNET --yes
real	19m37.327s
user	0m2.447s
sys	0m0.394s
(Timing just given as an indication how long the operation will typically take)
Planned improvements to this how-to
  • Add ability for CSR to take itself 'out-of-service' if its connection to the on-premise DC is down
  • Include performance tests
References
Please see these links for additional information:
Acknowledgments
The idea for the format of this how-to, specifically the use of Azure CLI instead of GUI screenshots came from the labs of github user jwrightazurehttps://github.com/jwrightazure/lab
pfillips11
Question:
For the communication from Spoke VM to on premise, the request will hit iLB VIP. While forwarding the traffic to CSRs won't the iLB change the destination IP from on prem server to CSR IP address? And if it does that then how does the CSR know what the destination is and where to forward the traffic?
Thank you
djtech2k
Is there a downloadable Visio for the images in this solution?
LuisF
Thank you for this guide, very helpful.   regarding the "Add ability for CSR to take itself 'out-of-service' if its connection to the on-premises DC is down", any news to share on that? this would be extremely helpful.
