IOS Upgrade on Cisco 3850 switches
6959
Upgrading old IOS with New IOS
  • Check IOS with “show version”.
  • Verify the stacks that how many switches are connected with stack & in ready state “ Show switch”
  • Take the configuration backup before proceeding upgrade
  • Start copying new IOS universalk9- 07.05.E into each switch connected to stack. With following command Copy tftp: flash-x: universalk9- 03.07.05.E.bin
  • Set the boot value: config-Switch#> boot system flash:cat3k_caa-universalk9.SPA.0x.0x.0x.E.bin
  • Reload the switch. (15-min Downtime to users)
  • After upgrading the new IOS, verify
    • New IOS with“ show version
  • If step-7 succeeded, the switch will have new IOS version 03.07.05.E and status confirmed as production ready
  • If step-8 failed, (Rollback) switch back to the old IOS. universalk9- 07.05.E.bin (15-min Downtime to users)
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 0x.0x.05.E RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Fri 10-Feb-17 07:59 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.58, RELEASE SOFTWARE (P)
Switch uptime is 1 hour, 17 minutes
Uptime for this control processor is 1 hour, 24 minutes
System returned to ROM by reload
System image file is "flash:cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-48P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FCW2037F033
1 Virtual Ethernet interface
52 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
252000K bytes of Crash Files at crashinfo:.
1611414K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : 00:42:5a:11:83:00
Motherboard Assembly Number        : 73-15800-08
Motherboard Serial Number          : FOC20367X15
Model Revision Number              : AB0
Motherboard Revision Number        : A0
Model Number                       : WS-C3850-48P
System Serial Number               : FCW2037F033
Switch Ports Model              SW Version        SW Image              Mode
*    1 56    WS-C3850-48P       03.07.05.E        cat3k_caa-universalk9 BUNDLE
Configuration register is 0x102
  • Verify the stack with “Show switch”.
AS-XXX-01-01#sh switch
Switch/Stack Mac Address : 0023.5e76.e280
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 0023.5e76.e280     15     1       Ready
 2       Member 0023.5e77.6d00     14     1       Ready
 3       Member 0023.33a0.1b80     13     1       Ready
  • Take configuration backup before proceeding upgrade.
AS-XXX-01-01#copy startup-config tftp:<tftp server address>
  • Start copying new IOS universalk9- 03.07.05.E into each switch connected to stack. With following command Copy tftp: flash-x: universalk9- 03.07.05.E.bin
AS-XXX-01-01#copy  tftp: flash:
Address or name of remote host []? x.x.x.x
Source filename []? cat3k_caa-universalk9.SPA.03.07.05.E.152-x.E5.bin
Destination filename [cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin]?
Accessing tftp://192.168.1.2/cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin...
Loading cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin from 192.168.1.2 (via Vlan1): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 328618032 bytes]
AS--XXX-01-0# config-Switch#>  boot system flash:cat3k_caa-universalk9.SPA.03.07.05.E.bin
AS--XXX-01-01#Reload
  • After installing the new IOS, verify:
    1. New IOS with“ show version”
AS--XXX-01-01#System image file is flash:cat3k_caa-universalk9.SPA.03.07.05.E.152-3.E5.bin"
BR
Tayyab
Beginner
Hi Muhammad,
Really helpful and Thanks for sharing specially Action Plan :)
Jhon
Beginner
Hi Tayyab,
   Thank you for taking the time to share your plan.  I have a slightly different upgrade plan that I have been using successfully for years.  I just wanted to share this with the group.  Steps 1-3 are the same as your plan, step 3 is listed just to introduce some examples.
3. Take the configuration backup before proceeding upgrade.
   Examples that will need to be adjusted for your environment:
   show run | redirect ftp://username:password@YUR.IP.ADD.RES:~/YourBackupDir/your-3850-sw1.cfg
   show run brief | redirect ftp://username:password@YUR.IP.ADD.RES:~/YourBackupDir/your-3850-sw1_brief.cfg
   show run all | redirect ftp://username:password@YUR.IP.ADD.RES:~/YourBackupDir/your-3850-sw1_all.cfg
4. There is no need to copy the new version package to each switch.  The package only needs to be copied to the "Active" master switch (usely switch #1).  The next step will perform that operation for us by copying the package to each switch utilizing the stack-wise connections high-bandwidth.  This keeps us from having to saturate the uplink(s) by transferring the package N(# of switches) times.  Also, we need to make sure to update any NBAR2 protocol packs as well.
   Examples for both:
   copy ftp://username:password@YUR.IP.ADD.RES:~/YourSoftwareDir/cat3k_caa-universalk9.16.06.04a.SPA.bin flash:cat3k_caa-universalk9.16.06.04a.SPA.bin
   copy ftp://username:password@YUR.IP.ADD.RES:~/YourSoftwareDir/pp-adv-cat3k-166.4-31-40.0.0.pack flash:pp-adv-cat3k-166.4-31-40.0.0.pack
   Examples for md5 hash verification:
   verify /md5 flash:cat3k_caa-universalk9.16.06.04a.SPA.bin
   verify /md5 flash:pp-adv-cat3k-166.4-31-40.0.0.pack
5. Install the new version using the software install command.
   Examples:
   software install file flash:cat3k_caa-universalk9.16.06.04a.SPA.bin new
   software install file flash:cat3k_caa-universalk9.16.06.04a.SPA.bin new auto-rollback 60
There are multiple options for this install method like auto-rollback, on-reboot, force, and so on.  I would recommend checking them out. You will be prompted to reload the switch (yes|no).  The verification process is done automatically during the software install and output to screen for your review prior to accepting reboot.  If something is in error, then from here you can stop the process and rollback.  I tell users at the very least 20min downtime for a single switch.  Multiple switch stacks can take a VERY long time to reload and re-provision themselves correctly.  As an example, I have waited 46mins for a stack of 4 to reload completely.  I was dialing TAC in panic at 45min...lol.
5. After upgrading the new IOS, verify
    New IOS with show version
6. After a successful upgrade, now you can update your NBAR2 protocol pack.
   Example:
   ip nbar protocol-pack flash:pp-adv-cat3k-166.4-31-40.0.0.pack
7. Don't forget to save config/wr mem!
- Ricky
Content for Community-Ad
July's Community Spotlight Awards
