CscTsWebDocs
Community Member
This document explains basic function design related to redundancy operation of NAT Box to Box High Availability (hereinafter called NAT B2B HA).
1. Redundancy Configuration of Control/Data Link
a. Control Link failure
With NAT B2B HA, a physical failure occurs in the Control Link, failing to secure redundancy in a state where all devices to configure HA become Active (hereinafter called split-brain).
To avoid split-brain caused by a Control Link failure, securing maximum reliability is recommended for a network that connects Control Link.
A redundancy Link configuration, such as Port-Channel, is effective for Control Link to avoid split-brain caused by a single Control Link failure.
The configuration diagram and the configurations of the sample are described below:
Figure5
R1#
redundancy
 application redundancy
  group 1
   name RG1
   preempt
   control Port-channel1.1001 protocol 1
   data Port-channel1.1002
interface Port-channel1
no ip address
interface Port-channel1.1001
encapsulation dot1Q 1001 primary Ethernet0/1 secondary Ethernet1/1
ip address 10.1.1.2 255.255.255.0
interface Port-channel1.1002
encapsulation dot1Q 1002 primary Ethernet1/1 secondary Ethernet0/1
ip address 10.2.2.2 255.255.255.0
interface Ethernet0/1
no ip address
channel-group 1
interface Ethernet1/1
no ip address
channel-group 1
R2#
redundancy
  group 1
   name RG1
   preempt
   priority 200 failover threshold 150
   asymmetric-routing interface Port-channel1.1002
no ip address
ip address 10.1.1.1 255.255.255.0
ip address 10.2.2.1 255.255.255.0
no ip address
channel-group 1
no ip address
channel-group 1
When Control Link is manually shut down, RG group of the device which is shut down becomes AdminDown.
When Control Link is shut down at ACTIVE side device, it becomes INIT (Disable), causing Failover.
R1#show redundancy application protocol group 1
RG Protocol RG 1
        Role: Init
        Negotiation: Disabled [RG-VP-Request]
        Priority: 105
        Protocol state: Disable
        Ctrl Intf(s) state: AdminDown
        Active Peer: Not exist
        Standby Peer: Not exist
        Log counters:
                role change to active: 1
                role change to standby: 1
                disable events: rg down state 1, rg shut 0
                ctrl intf events: up 1, down 0, admin_down 1
                reload events: local request 0, peer request 0
b. Data Link failure
When a failure occurs in Data Link, an ACTIVE router continues to operate as ACTIVE, and a STANDBY router becomes INIT.
When Data Link is manually shut down, RG group of the device which is shut down becomes AdminDown.
When Data Link is shut down at the ACTIVE side device, it becomes INIT (Disable), causing Failover.
2. Timer Tuning
This section describes two typical timers used for tuning the operation during a NAT BtoB HA failure.
1. timers hellotime [msec] number holdtime [msec] number
A sending interval of hello, and a holdtime to determine that the opposite side cannot respond when not receiving hello can be changed.
A default value of hellotime is 3 sec, and that of holdtime is 10 sec.
R1#
redundancy
  group 1
  protocol 1
   timers hellotime msec 500 holdtime msec 2000
R2#
redundancy
  group 1
  protocol 1
   timers hellotime msec 1000 holdtime msec 3000
RG Protocol RG 1
        Role: Active
        Negotiation: Enabled
        Priority: 105
        Protocol state: Active
        Ctrl Intf(s) state: Up
        Active Peer: Local
        Standby Peer: address 10.0.0.2, priority 100, intf Et0/1
        Log counters:
                role change to active: 2
                role change to standby: 2
                ctrl intf events: up 2, down 0, admin_down 1
RG Media Context for RG 1
        Ctx State: Active
        Protocol ID: 1
        Media type: Default
        Control Interface: Ethernet0/1
        Current Hello timer: 500
        Configured Hello timer: 500, Hold timer: 2000
        Peer Hello timer: 1000, Peer Hold timer: 3000
        Stats:
                Pkts 393, Bytes 24366, HA Seq 0, Seq Number 393, Pkt Loss 0
                Authentication not configured
                Authentication Failure: 0
                Reload Peer: TX 1, RX 0
                Resign: TX 0, RX 1
        Standby Peer: Present. Hold Timer: 2000
                Pkts 163, Bytes 5542, HA Seq 0, Seq Number 286186, Pkt Loss 0
2. timers delay <seconds> [reload <seconds>]
This timer specifies time taken to start a negotiation of RG role for recovering a device from a failure or after recovering from reloading.
A default value of delay is 10 sec, and that of reload timer is 120 sec.
These values are used when tuning, in accordance with recovery time for routing protocol after recovering from a failure, is required.
After booting, Negotiation Delay Timer in accordance with timers reload <seconds> begins the countdown as shown below.
A Pre-init state is kept until the Timer is expired.
RG Protocol RG 1
        Role: Init
        Negotiation: Delayed; remaining 48 sec
        Priority: 105
        Protocol state: Pre-init
        Log counters:
                role change to active: 0
                role change to standby: 0
                disable events: rg down state 0, rg shut 0
                ctrl intf events: up 1, down 0, admin_down 0
It transits to the Standby-cold state after the Delay Timer is expired.
%RG_PROTOCOL-5-ROLECHANGE: RG id 1 role change from Init to Standby
RG Protocol RG 1
        Role: Standby
        Priority: 105
        Protocol state: Standby-cold
        Active Peer: address 10.0.0.2, priority 100, intf Et0/1
        Standby Peer: Local
        Log counters:
If the Preempt settings are enabled, the Active state will be recovered again.
%RG_PROTOCOL-5-ROLECHANGE: RG id 1 role change from Standby to Active
RG Protocol RG 1
        Role: Active
        Priority: 105
        Active Peer: Local
        Log counters:
Please refer to the following documents:
Related Information
Original Document: https://supportforums.cisco.com/ja/document/12331106
Author: Daijiro Kido
Posted on Oct 21, 2014
