Networking Knowledge Base
Developer Sustainability Week Events
Build for Better Code Challenge
Cisco U. Spotlight Registration
>> View previously featured conversations <<
Knowledge Base Articles
Network Automation Basics Automate Shell Scripts with Expect   I remember in my early days of network engineering when I had a checklist that required me to SSH and Telnet into several servers and check the status or configurations to make sure ever...
Difference between USGMII and USXGMII: USGMII is used for 8x10M/100M/1GE network ports, with each port maximum speed of 1GE. USXGMII-Single  Port version can be used to support ONE network port with 10M/100M/1G/2.5G/5G/10G data ratesUSGMII is used f...
YANG Tools Cheat Sheet     Developer Support Options Break/Fix:  Contact the TAC if a Cisco API is not working as expected. Consulting/Best Practices:  Please use the DevNet Community to get general best practice help/tips/examples for using Cisco ...
I'm able to pull the topology using the API GEThttps://n.n.n.n/api/node/mo/topology/pod-1.json?query-target=children&target-subtree-class=fabricNode(after authenticating and getting a cookie, of course) But the version field is empty. I don't see a w...
bdbauer by Level 1
  • 2127 Views
  • 1 comments
Top Contributors
