mohammedrafiq
We are trying to install 6716-10g card in our 6506-E switch slot 5 and its coming as power down, do we need to reload the switch?
Regards.
P1-6506-2#sh mod
Mod Ports Card Type                              Model              Serial No.
  1  24  CEF720 24 port 1000mb SFP              WS-X6724-SFP      SAL1131WBD
  2  48  SFM-capable 48-port 10/100 Mbps RJ45  WS-X6548-RJ-45    SAL09051KJ
  5  16  FRU type (0x6003, 0x403(1027))        WS-X6716-10GE      SAL134214K    <-------------------------------------10g card
  6    2  Supervisor Engine 720 (Active)        WS-SUP720-3B      SAL10360RX
Mod MAC addresses                      Hw    Fw          Sw          Status
  1  001c.58be.9400 to 001c.58be.9417  2.6  12.2(14r)S5  12.2(18)SXF8 Ok
  2  0013.1a97.eaa0 to 0013.1a97.eacf  6.1  6.3(1)      8.5(0.46)RFW Ok
  5  0025.84f1.31e0 to 0025.84f1.31ef  1.1  Unknown      Unknown      PwrDow  <----------------------------------------10g card
  6  0016.9df6.9d08 to 0016.9df6.9d0b  5.2  8.4(2)      12.2(18)SXF8 Ok
Mod  Sub-Module                  Model              Serial      Hw    Status
  1  Centralized Forwarding Card WS-F6700-CFC      SAL1131W9RM  3.1    Ok
  5  Distributed Forwarding Card WS-F6700-DFC3C    SAL13431U62  1.4    PwrDow  <-------------------------------------
  6  Policy Feature Card 3      WS-F6K-PFC3B      SAL10360NY4  2.3    Ok
  6  MSFC3 Daughterboard        WS-SUP720          SAL10360NMW  2.5    Ok
Mod  Online Diag Status
P1-6506-2#sh ver
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(18)SXF
8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Sat 03-Mar-07 02:26 by tinhuang
Image text-base: 0x01020150, data-base: 0x01021000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR:
P1-6506-2 uptime is 5 weeks, 4 days, 17 hours, 22 minutes
Time since P1-6506-2 switched to active is 5 weeks, 4 days, 17 hours, 22 minutes
System returned to ROM by  power cycle (SP by power on)
System restarted at 20:29:48 GMT Fri Nov 27 2009
System image file is unknown
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6506-E (R7000) processor (revision 1.1) with 491520K/32768K bytes of m
emory.
Processor board ID SAL1127TNKY
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
12 Virtual Ethernet/IEEE 802.3 interfaces
48 FastEthernet/IEEE 802.3 interfaces
26 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
P1-6506-2#
  1  Pass
  2  Pass
  5  Not Applicable
  6  Pass
Borman Bravo
You need at least 12.2 (33) SXI to support this module and it will require the reboot.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html#wp3965233
krishnakumarr
Check some other slot 3&4
