Kt43387
import netmiko
from netmiko import ConnectHandler
device = ConnectHandler(device_type="cisco-ios, ip="IP ADDRESS", username="USENAME", password="PASSWORD", secret="ENABLE PASSWORD")
output1 = device.send_command("show running-config")
print(output1)
device.disconnect()
liviu000111
Please, Krishna, how can I use this script? On what device and what are the prerequisites?
Kt43387
Hi @liviu000111 Greetings. There is not prerequisite, Just install python on machine with any IDE and and run the given script to access your Cisco routers and switches and your are set. But its good to have some basic understanding of python to understand the script and optimize as per your need.
Krishna
liviu000111
Hi, Krishna, Question: This netmico is some library?
Kt43387
Hi @liviu000111  Yes, Its a multi vendor python library to SSH into network devices.its support multiple vendors. You can google it for more detail.
Krishna
