convms
Community Member
Hi Varma
Thanks for the reply, I did change it to the network address  but still I have no access to the internet from my laptop, only from  the router.
JK
version 12.4
hostname C2691
boot-start-marker
boot-end-marker
enable secret level 14 5 $1$X376$btHZvd07c.Un7HyJkcDS01
enable secret 5 $1$62Q7$rhPf9CIgIK/fK.9S8NGji.
enable password student
no aaa new-model
clock timezone GMT 0
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.0.170 172.16.0.190
ip dhcp pool itsusa
   network 172.16.0.160 255.255.255.224
   default-router 172.16.0.190
   dns-server 4.2.2.2 4.2.2.3
ip name-server 4.2.2.2
ip name-server 4.2.2.3
username cisco privilege 15 secret 5 $1$I7Rh$G/XqfPYnPhp1hK.2c3hsg.
interface FastEthernet0/0
ip address 172.16.0.190 255.255.255.224
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 70.148.158.141 255.255.255.248
ip nat outside
duplex auto
speed auto
router rip
version 2
network 70.0.0.0
network 172.16.0.0
no auto-summary
no ip classless
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/1 overload
access-list 1 permit 172.16.0.160 0.0.0.31
control-plane
line con 0
password
login
line aux 0
line vty 0 4
password
login
end
Vaibhava Varma
Level 4
Level 4
Hi JK
Are you getting a valid DHCP IP on your Laptop and able to ping the GW..How about the ping result to Internet e,g google.com/yahoo.com from laptoop. Is nslookup working on the laptop.
Are you able to resolve URL to IP on the laptop.
Varma
paolo bevilacqua
Post questions ind Discussions, not Documents.
