michelle.m.m
Community Member
Estou tendo problemas com um roteador que esta incrementando na interface serial output drops (Total output drops: 2563).
Serial0/0/0 is up, line protocol is up
  Hardware is GT96K Serial
  Description:
  Internet address is
  MTU 1024 bytes, BW 1024 Kbit, DLY 20000 usec,
     reliability 255/255, txload 29/255, rxload 1/255
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input 00:00:02, output 00:00:00, output hang never
  Last clearing of "show interface" counters 09:20:19
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2653
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/1747 (size/max total/threshold/drops)
     Conversations  0/4/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
  30 second input rate 7000 bits/sec, 23 packets/sec
  30 second output rate 178000 bits/sec, 45 packets/sec
     95879 packets input, 6585421 bytes, 0 no buffer
     Received 3922 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     169638 packets output, 80234282 bytes, 0 underruns
     unknown protocol drops
     4 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
paolo bevilacqua
Post questions in discussions, not documents.
