Resilience between sites
107
Hi, I will try my best to describe our issue.
We have two sites, A and B. We have recently created a backup data center for our virtual servers using vRanger and NetVault on site B. In a disaster scenario such as, we lost our primary Site A, we would like the ability to turn on the backed up servers that reside in Site B and have them just work.
The problem with this scenario is when the servers turn on they will have the default gateway of the router in Site A and thus won't work. Yes, we can go in and manually change it but it's a step that we would like to negate.
The options that I have come up with is using VRRP and point the servers to a virtual IP. Or we could define the VLAN that the servers use on Site A on Site B but shut the VLAN down and only bring it up when needed.
I hope this make sense. Please, if you need any further information to help me with this, just ask.
Kind regards,
Jamie.
Beginner
Bump
Content for Community-Ad
July's Community Spotlight Awards
