PRTG monitoring - Sensor Syslog receiver not receiving all data
720
PRTG system in place running other sensors on the same host, which are working.  Ive added syslog receiver sensor and receiving PRTG data from switch that increases drops, errors and warning stats that disappear after a few minutes.  Within messages panel  log entries are being logged but only timestamp and source IP address are correctly populated.  Messages column displays 0��0 ���00. � and the rest of the columns, timestamp severity etc are blank.  Overall sensor is connected but details from system logging are either being misinterpreted at PRTG or not being received.
No packets are being dropped at the firewall towards PRTG.
VIP Mentor
Not what is the device model here ? can you give more information about the device / Model / Version of Code running you syslog config on the device.
Beginner
syslog trap has been enabled.  SNMP access list is s standard access list towards PRTG, access 50.
CAT9K_IOSXE - Cisco IOS XE Software, Version 16.06.06
snmp-server group V3F@3!Group v3 auth read V3Read access 50
snmp-server view V3Read iso included
snmp-server view V3Read internet included
snmp-server view V3Read mib-2 included
snmp-server view V3Read system included
snmp-server view V3Read cisco included
snmp-server view V3Read ip.21 excluded
snmp-server view V3Read tcp.13 excluded
snmp-server view V3Read udp.5 excluded
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps flowmon
snmp-server enable traps entity-perf throughput-notif
snmp-server enable traps call-home message-send-fail server-fail
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps rep
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps port-security
snmp-server enable traps license
snmp-server enable traps cpu threshold
snmp-server enable traps memory bufferpeak
snmp-server enable traps stackwise
snmp-server enable traps fru-ctrl
snmp-server enable traps flash insertion removal lowspace
snmp-server enable traps energywise
snmp-server enable traps power-ethernet group 1
snmp-server enable traps power-ethernet group 2
snmp-server enable traps power-ethernet group 3
snmp-server enable traps power-ethernet group 4
snmp-server enable traps power-ethernet group 5
snmp-server enable traps power-ethernet group 6
snmp-server enable traps power-ethernet police
snmp-server enable traps envmon
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps ike policy add
snmp-server enable traps ike policy delete
snmp-server enable traps ike tunnel start
snmp-server enable traps ike tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps ipsla
snmp-server enable traps entity-diag boot-up-fail hm-test-recover hm-thresh-reached scheduled-test-fail
snmp-server enable traps bfd
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps event-manager
snmp-server enable traps hsrp
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps trustsec-sxp conn-srcaddr-err msg-parse-err conn-config-err binding-err conn-up conn-down binding-expn-fail oper-nodeid-change binding-conflict
snmp-server enable traps trustsec authz-file-error cache-file-error keystore-file-error keystore-sync-fail random-number-fail src-entropy-fail
snmp-server enable traps trustsec-interface unauthorized sap-fail authc-fail supplicant-fail authz-fail
snmp-server enable traps trustsec-server radius-server provision-secret
snmp-server enable traps lisp
snmp-server enable traps dhcp
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps rsvp
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps isis
snmp-server enable traps ospfv3 state-change
snmp-server enable traps ospfv3 errors
snmp-server enable traps vlan-membership
snmp-server enable traps errdisable
snmp-server enable traps rf
snmp-server enable traps transceiver all
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vrfmib vrf-up vrf-down vnet-trunk-up vnet-trunk-down
snmp-server host **.**.**.** version 3 auth **
