i have one switch and two ports for two dirrent network they is ring both port in same vlan configuration, i want solution if one port down then autometic traafic gone from 2nd port it is possible?
1051
Note: switch1 in  2 ethernet port avaibale only 21-22
switch1 ethernet port 21 is connect with switch2 ethernet port 4 other port is full
switch1 ethernet port 22 is connect with switch3 ethernet port 1 other port is full
switch2 in ethernet port 5 is connect with  switch3 in ethernet port 2. other port is full
ring network so if switch1 i port 21 down then autometic traafic gone from switch port 22 it is possible?
Beginner
Dear Kish
I kind of understood what you are trying to achieve.
All of your switches has vlan 5-8-74-89 and as you have mentioned that the other ports are full because of in use and you are not having any issues. I am sure that spanning tree is already running on every switch to provide you a loop free topology by blocking one on the links between the switches. Not knowing which port is currently blocked
     switch 1
switch 2       OLT1
switch3   --   OLT2
                  Mikrotikwan
please run the commands below on  switch1, switch2, switch3,OLT1, OLT2 and share the output.
show spanning-tree active
and
show spanning-tree summary
Zaaf
