TCC_2
Level 10
Level 10
Core issue
The multi-VLAN port feature on the Catalyst 2900 XL/3500 XL switches allows for configuring a single port into two or more VLANs. This feature allows users from different VLANs to access a server or router without implementing inter-VLAN routing capability. A multi-VLAN port performs normal switching functions in all its assigned VLANs. VLAN traffic on the multi-VLAN port is not encapsulated as it is in trunking.
Resolution
Synopsis: Port will not pass traffic for multi-access VLAN configuration, but works fine on one VLAN.
The limitations of implementing multi-VLAN port features are as follows:
  • You cannot configure a multi-VLAN port when a trunk is configured on the switch. You must connect the multi-VLAN port only to a router or server. The switch automatically transitions to VTP transparent mode when the multi-VLAN port feature is enabled, making the VLAN Trunk Protocol (VTP) disabled. No VTP configuration is required.
  • The multi-VLAN port feature is supported only on the Catalyst 2900 XL/3500 XL series switches. This feature is not supported on the Catalyst 4000/5000/6000 series or any other Cisco Catalyst switches.
For more information, refer to Creating Ethernet VLANs on Catalyst Switches.
