ekhabaro
This article now available on CCO: https://www.cisco.com/c/en/us/support/docs/routers/sd-wan/214147-vedge-does-not-advertise-its-own-as-when.html
Introduction
This document describes why vEdge router does not advertise it's own Autonomous System (AS) number when advertising Border Gateway Protocol (BGP) routes into Overlay Management Protocol (OMP).
Prerequisites
Requirements
Cisco recommends that you have knowledge of these topics:
  • Basic understanding of Viptela Software Defined Wide Area network (SDWAN) solution
  • Overlay Management Protocol (OMP)
Components Used
The information in this document was created with help of the devices in a specific lab environment. All of the devices used in this document started with a cleared (default) configuration. If your network is live, ensure that you understand the potential impact of any command.
Configure
Network Diagram
Here is a simple topology diagram that describe the setup:
192.168.41.0/24---|R1---vedge1–-Overlay–-vedge2---R2|---192.168.51.0/24
And the problem can be depicted as below:Screenshot 2019-02-06 at 23.09.07.png
For prefix A on R2 - you expect to see AS-PATH: 65002, 64500, 65001, 65156 but only saw 65002 64500 65156
For prefix B on R1 - you expect to see AS-PATH: 65001, 64500, 65002, 65157 but only saw 65001 64500 65157
Verify
1) Take a look at the prefix B (192.168.51.0/24) on vedge2.
vedge2# show bgp routes 192.168.51.0/24 detail
bgp routes-table vpn 40 192.168.51.0/24
 best-path 1
 info 0
  nexthop     192.168.50.115
  metric      0
  weight      0
  origin      igp
  as-path     65157
  ri-peer     192.168.50.115
  ri-routerid 2.2.2.1
  path-status valid,best,external
  tag         0
As you notice, AS-path here consists of singe AS of our peer router R2 and this is an expected behavior. You see this prefix on vedge2 as it was advertised to us.
You can observe similar behavior as on ordinary Internetworking Operating Systems (IOS) routers as well.
2)  Advertising BGP routes via OMP.
omp
 overlay-as       64500
 advertise bgp
Advertise bgp configuration is just like a well-known Cisco IOS redistribute command. OMP is similar to BGP, but in reality it’s another protocol developed specifically for SDWAN solution. So you preserve BGP prefix attributes that you had in BGP table (refer to step 1).
3)  Looking at prefix B (192.168.51.0/24) on vedge1 after passing through overlay.
vedge1# show omp routes 192.168.51.0/24 detail
omp route entries for vpn 40 route 192.168.51.0/24
            RECEIVED FROM:
peer            192.168.30.103
path-id         12
label           1003
status          C,I,R
loss-reason     not set
lost-to-peer    not set
lost-to-path-id not set
    Attributes:
     originator       192.168.30.105
     type             installed
     tloc             192.168.30.105, mpls, ipsec
     ultimate-tloc    not set
     domain-id        not set
     overlay-id        1
     site-id          50
     preference       not set
     tag              not set
     origin-proto     eBGP
     origin-metric    0
     as-path          "65157"
     unknown-attr-len not set
As you notice, attributes of this prefix were preserved similar to how it would be done for any other dynamic routing protocol. AS-path of BGP is just another one attribute of foreign routing protocol that has no meaning for OMP. Note that only one AS is seen in the path. It is an expected behavior because vedge2 didn’t do any advertisement to another BGP neighbor. It did redistribution to OMP from BGP, so it must not prepend its own AS to this prefix.
4) Performing redistribution of OMP into BGP AS 65001, but now on vedge1.
omp
 no shutdown
 overlay-as       64500
 advertise bgp
vpn 40
 router
  bgp 65001
   propagate-aspath
   address-family ipv4-unicast
    redistribute omp
   neighbor 192.168.40.114
    no shutdown
    remote-as 65156
Here is the place where overlay-as actually steps in and plays it's role, but unlike on ordinary Cisco IOS you won't see changes to prefix as it's advertised to R1 because on vEdge there is no command similar to Cisco IOS "show ipv4 uncicast bgp neighbors 192.168.40.114 advertised-routes" that can help us to see newly constructed AS-path.
5) So you are only left with possibility to check AS-path on receiving router (in this case R1).
R1#show bgp vpnv4 unicast vrf vEdge1_18.3 neighbors 192.168.40.104 routes
BGP table version is 11, local router ID is 192.168.41.10
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
              t secondary path,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:183 (default for vrf vEdge1_18.3)
 *>   192.168.51.0     192.168.40.104        1000             0 65001 64500 65157 ?
Conclusion
OMP shares some similarities with BGP, but this fact should not make any confusion when two protocols interact with each other. AS-path is one of the topics that commonly causes such misunderstanding.
Related Information
