probleme de demarrage routeur cisco 3845
544
message en boucle 3845
Readonly ROMMON initialized
*** Watch Dog Timeout Reset ***
ra = 0x0, EPC = 0x0
*** BCM 1125 went through a full reset. HT/PCI fabric reset. ***
Rommon primary and backup variables are invalid...
Warning: monitor nvram area is corrupt ... using default values
amd_flash_cmd: timeout on write sector command
environment write to NVRAM failed
environment checksum failed
Total memory size = 512 MB - DIMM0 = 512 MB, DIMM1 = 0 MB
c3845 platform with 524288 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
