IPv6 Flexible NetFlow Configuration Example
4547
    Introduction
    This document provides sample configuration of Flexible NetFlow using IPv6 in Cisco IOS routers.Cisco IOS Flexible NetFlow is a next-generation flow  technology.
    NetFlow is a Cisco IOS technology that  provides statistics on packets flowing through a router. NetFlow provides IP operational data from IP networks to support network and security monitoring, network planning and other variety of purposes.
    Flexible NetFlow customize the traffic analysis parameters for your specific requirements and with the help of reusable configuration components, it facilitates the creation of more complex configurations for traffic analysis and data export.Flexible NetFlow improves on original NetFlow by providing
    enhanced optimization of the network infrastructure, improves capacity planning  and security detection.
    Prerequisite
    The following prerequisite to be met for configuring IPv6 NetFlow:
    • The networking device must be configured for IPv6 routing.
    • IPv6 CEF or Distributed IPv6 CEF must be enabled on the routers and on any interfaces on which you want to enable Flexible NetFlow.
    Background
    In this example, router R1 and R2 are connected via FastEthernet interface Fa1/0 and uses OSPFv3 to communicate with each other. The interfaces are configured with IPv6 addresses.
    Note: All configuration is tested on Cisco 7200 Series Router running on IOS Version  15.0(1)M Advance IP Services Image.
    Topology Diagram
    Summary Steps
    In Global Configuration Mode
    1. enable
    2. configure terminal
    3. flow monitor monitor-name
    4. description description
    5. record
    6. end
    In Interface Configuration Mode
    1. ipv6 flow monitor monitor-name {input |output}
    2. end
    Configuration
    R1
    R2
    R1#show run
    version 15.0
    hostname R1
    flow monitor TEST
    Creates a flow monitor and enters Flexible NetFlow flow monitor configuration mode.
    record netflow ipv6 original-output
    Specifies the record for the flow monitor.
    ipv6 unicast-routing
    ipv6 cef
    interface Loopback0
    no ip address
    ipv6 address 1111::11/128
    ipv6 ospf 1 area 0
    interface FastEthernet1/0
    no ip address
    duplex auto
    speed auto
    ipv6 address 2020:1:1:1::1/64
    ipv6 ospf 1 area 0
    ipv6 flow monitor TEST output
    Activates the flow monitor that you created previously by
    assigning it to the interface to analyze egress traffic.
    ipv6 router ospf 1
    router-id 1.1.1.1
    log-adjacency-changes
    end
    R2#show run
    version 15.0
    hostname R2
    flow monitor TEST2
    record netflow ipv6 protocol-port
    Creates flows based on protocols and ports in the traffic flow data.
    ipv6 cef
    interface Loopback0
    no ip address
    ipv6 address 2222::22/128
    ipv6 ospf 1 area 0
    no ip address
    duplex auto
    speed auto
    ipv6 address 2020:1:1:1::2/64
    ipv6 ospf 1 area 0
    ipv6 flow monitor TEST2 input
    ipv6 router ospf 1
    router-id 2.2.2.2
    end
    Verification Commands
    show flow monitor
    show running-config flow monitor <monitor-name>
    show flow monitor <monitor-name> statistics
    show flow record netflow ipv6 protocol-port
    show flow monitor <monitor-name> cache
    References
    Understanding IPv6 NetFlow
    Flexible Netflow Configuration Guide, Cisco IOS Release 15.0S
    Cisco IOS Flexible NetFlow Command Reference
    Cisco IOS Flexible NetFlow Technology Q&A
