Issue:
External EIGRP route not reachable by R1 and R10 in the topology bellow after redistribution between OSPF and EIGRP configured in R1 and R10
Solution:
Before we start with the solution lets see the routing tables of each of the routers above
R3:
R3#sho ip route
3.0.0.0/24 is subnetted, 1 subnets
C 3.3.3.0 is directly connected, Loopback0
10.0.0.0/24 is subnetted, 1 subnets
C 10.1.1.0 is directly connected, FastEthernet1/0
D EX 192.168.1.0/24 [170/2560002816] via 10.1.1.10, 00:00:43, FastEthernet1/0
[170/2560002816] via 10.1.1.1, 00:00:42, FastEthernet1/0
150.1.0.0/24 is subnetted, 1 subnets
C 150.1.1.0 is directly connected, Loopback1
as we can see the network 150.1.1.0 is a directly connected network in R3 and this network advertised as external EIGRP network through redistribution
in other words R1 and R10 supposed to see this network as external EIGRP, lets see the routing table of R1 and R10:
R1#show ip route 150.1.1.0
Routing entry for 150.1.1.0/24
Known via "ospf 1", distance 110, metric 20
Tag 190, type extern 2, forward metric 1
Redistributing via eigrp 10
Advertised by eigrp 10 metric 1 1 1 1 1
Last update from 192.168.1.10 on FastEthernet1/0, 00:03:23 ago
Routing Descriptor Blocks:
* 192.168.1.10, from 192.168.1.10, 00:03:23 ago, via FastEthernet1/0
Route metric is 20, traffic share count is 1
Route tag 190
R10#show ip route 150.1.1.0
Known via "eigrp 10", distance 170, metric 2560002816
Tag 190, type external
Redistributing via ospf 1, eigrp 10
Advertised by ospf 1 subnets tag 190
Last update from 10.1.1.1 on FastEthernet1/1, 00:03:35 ago
* 10.1.1.3, from 10.1.1.3, 00:03:35 ago, via FastEthernet1/1
Route metric is 2560002816, traffic share count is 1
Total delay is 110 microseconds, minimum bandwidth is 1 Kbit
Reliability 1/255, minimum MTU 1 bytes
Loading 1/255, Hops 1
10.1.1.1, from 10.1.1.1, 00:03:35 ago, via FastEthernet1/1
Route tag 190
As it shown in the routing table of R1 and R10 the network 150.1.1.0 is looping now
Simply because, R1 see it through OSPF with distance 110 and R10 see it from R1 and R3 and this will result in a typical routing loop
R10#ping 150.1.1.1
Sending 5, 100-byte ICMP Echos to 150.1.1.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
R1#ping 150.1.1.1
The main problem here is that EIGRP External Route has Administrative Distance of 170 and we did what is know as "mutual redistribution" between OSPF and EIGRP in both ASBR routers, this issue will happen with External EIGRP route only here, because each of R1 and R10 will see this route with a less admin distance "AD" from each other and a route looping will form in this case
Technically, there are multiple ways to solve issues like this and its always depends on the network design and how complex it is. In this document we will see how we can solve this issue by using route filtering combined with Route tagging
As shown above, in the routing tables of both R1 and R10, there is a tag associated with the network 150.1.1.0 in R1 and R10, this is because: when the route redistribution from EIGRP into OSPF configured it was also tagged with the following values and CLI commands:
R1:
router ospf 1
redistribute eigrp 10 subnets tag 1090
R10:
router ospf 1
redistribute eigrp 10 subnets tag 190
Now if we look at the "show ip route" result again we can notice that both ASBR routers have the deployed tagging, this indicates that the routes is learned via OSPF after being redistributed, as mentioned above because of the higher distance of external EIGRP AD
Last update from 192.168.1.10 on FastEthernet1/0, 00:16:49 ago
* 192.168.1.10, from 192.168.1.10, 00:16:49 ago, via FastEthernet1/0
Route tag 190 --- ----190 fom R10
Last update from 10.1.1.1 on FastEthernet1/1, 00:17:49 ago
* 10.1.1.3, from 10.1.1.3, 00:17:49 ago, via FastEthernet1/1
10.1.1.1, from 10.1.1.1, 00:17:49 ago, via FastEthernet1/1
Route tag 190 --- this means that R1 advertising this ntwork back to R10 after its leaned it from R10 thorugh OSPF (tag 190)
Now the first step is that we know the route tags
R1 advertising EIGRP route with tag 1090
