Community Helping Community
NFS for NCS backup purposes
7659
NFS mount for backups on NCS:
nms-kate/admin# backup verifying_nfs repository nfsVictoria application NCS
% Creating backup with timestamped filename: verifying_nfs-120713-1055.tar.gpg
Stage 1 of 7: Database backup ...
-- complete.
Stage 2 of 7: Database copy ...
-- complete.
Stage 3 of 7: Backing up support files ...
-- complete.
Stage 4 of 7: Compressing backup ...
-- complete.
Stage 5 of 7: Building backup file ...
-- complete.
Stage 6 of 7: Encrypting backup file ...
-- complete.
Stage 7 of 7: Transferring backup file ...
-- complete.
nms-kate/admin#
NCS Config:
backup-staging-url nfs://nms-victoria.cisco.com:/var/nfs
NFS Config ( Centos ):
Install nfs:
yum install nfs-utils nfs-utils-lib
chkconfig --levels 35 nfs on
chkconfig --levels 35 portmap on
service portmap start
service nfs start
Create the share and set permissions:
mkdir -p /var/nfs
chown 65534:65534 /var/nfs
chmod 755 /var/nfs
/etc/exports:
/var/nfs                         172.18.123.0/16(rw,sync,no_subtree_check)
run the command "exportfs -a"
You should be able to see what you are exporting then with:
nms-victoria:/var# exportfs
nms-victoria:/var# showmount -e localhost
Export list for localhost:
Verify services are  running:
nms-victoria:/media/sschmidt# rpcinfo -p
rpcinfo: can't contact portmapper: RPC: Remote system error - Connection refused
Portmap is not running
    program vers   proto   port
     100000    2     tcp    111  portmapper
     100000    2     udp    111  portmapper
Not seeing all the other ports and services -
service nfs restart
From machine that is configured for NFS:
     100011    1   udp    861  rquotad
     100011    2   udp    861  rquotad
     100011    1   tcp    864  rquotad
     100011    2   tcp    864  rquotad
     100003    2   udp   2049  nfs
     100003    3   udp   2049  nfs
     100003    4   udp   2049  nfs
     100021    1   udp  33690  nlockmgr
     100021    3   udp  33690  nlockmgr
     100021    4   udp  33690  nlockmgr
     100003    2   tcp   2049  nfs
     100003    3   tcp   2049  nfs
     100003    4   tcp   2049  nfs
     100021    1   tcp  60276  nlockmgr
     100021    3   tcp  60276  nlockmgr
     100021    4   tcp  60276  nlockmgr
     100005    1   udp    876  mountd
     100005    1   tcp    879  mountd
     100005    2   udp    876  mountd
     100005    2   tcp    879  mountd
     100005    3   udp    876  mountd
     100005    3   tcp    879  mountd
From a machine that is in the same subnet:
linuxlabciscocom:/mnt/nfs/var/nfs# rpcinfo -p 172.18.123.241
Either disable iptables or add the ports from above
service iptables stop
chkconfig iptables off
To mount from another linux machine:
Create mount point and mount:
mkdir -p /mnt/nfs/var/nfs
mount 172.18.123.241:/var/nfs /mnt/nfs/var/nfs
Verify:
linuxlabciscocom:/mnt/nfs/var/nfs# mount
172.18.123.241:/var/nfs on /mnt/nfs/var/nfs type nfs (rw,addr=172.18.123.241)
Windows NFS server config:
The best document I have found is this write up of the process from Microsoft MSDN:
https://blogs.msdn.com/b/sfu/archive/2007/04/19/set-up-server-for-nfs-in-windows-server-2003-r2.aspx?Redirected=true
Nice Doc Rollin..
Thank you for taking the time to make this document. It was very useful when I needed to backup Cisco Prime to NFS.
The following PowerShell script can be used to install and configure NFS on Windows Server 2012 R2:
# Set variables
$CiscoPrimeIPAddress = "IP address of Cisco Prime Infrastructure"
$nfsServer = $env:ComputerName
$nfsRepoName = "nfsRepo"
$nfsRepoRoot = "C:\nfsRepo"
$nfsRepoStaging = "staging"
$nfsRepoStorage = "storage"
# Create the files group and passwd in %SystemRoot%\System32\drivers\etc to be used as a user mapping source.
New-Item "${env:SystemRoot}\System32\drivers\etc\group" -Type File -Value "BUILTIN\Administrators:x:0:root"
New-Item "${env:SystemRoot}\System32\drivers\etc\passwd" -Type File -Value "${nfsServer}\Administrator:x:0:0:root::"
# Install Server for NFS Role
Import-Module ServerManager
Add-WindowsFeature FS-NFS-Service
Import-Module NFS
# Create staging and storage folders
New-Item -ItemType Directory -Path ${nfsRepoRoot}\${nfsRepoStaging}
New-Item -ItemType Directory -Path ${nfsRepoRoot}\${nfsRepoStorage}
New-Item "${nfsRepoRoot}\${nfsRepoStorage}\test.txt" -Type File
# Create new share
New-NfsShare -Name $nfsRepoName -Path $nfsRepoRoot -AllowRootAccess $False -Authentication Sys -EnableAnonymousAccess $False -EnableUnmappedAccess $False -Permission No-Access
# Grant permission to CPI
Grant-NfsSharePermission -Name $nfsRepoName -ClientName $CiscoPrimeIPAddress -ClientType "Host" -Permission "ReadWrite" -AllowRootAccess $True
# Output Cisco Prime Config
$Output = @"
configure terminal
backup-staging-url nfs://${nfsServer}:/${nfsRepoName}/${nfsRepoStaging}
repository ${nfsRepoName}
  url nfs://${nfsServer}:/${nfsRepoName}/${nfsRepoStorage}
end
show repository ${nfsRepoName}
Write-Host "After running the following config on CPI you should get test.txt as output" -ForegroundColor "Yellow"
Write-Host $Output -BackgroundColor "Black" -ForegroundColor "Green"
Content for Community-Ad
FusionCharts will render here