R10 advertising EGRP route with tag 190
Next we need to prevent the loop by blocking the route from being learned back by EIGRP domain. what that mean, in our example R1 needs to block any learned route with tag 190 to be redistributed back into EIGRP. Similarly, R10 needs to block any route with tag 1090 from being redistributed back into EIGRP
In this case we will make sure that any EIGRP route redistributed into OSPF Domain by R1 will not be redistributed back into EIGRP domain by R10. The exact same concept is applicable to R10 redistribution
lets see how we can recover our network above from the route looping with this concept:
R1:
route-map EIGRP deny 10 -------- this means deny any route has tag 190
match tag 190
route-map EIGRP permit 20 -- permit anything else
router eigrp 10
redistribute ospf 1 metric 1 1 1 1 1 route-map EIGRP
R10:
match tag 1090
router eigrp 10
lets pig now :
R1#ping 150.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 92/137/188 ms
R10#ping 150.1.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/64/156 ms
All good !!!!!
lets see the routing tables of R1 and R10
Known via "eigrp 10", distance 170, metric 2560002816, type external
Last update from 10.1.1.3 on FastEthernet1/1, 00:03:46 ago
* 10.1.1.3, from 10.1.1.3, 00:03:46 ago, via FastEthernet1/1
Last update from 192.168.1.10 on FastEthernet1/0, 00:30:37 ago
* 192.168.1.10, from 192.168.1.10, 00:30:37 ago, via FastEthernet1/0
Route tag 190
Although we have just solved the looping issue, we still see this network in R1 through OSPF !!
As long as there is no route loop this is fine UNLESS you are looking for optimal route path in the case there are some extra steps you need to configured
We can use the same route-maps we created above that match the tagged traffic and then we apply under OSPF process using distribute list with a route map
lets do it in R1 to see the effect and then we can apply it in R10 as well
Keep in mind that you need to consider redundancy and backup links when you do it a real network design because with the filtering above you might block a redundant link ( just be ware and careful when you do it in production network with multiple paths)
As this document not for best path selection and optimal route there will be no deep details about how to configure this network for optimal path selection such as route metric tuning.
router ospf 1
distribute-list route-map EIGRP in
Advertised by ospf 1 subnets tag 1090
Last update from 10.1.1.3 on FastEthernet1/1, 00:00:36 ago
* 10.1.1.3, from 10.1.1.3, 00:00:36 ago, via FastEthernet1/1
here we go the route now through R3 and through EIGRP in R1
same config need to be done in R10
Thank you
Marwan Alshawi
great article. I was looking for a practical example of the use of route tagging. This article nailed it.
thanks.
For a Optimal Path Selection, which means going to the network of 150.x.x.x through R3, through our EIGRP domain, and also for a Redundant Path which is through R10, through the OSPF domain, we can prefer the main path through R3 via EIGRP domain and also use the redundant path to the 150.x.x.x network through R10, through OSPF domain. Simply, we go on R1 and we change the Administrative Distance of that specific route of 150.x.x.x advertised us by R10:
R1:
conf t
router ospf 1
distance 171 10.1.1.3 0.0.0.0 1
exit
access-list 1 permit 150.1.1.0 0.0.0.255
end
And that's it, we don't need to definitely block our path to 150.x.x.x network through R10, instead we use it as a redundant path because now it has a higher AD than the External EIGRP AD of 170.
The reason why the path to 150.x.x.x was initially preferred through R10 is because R10 was advertising us the same route of 150.x.x.x that we got from R3 but with a better AD, an AD of 110 vs the one we had with AD of 170.
Great and well explained
Is there a way you can avoid the loop in this scenario without using a route-map,Access-list,Prefix list and also not changing AD of the routers.
Exceptional Article and simple words to explain such a great concept.
Thanks a lot MArwan
Excellent explained !!, great job.
